Author Topic: split list into lists  (Read 16476 times)
« on: January 14, 2005, 11:40:10 AM »
I'm having a brain freeze problem today!
I want to parse a list into smaller lists excluding a certain item.  Example, given the list
(5 4 3 0 9 8 7 0 6 7 8) separate it into a list of smaller lists such as
((543)(987)(678))
I can't for the life of me figure this out! Maybe because it's Friday. :D
« Reply #1 on: January 14, 2005, 12:01:41 PM »
Always three items?
« Reply #2 on: January 14, 2005, 12:05:09 PM »
Quote from: Se7en
Always three items?
Nope!! can be any number.
« Reply #3 on: January 14, 2005, 12:26:10 PM »
What?! Your killing me!
...Fine, give me a few more min.
whdjr
« Reply #4 on: January 14, 2005, 12:35:40 PM »
Are you always going to use 0 as a divider?
« Reply #5 on: January 14, 2005, 12:36:37 PM »
Quote from: whdjr
yes, well it's always a constant.
« Reply #6 on: January 14, 2005, 12:44:41 PM »
Sorry i dont have more time to test this more. But this is a quick run thru. No pseudo code, no nothing. Just whiped it off the top of my head.
(second run at it though ...*Ahem!?*)
;;; Parse list
;;; Split a list into parts delimited of a specific delim.
;;; Example:
;;; Command: (setq lst '(1 0 2 0 5 0 5 9 2 3 4 7 8 9 5 0 7 8 9))
;;; (1 0 2 0 5 0 5 9 2 3 4 7 8 9 5 0 7 8 9)
;;; Command: (parselst 3 0 lst)
;;; ((1 2 5) (5 5 9) (5 9 2) (3 4 7) (8 9 5) (7 8 9))
(defun parselst (nu del alst / pop# isdel nlst)
  (defun isdel (a b) (= a b))
  (defun pop# (alst / cntr nlst)
    (setq cntr 0 nlst '() )
    (while
      (< (length nlst) nu)
      (if (isdel (nth cntr alst) del)
        (setq cntr (1+ cntr)))
      (setq nlst (cons (nth cntr alst) nlst))
    (reverse nlst)
  (while (>= (length alst) nu)
    (setq nlst (cons (pop# alst) nlst))
    (setq alst (cdddr alst))
  (reverse nlst)
« Reply #7 on: January 14, 2005, 12:55:19 PM »
Whoa nelly!  Thats wrong!?
Hold on I'll fix it.
SMadsen
« Reply #8 on: January 14, 2005, 01:24:39 PM »
Mark, it's just a parser with a delimiter you're making, right? e.g.
(func 8 '(5 4 3 0 9 8 9 0 5 6 8 )) -> ((5 4 3 0 9) (9 0 5 6))
(defun parselst (item lst / l ll)
  (while lst
    (cond ((not (eq (car lst) item))
           (setq l (cons (car lst) l)))
          ((setq ll (cons (reverse l) ll)
                 l  nil))
    (setq lst (cdr lst))
  (reverse (if l (cons (reverse l) ll) ll))
« Reply #9 on: January 14, 2005, 01:38:56 PM »
Quote from: SMadsen
Yes that is correct. That's really close Stig, close enough to get me going anyway. thanks.
Output w/ my list
ll = (32 53 54 46 48 48 32 32 55 56 32 32 56 56 32)
(parselst 32 ll)
(nil (53 54 46 48 48) nil (55 56) nil (56 56))
« Reply #10 on: January 14, 2005, 02:11:06 PM »
More code:
;; Functions originated by Ken Alexander (03-05-03)
;; that are 10X faster than @cv_parse_list, yet limited
;; to only pairs or triplets.
;; Thanks, Ken!
;; (01-02-04) corrected to (while old ...)
;; Revised (01-16-04) to increase speed thanks to Tony T's
;; example of using (while (setq ...))
(defun @cv_double_up (old / new)
    old
    (while
      (setq new (cons (list (car old) (cadr old)) new)
            old (cddr old)
  (reverse new)
(defun @cv_triple_up (old / new)
    old
    (while
      (setq new (cons (list (car old) (cadr old) (caddr old)) new)
            old (cdddr old)
  (reverse new)
;; (01-16-04) combination of @cv_double_up and @cv_triple_up
;; Not yet employed.
(defun @cv_grouplist (old n / new)
  ;; n must be 2 or 3
    old
      ((= n 2)
       (while
               old (cddr old)
      ((= n 3)
       (while
               old (cdddr old)
  (reverse new)
SMadsen
« Reply #11 on: January 14, 2005, 02:23:25 PM »
Quote from: Mark Thomas
Oh well, one typo more or less .. :)  It could've been avoided by using APPEND instead (and code made shorter) but I like CONS better
  (while lst
          ((setq ll (if l (cons (reverse l) ll) ll)
                 l  nil))
« Reply #12 on: January 14, 2005, 03:14:26 PM »
Ooops, Guess I wasn't paying attention. :oops:
« Reply #13 on: January 14, 2005, 03:37:05 PM »
Thanks Stig that's works like a champ. I was trying to wrap the whole thing into a 'apply append mapcar' type setup.
« Reply #14 on: January 14, 2005, 04:12:51 PM »
Ok, im sorry. I got hung up here at work.  ...but im glad you got it working.
BTW, Thats all you wanted?! What was the 'list of three' thing?  (Im not sorry anymore.)
