Author Topic: How to change texstyle of sellected dtext  (Read 3010 times)
GDF
« on: January 03, 2011, 10:21:54 AM »
I base my dtext height off of the dimscale value. My question is how to I select all dtext on a layer to modify the (40 . 0.0937501) to
(40 . 0.375), or any new value based upon a different dimscale?
I want the routine do scale up all of the sellected dtext. I need more coffeeeeeeee
(0 . "TEXT")
(330 . <Entity name: 7ee4fcf8>)
(5 . "108")
(100 . "AcDbEntity")
(67 . 0)
(410 . "Model")
(8 . "A-NOTE")
(100 . "AcDbText")
(10 11.3032 10.9047 0.0)
(40 . 0.0937501)
(1 . "30\" CLEARANCE MIN")
(50 . 0.0)
(41 . 0.7)
(51 . 0.0)
(7 . "NOTES")
(71 . 0)
(72 . 0)
(11 0.0 0.0 0.0)
(210 0.0 0.0 1.0)
(100 . "AcDbText")
(73 . 0)
(0 . "TEXT")
(5 . "10D")
(67 . 0)
(410 . "Model")
(8 . "A-NOTE")
(100 . "AcDbText")
(10 11.3854 9.44752 0.0)
(40 . 0.375)
(50 . 0.0)
(41 . 0.7)
(51 . 0.0)
(7 . "NOTES")
(71 . 0)
(72 . 0)
(11 0.0 0.0 0.0)
(210 0.0 0.0 1.0)
(100 . "AcDbText")
(73 . 0)
;;my old out of date routine:
(defun STY-NOTES ();(/ sset cnt sty enam eobj wid)
  (setq XNOTES 0.7)
  (setvar "cmdecho" 0)
  ;(command "-style" ARCH#TXSN ARCH#TXFN "0" (rtos XNOTES 2 3) "0" "N" "N" "N")
  (command "-style" ARCH#TXSN ARCH#TXFN "0" (rtos XNOTES 2 3) "0" "N" "N")
  (setq SSET (ssget "X"
                    (list (cons 0 "*TEXT")
                          (cons 7 "ANNO*,HELVL,NOTE*,STANDARD")
                          (cons 8 "0,*ANNO*,*DATA*,*DIM*,*LEAD*,*NOTE*,*SYM*,*TEXT*")
        CNT  0
        STY  "NOTES"
        WID  XNOTES
  (if SSET
      (repeat (sslength SSET)
        (setq ENAM (ssname SSET CNT)
              CNT  (1+ CNT)
              EOBJ (vlax-ename->vla-object ENAM)
          (vla-put-stylename EOBJ STY)
          (vla-put-scalefactor EOBJ WID)
      (princ
        "\n*        Text: Textstyle Notes completed         *"
Re: How to change texstyle of sellected dtext
« Reply #1 on: January 03, 2011, 11:24:49 AM »
Couldn't you just use entmod Gary?
(setq el (entget (car (entsel))))
(entmod (subst (cons 40 0.375) (assoc 40 el) el))
GDF
« Reply #2 on: January 03, 2011, 11:57:40 AM »
Thanks Ron
I need to change (setq el (entget (car (entsel)))) to get all of the dtext objects with that current textstyle value.
So that all of the dtext within that sellection set can be changed.
« Reply #3 on: January 03, 2011, 12:13:54 PM »
Maybe something like this Gary?
(defun c:test ( / ht ss i elist )
  ;; Example by Lee Mac 2011 - www.lee-mac.com
    (and
      (setq ht (getdist "\nSpecify New Text Height: "))
      (setq ss (ssget "_X" (list (cons 0 "TEXT") (cons -4 "<NOT") (cons 40 ht) (cons -4 "NOT>"))))
    (repeat (setq i (sslength ss))
      (if (setq elist (entget (ssname ss (setq i (1- i))))
                elist (entmod (subst (cons 40 ht) (assoc 40 elist) elist))
        (entupd (cdr (assoc -1 elist)))
EDIT: Noticed you also want to filter by a layer: add something like:
(cons 8 "Your Layer Here")
To the ssget filter list :-)
« Last Edit: January 03, 2011, 12:18:01 PM by Lee Mac »
trogg
« Reply #4 on: January 03, 2011, 12:19:01 PM »
Lee,
Is this your first posting for 2011?
meaning "did you ever take a break over the weekend?"
~Greg
GDF
« Reply #5 on: January 03, 2011, 12:20:26 PM »
Thanks Lee that was what I was looking for.
I had a second cup of cooffee, and it still has not kicked in.
This is my text height value for my notes in architectural units:
(setq ht (/ (getvar "dimscale")  10.66666))
The more I learn the less I know...
Thanks again
« Reply #6 on: January 03, 2011, 12:37:30 PM »
lol yeah, had a small break - but you should know by now that I'm a Swamp addict  :lol:
« Reply #7 on: January 03, 2011, 12:37:49 PM »
Thanks again
Cool - you all sorted now?  :-)
GDF
« Reply #8 on: January 03, 2011, 12:43:25 PM »
Yes, thanks again Ron and Lee
here is my modified routine:
    (and
      (setq ss (ssget "_X" (list (cons 7 "ANNO*,HELVL,NOTE*,STANDARD")(cons 8 "0,*ANNO*,*NOTE*,*TEXT*")(cons 0 "TEXT")(cons -4 "<NOT")(cons 40 ht)(cons -4 "NOT>"))))
    (and
      (setq ht (/ (getvar "dimscale")  5.33333))
      (setq ss (ssget "_X" (list (cons 7 "TITLE,HELVL,NOTE*,STANDARD")(cons 8 "0,*SHTT*,*SYMB*")(cons 0 "TEXT")(cons -4 "<NOT")(cons 40 ht)(cons -4 "NOT>"))))
« Reply #9 on: January 03, 2011, 01:07:01 PM »
I didn't do much .. but glad to help anyways  :-).
Not important but you could also shorten up your filter a bit with '(-4 . "/=")(cons 40 ht) rather than (cons -4 "<NOT")(cons 40 ht)(cons -4 "NOT>").
Ron
