Author Topic: Plot routine  (Read 5736 times)
0 Members and 4 Guests are viewing this topic.
alanjt
  • Standby for witty remark...
Re: Plot routine
« Reply #15 on: February 23, 2011, 12:37:41 PM »
Maybe that's what happens when publish in background is selected. I've had that unchecked for years (setvar 'backgroundplot 0) because of speed (on larger drawings).
Nope, I don't use/like background plot - variable is also set to 0.
No answer ... sorry  :?
Ehh, figured. Thanks Ron.
Dropbox
cmwade77
Re: Plot routine
« Reply #16 on: February 23, 2011, 05:41:05 PM »
PUBLISH (won't check where your titleblocks are but will give you an interface to plot)
PUBLISH wont plot all the drawings I have open will it? I would have to make a list of the drawigns I want published.
There is a check box within the publish dialog box to automatically add all open drawings, check it once, close out of the publish command and go back into it, all open drawings should automatically get added.
