Author Topic: How to update a block's insertion point  (Read 1492 times)
kameron1967
« on: February 20, 2011, 11:11:30 PM »
Hi guys,
I have one titleblock name (titleblockA) that has 2 types of insertion point.  Basically, when I insert it into the drawing, it either would come in with the insertion point at the lowest left-hand corner of the trim line (not the border frame) OR will come in with the insertion point at the border frame (approximately 2 inches to the right and half an inch up).
Is there a way to determine which border has the insertion point at the lowest left and change its insertion point so that it's in the corner where the border frame meet?
I'm not sure how to go about doing that.
By the way, the cadtutor.net has a virus today.  I'd be cautious to visit it.  Thanks.
Re: How to update a block's insertion point
« Reply #1 on: February 20, 2011, 11:51:21 PM »
A Piccy would be good.
A drawing and a little more info would be better.
