I have a UserControl Palette with a TreeView control in which a right-click menu option requires that I use Tony's CommandLine class (
http://www.caddzone.com/CommandLine.cs) to run a command. The problem is that in Tony's code the first if statement AcadApp.DocumentManager.IsApplicationContext is true.
I'm assuming that because when the code for the right-click on the TreeView is run, I'm not actively in a drawing Database but the AutoCAD Application. My question is then how to I get past this and activate the current drawing?
Thanks!
Doug
