Morn'n all,
I am just curious as I have a couple drawings with labels that are reversed and it got me thinking, is there a simple code to reverse a string of text?
For example, the current label is "A15", or "AC015", or for a worst case scenario, a label for a fuse "FUSE F12", or "F12 125MA 24VDC". You want the label(s) to read "15A", or "015AC", and for the worst case scenario, the label would read "FUSE 12F", or "12F 125MA 24VDC".
Granted for the worst case scenario, it would be extensive code to search for the fuse label in a string such as this, so you are not reversing the voltage or amperage, but the label only.
But to quench the curiosity without losing a life, has anyone put a piece of code together to reverse a string of text?
Any thoughts, ... suggestions, ... perhaps a challenge for the guru's?.
