in vectorwroks there is a command that will just rotate the object everytime you hit...say "alt/sft/R" (or whatever)
is there any command in cad that will jsut rotate said object w/o having to hit ro/enter, then use the tool....sort of like the copy/paste command set is started and completed with only keys.
id like to, if an object needs to be rotated 270 degrees, i can just hit, "this set of keys" 3 times to get it right.
-make any sense?
