Author Topic: Wide Lwpolyline Silhouette  (Read 4657 times)
chlh_jd
« on: January 16, 2011, 04:11:38 AM »
;;;宽POLYLINE转线框程序
(defun c:PPL (/ ssen)
(setq ssen (wjm_ss2lst (ssget (list (cons 0 "LWPOLYLINE")))))
(foreach a ssen
(ss-WPL->PL a T)
(entdel a)
(princ "\n高山流水宽PL线转线框程序,命令PPL")
(defun c:PPL1 (/ ssen)
(foreach a ssen
(ss-WPL->PL a NIL)
(entdel a)
(princ "\n高山流水宽PL线转单段线框程序,命令PPL1")
;;; SS-WPL->PL ;;;
;;; function : Translate Wide LwPolyLine into Frame Border ;;;
;;; Arg : ;;;
;;; pl - PL Ename ;;;
;;; bool - boolean, T or NIL ;;;
;;; If you provide T , Then it'll translate PL to a Closed PL-Frame, ;;;
;;; If it's NIL , Single-stage PL-Frame. ;;;
;;; GE Alg : ;;;
;;; Trisect ARC length and width, Combine sidelines with Convexity ;;;
;;; Example: ;;;
;;; (SS-WPL->PL PL_Ename T) ;_Return a Closed PL-Frame ;;;
;;; Writen By GSLS(SS) 2010-08-08 ;;;
;;; (C) EasyCity OptDesign Studio of Building Structures ;;;
;;; Email: chlh_jd@126.com Tel:0592-5391029 Fax:0592-5391020 ;;;
(defun SS-WPL->PL (pl bool)
(if bool
;;;整条返回封闭POLYLINE
(mapcar 'entmake (ss-PL->Bound pl))
;;;逐段返回封闭POLYLINE
(ss-pl->sbound pl)
« Last Edit: January 16, 2011, 05:25:25 AM by chlh_jd »
chlh_jd
Re: Wide Lwpolyline Silhouette
« Reply #1 on: January 16, 2011, 04:16:26 AM »
Main fun1
(defun SS-PL->Bound (pl     /    ent   is_close pl_vetex
     b     i    lst1   lst2 w02 c0     p1
     p2     w11    w12   c1 b mid    mid1
     mid2   mid3   mid4   mid5 mid6 from1  from2
     mpt1   mpt2   m1   m2 mpt1 mpt2   ang
     dis1   dis2   mptl1  mptr1 mptl2 mptr2  n1
     n2     m3    m4   end
;(setq pl (car (entsel)))
  (setq ent (entget pl '("*")))
  (setq is_close (rem (cdr (assoc 70 ent)) 2))
  (setq pl_vetex nil
b nil
  (foreach n ent ;_(setq e (assoc 10 ent))
    (if (or (= 10 (car n))
    (= 40 (car n))
    (= 41 (car n))
    (= 42 (car n))
) ;_ 结束or
(setq b (cons (cdr n) b))
(if (= 4 (length b))
  (setq pl_vetex (append pl_vetex (list (reverse b)))
b nil
  (setq i    0
lst1 nil
lst2 nil
w02  nil
c0   nil
  (foreach a pl_vetex ;(setq a (nth 1 pl_vetex)) (setq c0 (cadddr (nth 0 pl_vetex)))
    (setq p1 (car a)
  w11 (cadr a)
  w12 (caddr a)
  c1 (cadddr a)
  b (nth (1+ i) pl_vetex)
  mid nil
  mid1 nil
  mid2 nil
  from1 nil
  form2 nil
    (if (and (null b) (= is_close 1))
      (setq b (car pl_vetex))
    (if (setq p2 (car b))
(setq mid (ss-plwk-pts p1 w11 w12 c1 p2))
  (or (null c0) (null w02)) ;_第一段
   (repeat (/ (length mid) 2)
     (setq lst1 (cons (car mid) lst1)
   lst2 (cons (cadr mid) lst2)
   mid (cddr mid)
     (setq from1 (car lst1)
   lst1 (cdr lst1)
   from2 (car lst2)
   lst2 (cdr lst2)
;;;_1同为直段
       ((= c0 c1 0.0)
(setq mid1 (car mid)
      mid2 (cadr mid)
  ((= w02 w11)
   (if (setq mpt1 (inters (car from1)
  (cadr from1)
  (car mid1)
  (cadr mid1)
  nil
       (setq mpt2 (inters (car from2)
  (cadr from2)
  (car mid2)
  (cadr mid2)
  nil
       ;;_无需再次判别连接
       (setq lst1 (cons (ch-lst mpt1 1 from1) lst1)
     lst2 (cons (ch-lst mpt2 1 from2) lst2)
     lst1 (cons (ch-lst mpt1 0 mid1) lst1)
     lst2 (cons (ch-lst mpt2 0 mid2) lst2)
     (setq lst1 (cons mid1 (cons from1 lst1))
   lst2 (cons mid2 (cons from2 lst2))
  ) ;_end cond 2.1
  ((> w02 w11) ;_前宽后窄
   (setq mpt1 (inters (car mid1)
      (cadr mid1)
      (car from1)
      (cadr from1)
      nil
mpt2 (inters (car mid2)
      (cadr mid2)
      (car from2)
      (cadr from2)
      nil
   ) ;_(check-pt (list mpt1 mpt2))
   (if (and mpt1 mpt2) ;_不存在交点,则平行
     (progn ;_存在交点
 ;_有个问题,是取宽端点连线交点,还是取与宽边交点???????????????????????????????????????????
 ;_暂时按方向角改变在[- pi/6 pi/6]
(or
     (/ pi -6.0)
     (- (gsls-ang-trans
  (angle
    (midpt (car from1) (car from2))
    (midpt (cadr from1) (cadr from2))
(gsls-ang-trans
  (angle (midpt (car mid1) (car mid2))
(midpt (cadr mid1) (cadr mid2))
     (/ pi 6.0)
   (/= w01 0.0)
  (setq mpt1 (inters (cadr from1)
     (cadr from2)
     (car mid1)
     (cadr mid1)
     nil
mpt2 (inters (cadr from1)
     (cadr from2)
     (car mid2)
     (cadr mid2)
     nil
   (cons from1 lst1)
   (cons from2 lst2)
  (setq
    mid1  (ch-lst mpt1 0 mid1)
    mid2  (ch-lst mpt2 0 mid2)
    from1 (ch-lst mpt1 1 from1)
    from2 (ch-lst mpt2 1 from2)
     ;;_平行
chlh_jd
« Reply #2 on: January 16, 2011, 04:18:25 AM »
Main Fun1 Continue...
((< w02 w11)
      (cadr mid1)
      (car from1)
      (cadr from1)
      nil
      (cadr mid2)
      (car from2)
      (cadr from2)
      nil
     (progn ;_存在交点
       (if (<= (/ pi -6.0)
       (- (gsls-ang-trans
    (angle (car from1) (cadr from1))
  (gsls-ang-trans
    (angle (car mid1) (cadr mid1))
       (/ pi 6.0)
    (cadr from2)
    (car mid1)
    (car mid2)
    nil
       mpt2 (inters (car from1)
    (cadr from2)
    (car mid1)
    (car mid2)
    nil
       lst1 (cons mid1
       lst2 (cons mid2
     (cadr mid1)
     (car from1)
     (cadr from1)
     nil
     (cadr mid2)
     (car from2)
     (cadr from2)
     nil
 ;_平行
   ) ;_end if
  ) ;_前窄后宽
;;;_2前段直段,后段弧
       ((and (= c0 0.0) (/= c1 0.0))
;(check-pt (cdr (reverse from1)))
      mid2 (cadr mid)
      mid  (cddr mid)
      mid3 (car mid)
      mid4 (cadr mid)
      mid  (cddr mid)
      mid5 (car mid)
      mid6 (cadr mid)
      m1   (SS-PTC-ptcR
     (car mid1)
     (cadr mid1)
     (caddr mid1)
      m2   (SS-PTC-ptcR
     (car mid2)
     (cadr mid2)
     (caddr mid2)
      m3   (SS-PTC-ptcR
     p1
     p2
     c1
      mpt1 (get-mindis-pt (ss-pl-inters from1 mid1) p1)
      mpt2 (get-mindis-pt (ss-pl-inters from2 mid2) p1) ;_(check-pt (list (car from2) (cadr from2)))
  ((= w02 w11) ;_2.1等宽
   (if (or mpt1 mpt2)
       (if mpt1
nil
(setq mpt1
(get-mindis-pt
  (ss-pl-inters from1 (list p1 mpt2 0.0))
  p1
       (if mpt2
nil
(setq mpt2
(get-mindis-pt
  (ss-pl-inters from2 (list p1 mpt1 0.0))
  p1
       (setq
mpt1 (pedal_to_line
(car m1)
(car from1)
(cadr from1)
mpt2 (pedal_to_line
(car m2)
(car from2)
(cadr from2)
ang  (angle (car from1) (cadr from1))
(equal (cadr m1)
(distance (car m1) mpt1)
2e-6
  (setq dis1 0.0)
  (setq
    dis1
     (sqrt (- (expt (cadr m1) 2.0)
      (expt (distance (car m1) mpt1) 2.0)
(equal (cadr m2)
(distance (car m2) mpt2)
2e-6
  (setq dis2 0.0)
  (setq
    dis2
     (sqrt (- (expt (cadr m2) 2.0)
      (expt (distance (car m2) mpt2) 2.0)
       (setq
mptl1 (polar mpt1 (+ ang pi) dis1)
mptr1 (polar mpt1 ang dis1)
mptl2 (polar mpt2 (+ ang pi) dis2)
mptr2 (polar mpt2 ang dis2)
       (cond ((> (distance mptl1 (car mid1))
(distance mptr1 (car mid1))
      (setq mpt1 mptr1)
     ((< (distance mptl1 (car mid1))
      (setq mpt1 mptl1)
     (t
      (setq mpt1 (midpt mptl1 mptr1)) ;_这里需要推敲下,求中点消除误差
       (cond ((> (distance mptl2 (car mid2))
(distance mptr2 (car mid2))
      (setq mpt2 mptr2)
     ((< (distance mptl2 (car mid2))
      (setq mpt2 mptl2)
     (t
      (setq mpt2 (midpt mptl2 mptr2))
   (setq n1 (ss-ptc-c mpt1
      (cadr mid1)
      (car m1)
      (> (caddr mid1) 0.0)
n2 (ss-ptc-c mpt2
      (cadr mid2)
      (car m2)
      (> (caddr mid2) 0.0)
      mpt1
      1
      from1
    lst1
      ) ;_
lst2 (cons (ch-lst
      mpt2
      1
      from2
    lst2
      ) ;_
mid1 (ch-lst n1 2 (ch-lst mpt1 0 mid1))
mid2 (ch-lst n2 2 (ch-lst mpt2 0 mid2))
lst1 (cons mid1 lst1)
lst2 (cons mid2 lst2)
  ((> w02 w11) ;_2.2前宽后窄
 ;_(command "line" (list 0 0 0) mpt2 "")
   (setq mpt1 (get-mindis-pt
(ss-pl-inters
  (list (cadr from1) (cadr from2) 0.0)
  mid1
(car mid1)
mpt2 (get-mindis-pt
(ss-pl-inters
  mid2
(car mid2)
   (if (and mpt1 mpt2) ;_这里需要调整下,可能存在一个交点,也是符合第一项处理
  (cadr mid1)
  (car m1)
     n2 (ss-ptc-c mpt2
  (cadr mid2)
  (car m2)
       (setq lst1 (cons from1 lst1)
     lst2 (cons from2 lst2)
    (ss-pl-inters
      from1
      mid1
    (car mid1)
     mpt2 (get-mindis-pt
    (ss-pl-inters
      from2
      mid2
    (car mid2)
  (cadr mid1)
  (car m1)
     n2 (ss-ptc-c mpt2
  (cadr mid2)
  (car m2)
       (setq from1 (ch-lst mpt1 1 from1)
  ((< w02 w11) ;_2.3前窄后款
   (setq mpt1 (car (ss-pl-inters
     from1
     (list (car mid1) (car mid2) 0.0)
mpt2 (car (ss-pl-inters
     from2
   (if (and mpt1 mpt2)
mpt1
1
from1
      lst1
   lst2 (cons (ch-lst
mpt2
1
from2
      lst2
   (ss-pl-inters
     from1
     mid1
   (car mid1)
   mpt2 (get-mindis-pt
   (ss-pl-inters
     from2
     mid2
   (car mid2)
   n1 (ss-ptc-c mpt1
   (cadr mid1)
   (car m1)
   n2 (ss-ptc-c mpt2
   (cadr mid2)
   (car m2)
   lst (cons mid2 (cons from2 lst1))
(setq
  lst1
       (cons mid5 (cons mid3 lst1))
  lst2
       (cons mid6 (cons mid4 lst2))
       ) ;_end 2.前直后弧
;;;_3前段弧段,后段直
       ((and (/= c0 0.0) (= c1 0.0))
      mid2 (cadr mid)
      m1   (SS-PTC-ptcR
     (car from1)
     (cadr from1)
     (caddr from1)
      m2   (SS-PTC-ptcR
     (car from2)
     (cadr from2)
     (caddr from2)
      m3   (SS-PTC-ptcR
     (/ (+ (caddr from1) (caddr from2)) 2.0)
  ((= w02 w11) ;_3.1等宽 这段代码需要改进,思路不清晰,用了开方,容差性差
   (setq
     mpt1 (pedal_to_line
    (car m1)
    (car mid1)
    (cadr mid1)
     mpt2 (pedal_to_line
    (car m2)
    (car mid2)
    (cadr mid2)
     ang  (angle (car mid1) (cadr mid1))
   (if (equal (cadr m1) (distance (car m1) mpt1) 2e-6)
     (setq dis1 0.0)
     (setq
       dis1
   (if (equal (cadr m2) (distance (car m2) mpt2) 2e-6)
     (setq dis2 0.0)
     (setq
       dis2
   (setq
   (cond ((> (distance mptl1 (cadr from1))
     (distance mptr1 (cadr from1))
  (setq mpt1 mptr1)
((< (distance mptl1 (cadr from1))
  (setq mpt1 mptl1)
(t
   (cond ((> (distance mptl2 (cadr from2))
     (distance mptr2 (cadr from2))
  (setq mpt2 mptr2)
((< (distance mptl2 (cadr from2))
  (setq mpt2 mptl2)
(t
  ((> w02 w11) ;_3.2前宽后窄
      (cadr from2)
      (car mid1)
      (cadr mid1)
      nil
      (cadr from2)
      (car mid2)
      (cadr mid2)
      nil
   (if (and mpt1 mpt2)
     nil
  (ss-pl-inters
    from1
    mid1
  (cadr from1)
   mpt2 (get-mindis-pt
  (ss-pl-inters
    from2
    mid2
  (cadr from2)
  ((< w02 w11) ;_3.3前窄后宽
(ss-pl-inters
  from1
(cadr from1)
mpt2 (get-mindis-pt
(ss-pl-inters
  from2
(cadr from2)
   ) ;_(command "line" (list 0 0) mpt2 "")
   (if (and mpt1 mpt2)
     nil
  (ss-pl-inters
    from1
    mid1
  (cadr from1)
   mpt2 (get-mindis-pt
  (ss-pl-inters
    from2
    mid2
  (cadr from2)
  ) ;_3.3
) ;_end cond
(setq
  n1   (ss-ptc-c (car from1)
mpt1
(car m1)
(> (caddr from1) 0.0)
  n2   (ss-ptc-c
(car from2)
mpt2
(car m2)
(> (caddr from2) 0.0)
  lst1 (cons (ch-lst n1 2 (ch-lst mpt1 1 from1))
     lst1
  lst2 (cons (ch-lst n2 2 (ch-lst mpt2 1 from2))
     lst2
  lst1 (cons mid1 lst1) ;_(check-pt (list mpt1 mpt2))
       ) ;_end 3.前弧后直
;;;_4.前段弧,后段弧
       ((and (/= c0 0.0) (/= c1 0.0))
      mid2 (cadr mid)
      mid  (cddr mid)
      mid3 (car mid)
      mid4 (cadr mid)
      mid  (cddr mid)
      mid5 (car mid)
      mid6 (cadr mid)
      m1   (SS-PTC-ptcR
     (car from1)
     (cadr from1)
     (caddr from1)
      m2   (SS-PTC-ptcR
     (car from2)
     (cadr from2)
     (caddr from2)
      m3   (SS-PTC-ptcR
     (car mid1)
     (cadr mid1)
     (caddr mid1)
      m4   (SS-PTC-ptcR
     (car mid2)
     (cadr mid2)
     (caddr mid2)
(cond ((= w02 w11) ;_4.1等宽
    (cadr from1)
     mpt2
  (get-mindis-pt
    (cadr from2)
       ) ;_有一种可能,因为计算误差,引起交点不存在的情况需要处理
       (setq n1    (ss-ptc-c (car from1)
     mpt1
     (car m1)
     from1 (ch-lst n1 2 (ch-lst mpt1 1 from1))
     n2    (ss-ptc-c
     (car from2)
     mpt2
     (car m2)
     from2 (ch-lst n2 2 (ch-lst mpt2 1 from2))
     n1    (ss-ptc-c mpt1
     (cadr mid1)
     (car m3)
     n2    (ss-ptc-c mpt2
     (cadr mid2)
     (car m4)
      ((> w02 w11) ;_4.2前宽后窄
    (ss-pl-inters
      mid1
    (car mid1)
     mpt2 (get-mindis-pt
    (ss-pl-inters
      mid2
    (car mid2)
       (if (and mpt1 mpt2)
      (cadr mid1)
      (car m3)
n2 (ss-ptc-c mpt2
      (cadr mid2)
      (car m4)
 ;_凸度同号,可能不存在交在宽者法边
       (ss-pl-inters
from1
mid1
       (car mid1)
       mpt2  (get-mindis-pt
       (ss-pl-inters
from2
mid2
       (car mid2)
       mpt1
       (car m1)
       n2    (ss-ptc-c (car from2)
       mpt2
       (car m2)
       n1    (ss-ptc-c mpt1
       (cadr mid1)
       (car m3)
       n2    (ss-ptc-c mpt2
       (cadr mid2)
       (car m4)
       ) ;_end if
      ((< w02 w11) ;_4.3前窄后宽
    (ss-pl-inters
      from1
    (cadr from1)
     mpt2 (get-mindis-pt
    (ss-pl-inters
      from2
    (cadr from2)
       (if (and mpt1 mpt2)
       mpt1
       (car m1)
       mpt2
       (car m2)
 ;_凸度同号,可能不存在都交于宽者法边交点
       (ss-pl-inters
from1
mid1
       p1
       mpt2  (get-mindis-pt
       (ss-pl-inters
from2
mid2
       p1
       mpt1
       (car m1)
       mpt2
       (car m2)
       n1    (ss-ptc-c mpt1
       (cadr mid1)
       (car m3)
       n2    (ss-ptc-c mpt2
       (cadr mid2)
       (car m4)
       ) ;_end if
(setq
  lst1
  lst2
       ) ;_end cond 4
     ) ;_end cond
   ) ;_end pro
) ;_end if
      ) ;_end if pro
    ) ;_end if
    (setq w02 w12
  w01 w11
  c0  c1
  b   nil
  i   (1+ i)
  ) ;_end foreach
chlh_jd
« Reply #3 on: January 16, 2011, 04:19:47 AM »
Main Fun1 Continue...2
;;;双环列表创建完毕
;;;首尾连接处理
  (if (= is_close 1)
    mid1  (last lst1)
    from2 (car lst2)
    mid2  (last lst2)
      (setq mpt1 (get-mindis-pt (ss-pl-inters from1 mid1) (car mid1)) ;_(command "LINE" (list 0 0 0) mpt2 "")
    mpt2 (get-mindis-pt (ss-pl-inters from2 mid2) (car mid2))
      (setq
n1    (if (= (caddr from1) 0.0)
0.0
(ss-ptc-c
  (car from1)
  mpt1
  (car (SS-PTC-ptcR
(car from1)
(cadr from1)
(caddr from1)
n2    (if (= (caddr from2) 0.0)
0.0
  mpt2
  (car (SS-PTC-ptcR
(car from2)
(cadr from2)
(caddr from2)
n1    (if (= (caddr mid1) 0.0)
0.0
(ss-ptc-c mpt1
  (cadr mid1)
  (car (SS-PTC-ptcR
(car mid1)
(cadr mid1)
(caddr mid1)
n2    (if (= (caddr mid2) 0.0)
0.0
(ss-ptc-c mpt2
  (cadr mid2)
  (car (SS-PTC-ptcR
(car mid2)
(cadr mid2)
(caddr mid2)
lst1  (ch-lst from1 0 lst1)
lst1  (reverse (ch-lst mid1 0 (reverse lst1)))
lst2  (ch-lst from2 0 lst2)
lst2  (reverse (ch-lst mid2 0 (reverse lst2)))
  ;;首尾连接处理完毕
;(setvar "osmode" 0) ;_测试用
  (setq lst1 (reverse lst1)) ;_(command "line" (list 0 0 0) (nth 0 (nth 2 lst2)) "")
  (if (= is_close 0)
      (setq len (length lst1)
    i 1
    lst nil
      (foreach a lst1
(if (< i len)
    (setq
      lst
       (append lst
       (list (cons 10 (car a)) (cons 42 (caddr a)))
    (if (eq (cadr a) (car (nth i lst1)))
      nil
      (setq lst
     (append lst (list (cons 10 (cadr a)) (cons 42 0.0)))
    (setq
      lst
       (append lst
    (setq
      lst
(setq i (1+ i))
      (setq i 1)
      (foreach a lst2
(if (< i len)
    (setq lst
   (append
     lst
     (list (cons 10 (cadr a)) (cons 42 (* -1.0 (caddr a))))
    (if (eq (car a) (cadr (nth i lst2)))
      nil
      (setq lst
     (append lst (list (cons 10 (car a)) (cons 42 0.0)))
    (setq lst (append lst
    (setq
      lst
(setq i (1+ i))
      (setq lst (append (list (cons 0 "LWPOLYLINE")
      (cons 100 "AcDbEntity")
      (cons 100 "AcDbPolyline")
      (cons 90 (/ (length lst) 2))
      (cons 70 1)
      (cons 43 0.0)
lst
      ) ;_(check-pt (ss-assoc 10 lst))
;(entmakex lst)
      (setq end (list lst))
    i 1
    lst nil
      (foreach a lst1
(if (< i len)
    (setq
      lst
       (append lst
    (if (eq (cadr a) (cadr (nth i lst1)))
      nil
      (setq lst
    (setq
      lst
       (append lst
    (if (eq (cadr a) (caar lst1))
      nil
      (setq
lst
(setq i (1+ i))
      (cons 70 1)
      (cons 43 0.0)
lst
;(entmakex lst)
      (setq i 1
    lst2 (reverse lst2)
    end (cons lst end)
    lst nil
      (foreach a lst2
(if (< i len)
    (setq
      lst
       (append
lst
    (if (eq (cadr a) (cadr (nth i lst2)))
      nil
      (setq lst
    (setq
      lst
       (append lst
    (if (eq (cadr a) (caar lst2))
      nil
      (setq
lst
(setq i (1+ i))
      (cons 70 1)
      (cons 43 0.0)
lst
      (setq end (reverse (cons lst end)))
;(entmakex lst)
  ) ;_end if
  end
chlh_jd
« Reply #4 on: January 16, 2011, 04:20:55 AM »
Main Fun2
(defun SS-PL->SBound (pl     /     ent    is_close pl_vetex
      mid2
     ) ;(setq pl (car (entsel)))
  (setq pl_vetex nil
b nil
    (= 40 (car n))
    (= 41 (car n))
    (= 42 (car n))
) ;_ 结束or
b nil
  (setq i 0
b nil
    (setq p1  (car a)
  w11 (cadr a)
  w12 (caddr a)
  c1  (cadddr a)
;(if (= i 1) (princ "暂停"))
      lst1 nil
      lst2 nil
      lst3 nil
      lst4 nil
  (setq
    mid1 (car mid)
    mid2 (cadr mid)
    mid (cddr mid)
    lst1 (if (equal (car mid1) (car lst1))
   (cons (cadr mid1) lst1)
   (cons (cadr mid1) (cons (car mid1) lst1))
    lst2 (if (equal (car mid2) (car lst2))
   (cons (cadr mid2) lst2)
   (cons (cadr mid2) (cons (car mid2) lst2))
    lst3 (cons (caddr mid1) lst3)
    lst4 (cons (* -1.0 (caddr mid2)) lst4)
(draw-pline
  (append (reverse lst1) lst2)
  0.0
  (append (reverse lst3) (append (cons 0.0 lst4) (list 0.0)))
  nil
  -1
  1
      ) ;_end if pro
    (setq i (1+ i))
  ) ;_end foreach
 ;_end if
chlh_jd
« Reply #5 on: January 16, 2011, 04:26:58 AM »
Used Fun1
(setq _pi2 1.5707963267948966192313216916395
      _2pi 6.283185307179586476925286766559
      _1d 0.0174532925199433)
;;;获取单段PL线的4个角点和两边凸度
;;;直线段返回4个点((pt11 pt21 n11) (pt12 pt22 n12))
;;;高山流水2010-06-25
;;;(ss-plwk-pts p1 w11 w12 c1 p2)
;;;(setq pt1 p1 w1 w11 w2 12 n c1 pt2 p2)
(defun ss-plwk-pts (pt1    w1   w2 n pt2    /      ptcR0
    ptc0   R0   mpt0 ang1 ang2 ang2a  ang2a/6 dw pt11
    pt12   pt21   pt22 ptm1 ptm2   ptcr1  ptcr2
    ptlst   lst i  n1 n2
  (if (/= n 0.0)
      (setq ptcR0 (SS-PTC-ptcR pt1 pt2 n)
    ptc0  (car ptcr0)
    R0   (cadr ptcr0)
    ang1  (angle ptc0 pt1)
    ang2  (angle ptc0 pt2)
    ang2a (angle (list 0.0 0.0 0.0) (gsls-XY->AB pt2 ptc0 ang1))
    ang2a (if (> n 0)
    ang2a
    (- ang2a _2pi)
    ang2a/6 (/ ang2a 6.0)
    dw (/ (- w2 w1) 6.0)
      (setq i 0
    ptlst nil)
      (repeat 7
(setq pt11 (polar (polar ptc0 (+ ang1 (* i ang2a/6)) R0) (+ ang1 (* i ang2a/6) pi) (/ (+ w1 (* i dw)) 2.0))
      pt12 (polar (polar ptc0 (+ ang1 (* i ang2a/6)) R0) (+ ang1 (* i ang2a/6)) (/ (+ w1 (* i dw)) 2.0))
      ptlst (cons pt12 (cons pt11 ptlst))
      i (1+ i)
      ;(check-pt ptlst)
      (setq i 0
    ptlst (reverse ptlst)
    lst nil
      (repeat 3
(setq pt11 (nth (* i 4) ptlst)
      pt12 (nth (1+ (* i 4)) ptlst)
      ptm1 (nth (+ (* i 4) 2) ptlst)
      ptm2 (nth (+ (* i 4) 3) ptlst)
      pt21 (nth (+ (* i 4) 4) ptlst)
      pt22 (nth (+ (* i 4) 5) ptlst)
      ptcr1 (SS-PT-ptcR pt11 ptm1 pt21)
      ptcr2 (ss-pt-ptcr pt12 ptm2 pt22)
      n1 (ss-ptc-c pt11 pt21 (car ptcr1) (> n 0))
      n2 (ss-ptc-c pt12 pt22 (car ptcr2) (> n 0))
(if (> n 0.0)
(setq lst (cons (list pt12 pt22 n2) (cons (list pt11 pt21 n1) lst)))
(setq lst (cons (list pt11 pt21 n1) (cons (list pt12 pt22 n2) lst)))
(setq i (1+ i))
      (setq lst (reverse lst))
      (setq ang (angle pt1 pt2)
    pt11 (polar pt1 (+ ang _pi2) (/ w1 2.0))
    pt12 (polar pt1 (- ang _pi2) (/ w1 2.0))
    pt21 (polar pt2 (+ ang _pi2) (/ w2 2.0))
    pt22 (polar pt2 (- ang _pi2) (/ w2 2.0))
      (list (list pt11 pt21 0.0) (list pt12 pt22 0.0))
;;;已知圆弧起点、终点和凸度,求圆心和半径
;;;高山流水2010-06-25
;;;(SS-PTC-ptcR '(764814.0 -1.11779e+006 0.0) '(734523.0 -1.11239e+006) -0.722053)
(defun SS-PTC-ptcR (pt1 pt2 convexity / ang mpt a b ptc R)
mpt (midpt pt1 pt2)
b   (distance pt1 mpt)
a   (* b
       (/ (sin (- _pi2 (* 2.0 (atan convexity))))
  (cos (- _pi2 (* 2.0 (atan convexity))))
ptc (polar mpt (+ ang _pi2) a)
R   (sqrt (+ (* a a) (* b b)))
  (list ptc R)
;;;已知圆弧上的3点,求圆心和半径
;;;高山流水2010-06-25
(defun SS-PT-ptcR (pt1 mpt pt2 / mpt1 mpt2 mpt11 mpt22 ptc R)
  (setq mpt1  (midpt pt1 mpt)
mpt2  (midpt mpt pt2)
mpt11 (polar mpt1 (+ (angle pt1 mpt) _pi2) 1000.0)
mpt22 (polar mpt2 (+ (angle mpt pt2) _pi2) 1000.0)
ptc   (inters mpt1 mpt11 mpt2 mpt22 nil)
R     (distance ptc pt1)
  );_(check-pt (list pt1 mpt pt2))
  (list ptc R)
;;;已知圆弧的端点pt1->pt2,圆心ptc,求凸度
;;;高山流水2010-06-26
(defun ss-ptc-c (pt1 pt2 ptc is_nsz / ang1 pt2a ang2)
  (setq ang1 (angle ptc pt1)
pt2a (gsls-XY->AB pt2 ptc ang1)
ang2 (angle (list 0.0 0.0 0.0) pt2a)
  (if is_nsz
    nil
    (setq ang2 (- ang2 _2pi))
  (/ (sin (/ ang2 4.0)) (cos (/ ang2 4.0)))
;;;已知起止点和凸度求法向角度
;;;参数mid = (list pt1 pt2 conv)
;;;参数boe = 0 或1 0为起点,1为终点
(defun ss-pl-Nang (mid boe / pt1 pt2 conv ptc)
  (setq pt1  (car mid)
pt2  (cadr mid)
conv (caddr mid)
ptc  (car (ss-pt-ptcr pt1 pt2 conv))
  (cond ((and (= boe 0) (> conv 0))
(angle pt1 ptc)
((and (= boe 1) (> conv 0))
(angle pt2 ptc)
((and (= boe 0) (< conv 0))
(angle ptc pt1)
((and (= boe 1) (< conv 0))
(angle ptc pt2)
(t
(+ (angle pt1 pt2) _pi2)
;;;求直线、圆弧交点集,点凸版
;;;(ss-pl-inters '((713708.0 -563492.0) (717691.0 -570078.0) 0.0) '((715257.0 -566053.0) (720145.0 -553354.0) 0.280634))
(defun ss-pl-inters (mid1 mid2 / intersections)
  (setq pt11 (car mid1)
pt12 (cadr mid1)
n1 (caddr mid1)
pt21 (car mid2)
pt22 (cadr mid2)
n2 (caddr mid2)
intersections nil
  (cond ((= n1 n2 0.0) ;_直线交直线
(list (inters pt11 pt12 pt21 pt22 nil))
((and (= n1 0.0) (/= n2 0.0)) ;_直线交圆弧
(setq ptcr2 (SS-PTC-ptcR pt21 pt22 n2))
(L_INT_C pt11 pt12 (car ptcr2) (cadr ptcr2))
((and (/= n1 0.0) (= n2 0.0)) ;_圆弧交直线
(setq ptcr1 (SS-PTC-ptcR pt11 pt12 n1))
(L_INT_C pt21 pt22 (car ptcr1) (cadr ptcr1))
((and (/= n1 0.0) (/= n2 0.0)) ;_圆弧交圆弧
(c_int_c (car ptcr1) (cadr ptcr1) (car ptcr2) (cadr ptcr2))
;;;求圆弧和直线中点,点凸版
(defun ss-pl-midpt
       (pt1 pt2 n / endpt ptcr ptc redia ang1 pt2a ang2 ang)
  (if (= n 0.0)
    (setq endpt (midpt pt1 pt2))
    (setq ptcr (SS-PTC-ptcR pt1 pt2 n)
  ptc (car ptcr)
  radia (cadr ptcr)
  ang2 (if (> n 0.0)
  ang2
  (- ang2 _2pi)
  ang (if (> n 0.0)
  (+ ang1 (* ang2 0.5))
  (- ang1 (* ang2 0.5))
  endpt (polar ptc ang radia)
  endpt
chlh_jd
« Reply #6 on: January 16, 2011, 04:34:16 AM »
Used Fun2
(defun gsls-ang-trans (ang)
  (while (> ang pi)
    (setq ang (- ang pi))
  (while (< ang 0.0)
    (setq ang (+ ang pi))
  (if (equal ang pi 1e-3)
    (setq ang 0.0)
  ang
(defun L_INT_C (l_end1 l_end2 c_cen c_rad / pedal dist_cen_l int1 int2
  ints)
    (setq pedal (pedal_to_line c_cen l_end1 l_end2)
  dist_cen_l (distance pedal c_cen))
      ((equal c_rad dist_cen_l min_num) (setq ints (list pedal)))
      ((> c_rad dist_cen_l)
(setq int1
(polar pedal
       (angle l_end1 l_end2)
       (sqrt (- (* c_rad c_rad) (* dist_cen_l dist_cen_l)))
(setq int2
(polar pedal
       (+ pi (angle l_end1 l_end2))
(setq ints (list int1 int2))
    ints
;;;点到直线的垂足坐标
(defun pedal_to_line (pt pt1 pt2)
  (inters
    pt
    (polar pt (+ (/ pi 2) (angle pt1 pt2)) 1000)
    pt1
    pt2
    nil
;______________________________________________________________________
 ;_________________求交点核心函数部分____BY__WKAI__晓东CAD论坛__________
 ;___________________2003.12.11.14.33___________________________________
 ;_精度设置_____________________________________________________________
  (setq min_num 1e-7)
 ;___________________圆与圆交点函数,输入值圆心1,半径1,圆心2,半径2.返回值交点表
  (defun c_int_c (c1_cen c1_rad c2_cen c2_rad / ints c1c2_dis dd ee)
    (setq c1c2_dis (distance c1_cen c2_cen))
      ((equal c1c2_dis (+ c1_rad c2_rad) min_num)
       (setq ints (list (polar c1_cen (angle c1_cen c2_cen) c1_rad)))
      ((equal c1c2_dis (abs (- c1_rad c2_rad)) min_num)
       (if (minusp (- c1_rad c2_rad))
(setq ints (list (polar c2_cen (angle c2_cen c1_cen) c2_rad)))
      ((and (> c1c2_dis (abs (- c1_rad c2_rad)))
    (< c1c2_dis (+ c1_rad c2_rad))
(setq dd (/ (- (+ (* c1c2_dis c1c2_dis) (* c1_rad c1_rad))
(* c2_rad c2_rad)
     (* 2 c1c2_dis)
(setq ee (sqrt (- (* c1_rad c1_rad) (* dd dd))))
(setq
   ints (list (polar (polar c1_cen (angle c1_cen c2_cen) dd)
     (+ (angle c1_cen c2_cen) (/ pi 2))
     ee
(setq ints
(append
  ints
       (- (angle c1_cen c2_cen) (/ pi 2))
       ee
    ints
chlh_jd
« Reply #7 on: January 16, 2011, 04:37:13 AM »
Used Fun3
;;;获取点集ptlst中与点pt距离最近的点
(defun get-mindis-pt (ptlst pt)
  (car
    (vl-sort ptlst
     (function (lambda (e1 e2)
(< (distance e1 pt) (distance e2 pt))
;;表项替代函数
(defun ch-lst (new i lst / j)
  (if (numberp i)
    (cond ((zerop i) (cons new (cdr lst)))
  ((> i 0)
   (cons
     (car lst)
     (ch-lst
       new
       (1- i)
       (cdr lst)
  (T lst)
      (setq j (cadr i)
    i (car i)
      (if j
(ch-lst (ch-lst new j (nth i lst)) i lst)
(ch-lst new i lst)
;;;转换选择集为表
(defun wjm_ss2lst (ss / i e lst)
  (if (= (type ss) 'PICKSET)
      (setq i -1)
      (while (setq e (ssname ss (setq i (1+ i))))
(if (= (type e) 'ENAME) (setq lst (cons e lst)) nil)
      lst
    nil
;;;drwa-pline        ;;;
;;;function: to make a polyline by code and return ename
;;;Variants:
;;;pl_list: the points list offered by order
;;;width : 0.0 or num, or a list like ((0.0 0.0) (0.0 20) (20 0.0)...),if nil it will getvar "plinewid" ,
;;;        if it's length noteq d90 then wid41 and wid42 equal to 0.0 .
;;;d42_lst: 0.0 or num, or nil, if nil or it's length noteq d90 then d42 equal to 0.0 .
;;;lay_pl: layername, if nil it will getvar "CLAYER"
;;;color : color number, if it's -1 then getvar "COLOR" ellse set it by the given color number
;;;Prompt:
;;;If width list or d42_lst list is Exist , it's order must be same to the pl_list,
;;;   otherwise it will take out a wrong polyline .
;;;Written By WJM and GSLS(SS),2010.06.30
(defun draw-pline
  (pl_list width   d42_lst lay_pl  color   d70
   /    d90    i    wid    d42    wid40
   wid41   en000   pb
  (setq d90 (length pl_list)
pb  '()
i   0
  (cond ((and (listp width)
      (listp d42_lst)
      (= (length width) (length d42_lst) d90)
(foreach pt pl_list
   (setq wid   (nth i width)
d42   (nth i d42_lst)
wid40 (car wid)
wid41 (cadr wid)
pb    (append pb
       (list (cons 10 pt)
     (cons 40 wid40)
     (cons 41 wid41)
     (cons 42 d42)
i     (1+ i)
((and (or (numberp width) (null width))
      (listp d42_lst)
      (= (length d42_lst) d90)
(if (null width)
   (setq wid40 (getvar "plinewid")
wid41 (getvar "plinewid")
   (setq wid40 width
wid41 width
(foreach pt pl_list
   (setq d42 (nth i d42_lst)
pb  (append pb
     (list (cons 10 pt)
   (cons 40 wid40)
   (cons 41 wid41)
   (cons 42 d42)
i   (1+ i)
((and (listp width)
      (= (length width) d90)
      (or (null d42_lst) (numberp d42_lst))
(if (null d42_lst)
   (setq d42 0.0)
   (setq d42 d42_lst)
(foreach pt pl_list
wid40 (car wid)
wid41 (cadr wid)
pb    (append pb
       (list (cons 10 pt)
     (cons 40 wid40)
     (cons 41 wid41)
     (cons 42 d42)
i     (1+ i)
(t
(if (numberp width)
   (setq wid40 width
wid41 width
   (setq wid40 0.0
wid41 0.0
(foreach pt pl_list
   (setq pb (append pb
    (list (cons 10 pt)
  (cons 40 wid40)
  (cons 41 wid41)
  (cons 42 0.0)
  (setq en000 (append (list
(cons 8
      (if (and lay_pl (/= lay_pl ""))
lay_pl
(getvar "CLAYER")
(cons 90 d90)
(cons 70 d70)
      pb
  (if (and color (/= -1 color))
    (setq en000 (append en000 (list (cons 62 color))))
  (if (= nil (entmake en000))
    (princ "\n制造 LWPL 制造失败.")
  (entlast)
Crank
« Reply #8 on: January 16, 2011, 06:50:51 AM »
Very nice, thanks for sharing this!
Nb.: I think you forgot to add the function MIDPT
Is it possible to post this as an .lsp attachement? I want to give you full credit, but when I copy/paste the Chinese characters turn into question marks.  :|
xiaxiang
« Reply #9 on: January 16, 2011, 08:30:19 PM »
Yes.Why not to post a complete lsp? Some Translation maybe help.
chlh_jd
« Reply #10 on: January 16, 2011, 11:41:09 PM »
I'm sorry to forget the fun 'MIDPT',
These Codes is very rough, hope to have a more comprehensive and more concise procedures.
the 'midpt' fun
;;;求两点中点
(defun midpt (pta ptb)
  (mapcar (function (lambda (x y)
      (/ (+ x y) 2.0)
  pta
  ptb
chlh_jd
« Reply #11 on: January 17, 2011, 12:20:13 AM »
Now, Upload the lsp file
danallen
« Reply #12 on: September 13, 2012, 01:54:14 AM »
Thank you chlh_jd for sharing this code.
-Dan
chlh_jd
« Reply #13 on: September 13, 2012, 08:20:14 AM »
-Dan
You are welcome !
