Author Topic: Lisp to delete AutoCAD Recent folder contents  (Read 16883 times)
Re: Lisp to delete AutoCAD Recent folder contents
« Reply #15 on: January 02, 2011, 10:48:22 PM »
The folder content looks like the attached piccy, and has no MRU list.
The MRU list is maintained in the registry, just as you pointed out in your first post
« Reply #16 on: January 02, 2011, 11:02:28 PM »
It is now, but Alans post sems to indicate it was kept in a folder.
I'd be interested in knowing if that list matches the MRU list on the menu->File pulldown
.. I can't recall because of a selective memory.
« Reply #17 on: January 03, 2011, 12:26:59 AM »
I'll take a look tomorrow. Too late here.
« Reply #18 on: January 03, 2011, 08:59:34 AM »
This folder has most of the files listed in the MRU pull down menu but not all and some that are not listed:
C:\Documents and Settings\Alan\Application Data\Autodesk\AutoCAD 2006\R16.2\enu\Recent\Select File
The registry has the exact list.
When I run Kerry's routine the registry is cleared but the MRU in the file pull down remains un affected.
Shutting ACAD down & re start the registry list is restored with the list.
« Reply #19 on: January 03, 2011, 12:28:20 PM »
The MRU list in the registry is read when AutoCAD opens only. Once the menu is populated the registry isn't used again until AutoCAD closes, at which point, the MRU list is updated in the registry. This would mean that AutoCAD maintains the MRU list in the registry while it isn't running, but in the application while it is, only updating upon closing.
If you open multiple instances of AutoCAD and open different drawings in each, the MRU in each instance will be slightly different. Then as you close AutoCAD instances, the registry MRU is updated. The MRU in the last instance of AutoCAD to close will be the MRU that is displayed when AutoCAD is started again.
Some earlier versions of AutoCAD allowed multiple instances, I don't know if you can make the later ones open separate application windows.
