Author Topic: (AutoCAD LT) Error Message  (Read 5710 times)
mondes
« on: January 04, 2011, 04:18:36 PM »
I just installed LT 2011 on my computer and while working in the drawing editor I constatly get the error message:
“You do not have permission to save to this location.  Contact your administrator to obtain this permission.”  (there is no active “save” command).  This message is interfering with my work.  What’s wrong?
I use Windows 7.
Re: Error Message
« Reply #1 on: January 04, 2011, 04:43:54 PM »
Where do you have autocad configured to save your temp files?
Turn OFF Autosave
OR
Make sure you are local Administrator/Power User on that machine; and have full permissions on all your working folders.
mondes
Re: Error Message
« Reply #2 on: January 04, 2011, 04:57:18 PM »
now you mention it, I did change that to a folder under LT 2011 I call "File Backups".  I always do that with all my autocad installs cause I don't like the convoluted place autodesk likes to hide them.
Re: Error Message
« Reply #3 on: January 04, 2011, 05:05:25 PM »
the solution is often the problem
mondes
Re: Error Message
« Reply #4 on: January 04, 2011, 05:09:04 PM »
Yeah, now if I want to change it back I'll have to reinstall cause I sure as hell don't remember it!  Can you paste it in to a reply?
Re: Error Message
« Reply #5 on: January 04, 2011, 05:12:25 PM »
I'm NOT working with LT
However this is where my default location is autosaving to, and luky for you C3D just did!
C:\Users\ADMINI~1\AppData\Local\Temp\210710_Basetopo-Design_1_1_3544.sv$
mondes
Re: Error Message
« Reply #6 on: January 05, 2011, 11:56:16 AM »
"Make sure you are local Administrator/Power User on that machine; and have full permissions on all your working folders."
Any idea how to check this?
Re: Error Message
« Reply #7 on: January 05, 2011, 12:11:43 PM »
Are you the sytems administrator?
If
Yes
Then
You would know.
