Unfortunately, this file is a conglomeration (SP?) of dwgs from different trades. The Main Contractor is insistant that everything be in ONE CAD Dwg.
Yes there are 3D items in the dwg. OURS it 2D, but I cannot flatten anything. Basically, I am simply XRef'ing ours into the Master dwg, so I really can do too much.
The purpose of my original question was to rule out errors.
I have done the purge / Audit dwg things and found no errors.
The size is soooo large I guess I assumed something is wrong with it. Again, I have never seen nor heard of a dwg this large!
Do any of you folks work with dwgs this large?
craigr
