Author Topic: Change LineType Scale...  (Read 2608 times)
MeasureUp
« on: December 22, 2010, 06:32:28 PM »
There is no problems when changing linetype scale by selecting object on the screen.
command: chprop -> select object -> "s"
But this won't work when writing to the code.
For example, I want to change the selected object to
1) Layer: steel
2) Linetype Scale: 0.5
And the following is what I get.
(command "._chprop" "last" "" "layer" "Steel" "" "S" "0.5")
Command: ._chprop
Select objects: last 1 found
Select objects:
Enter property to change
[Color/LAyer/LType/ltScale/LWeight/Thickness/TRansparency/Material/Annotative]:
layer
Enter new layer name <Dims>: Steel
Command: S Unknown command "S".  Press F1 for help.
Command: 0.5 Unknown command "5".  Press F1 for help.
Does anyone has a solution?
Thanks for your help.
Re: Change LineType Scale...
« Reply #1 on: December 22, 2010, 06:39:46 PM »
Move the quotes between "Steel" and "S" to the end:
(command "._chprop" "last" "" "layer" "Steel" "S" "0.5" "")
MeasureUp
« Reply #2 on: December 22, 2010, 07:10:49 PM »
That is it.
Thank you very much & merry Christmas.
« Reply #3 on: December 23, 2010, 05:46:54 AM »
Should you want to approach it another way  :-)
(defun c:test ( / ss i )
  (if (setq ss (ssget "_L"))
      (entupd
        (cdr
          (assoc -1
            (_UpdateDXF  48 0.5
              (_UpdateDXF 8 "Steel"
                (entget (ssname ss (setq i (1- i))))
(defun _UpdateDXF ( code value elist )
  (cond ( (entmod (list (assoc -1 elist) (cons code value))) ) ( elist ))
Merry Christmas guys!  :-)
alanjt
  • Standby for witty remark...
« Reply #4 on: December 23, 2010, 08:51:10 AM »
Do you find inconsistencies in using entmod that way? I tried it a few weeks back, but it didn't work on LWPolylines and randomly didn't work on Lines.
Also, you shouldn't need to step through the selection set since (ssget "_L") will only select the last object - (ssname ss 0) should suffice, or am I just wrong?
Dropbox
« Reply #5 on: December 23, 2010, 09:34:21 AM »
I've found it works in most cases, but not when updating MText formatting, or on non-graphical entities such as layers etc.
Good point, I think does only collect one entity - oh well, at least its open for easy modification should the user want to change it  :-)
« Last Edit: December 23, 2010, 09:44:57 AM by Lee Mac »
alanjt
« Reply #6 on: December 23, 2010, 10:15:43 AM »
Well, not working on LWPolylines and sometimes on Lines is enough for me to not use it. I was curious if it was only me or you had similar results.
Dropbox
