Author Topic: Math problem?  (Read 4107 times)
Brick_top
Math problem?
« on: January 21, 2011, 09:28:41 AM »
I know the distances from A to B and C to D.
How do I get the Angle E?
I'm very bad at math, sorry
SOFITO_SOFT
Re: Math problem?
« Reply #1 on: January 21, 2011, 10:00:36 AM »
tangent ( E ) =  DC / CA
arc tang ( E ) = ang E   ( IN RADIANS )
Brick_top
Re: Math problem?
« Reply #2 on: January 21, 2011, 10:13:16 AM »
Hi there! thanks for your response!
I guess someone must have already written the tangent and arc tang in autolisp?
Sorry If i'm saying something stupid.
I'll do a search
Brick_top
Re: Math problem?
« Reply #3 on: January 21, 2011, 10:17:10 AM »
atan is arc tang right?
Brick_top
Re: Math problem?
« Reply #4 on: January 21, 2011, 10:29:58 AM »
You have there Tangent (E) = DC / CA
But I don't know CA
I only know distances I don't know coordinates
« Last Edit: January 21, 2011, 10:48:17 AM by Brick_top »
dgorsman
Re: Math problem?
« Reply #5 on: January 21, 2011, 10:53:41 AM »
You know the lengths of two sides and there's a right angle.  Look to Pythagoras.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Brick_top
Re: Math problem?
« Reply #6 on: January 21, 2011, 11:02:33 AM »
I know that when AB is rotated at the unknown angle E the distance between DC is met
In case I'm making any sense
SEANT
Re: Math problem?
« Reply #7 on: January 21, 2011, 11:13:17 AM »
I think you need ASIN(CD/AB).
That is if AD = AB, i.e., A at center of circle.
Sean Tessier
AutoCAD 2016 Mechanical
Guitar_Jones
Re: Math problem?
« Reply #8 on: January 21, 2011, 11:15:33 AM »
But I don't know CA
Assuming A is at the center of your circle
RADIUS = AD = AB
If you must know AC, you can then use the pythagorean theorum as suggested.
Brick_top
Re: Math problem?
« Reply #9 on: January 21, 2011, 11:21:13 AM »
Hi there, thanks a lot  :-)
using this function I got from here: http://autocad.wikia.com/wiki/Asin_(AutoLISP_function)
;;;  WIKI-ASIN
; End AutoLISP comment mode if on |;
(DEFUN WIKI-ASIN (X)
;| Returns the arc sine of a number
   Edit the source code for this function at
  asin (AutoLISP function)
 (ATAN X (SQRT (- 1 (* X X))))
worked fine
« Last Edit: January 21, 2011, 12:58:24 PM by CAB »
SOFITO_SOFT
Re: Math problem?
« Reply #11 on: January 21, 2011, 01:42:33 PM »
I know the distances from A to B = M
and C to D = N
AD = AB  = M    <<<<   RADIOS OF CIRCLE
AC =  SQRT ( M^2 - N^2 ) = L <<< PITAGORAS
tangent ( E ) =  M / L
in Alisp:
(( setq m ( distance a b ) )
( setq n ( distance c d ) )
( setq L ( sqrt ( - ( expt m 2 ) ( expt n 2 ) ) ) )
( setq e ( atan ( / n L  )) )
remember the swamp when you get to be like A. Einstein. :)
dgorsman
Re: Math problem?
« Reply #12 on: January 21, 2011, 01:43:14 PM »
All that high school math where you said "I'll never use this in the real world!" actually does have its uses   :-P
try {GreatPower;}
   finally
      {MasterBasics;}
SOFITO_SOFT
Re: Math problem?
« Reply #13 on: January 21, 2011, 01:44:02 PM »
Sorry:
tangent ( E ) =  N / L
