Author Topic: Delete all Frozen and Hidden Layers  (Read 17538 times)
blahdc
« on: January 25, 2011, 11:24:10 AM »
Sorry for the multiple posts lately. Working on some weird projects. Are there any shortcuts to delete all frozen and hidden layers on a DWG? Right now I have to turn off all my current active layers and turn on all my frozen and hidden layers, select them and delete. It would be fine if there were only 5-10 layers but I'm working with 50+ layers per drawing.  Ideas? Thanks!
Re: Delete all Frozen and Hidden Layers
« Reply #1 on: January 25, 2011, 11:25:55 AM »
This what I use.
(defun c:EFrozeOff (/ ActDoc LayList LayNameList)
    ; Erases all objects on frozen/off layers, then purges drawing.
    (setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
    (vlax-for Lay (vla-get-Layers ActDoc)
            (or
                (= (vla-get-LayerOn Lay) ':vlax-false)
                (= (vla-get-Freeze Lay) ':vlax-true)
                (vla-put-Lock Lay :vlax-false)
                (setq LayList (cons Lay LayList)
                    LayNameList (cons (vla-get-Name Lay) LayNameList)
    (vla-StartUndoMark ActDoc)
    (if LayList
            (vlax-for Layout (vla-get-Layouts ActDoc)
                (vlax-for Obj (vla-get-Block Layout)
                    (if (member (vla-get-Layer Obj) LayNameList)
                        (vla-Delete Obj)
            (vla-PurgeAll ActDoc)
    (vla-EndUndoMark ActDoc)
Krushert
  • FREE BEER Tomorrow!!
« Reply #2 on: January 25, 2011, 11:34:00 AM »
Why don't you use the command LAYDEL?  Core command now but once was a express tool.  If you know the layer name to freeze you enough to delete it.
Quote from: from Autocad's Help
LAYDEL
Deletes all objects on a layer and purges the layer.
blahdc
« Reply #3 on: January 25, 2011, 12:41:12 PM »
Because they are never the same name and can be many hidden and frozen layers.
I'm going to give that LISP a try, looks great!
Update: Using the EFrozeoff lsp works great! Many thanks!
« Last Edit: February 01, 2011, 01:37:19 PM by blahdc »
