Author Topic: Associative Dims (?)  (Read 1899 times)
PHX cadie
« on: November 29, 2010, 02:22:29 PM »
What makes some dims zing off toward Alpha Centauri?
I have always thought its an dim assiciation to something that was deleted, but not today.
Acad 2013 and XM
Back when High Tech meant you had an adjustable triangle
JCTER
Re: Associative Dims (?)
« Reply #1 on: November 29, 2010, 02:44:11 PM »
I wish I knew :(
It's been one of those things that's plagued me since I can remember using associative dims.
« Reply #2 on: November 29, 2010, 03:34:17 PM »
ever try using the TAB Key to toggle through the available snaps?
thus when the desired dimension start or end point is lit up, you will have a better change of keeping those dims from connecting to objects lying nearby in a parallel universe.
PHX cadie
« Reply #3 on: November 29, 2010, 04:10:36 PM »
add'l info
I just opened the files and zinggo   :?
Acad 2013 and XM
« Reply #4 on: November 29, 2010, 05:01:36 PM »
may I see that file?
JCTER
« Reply #5 on: November 29, 2010, 05:13:55 PM »
Just being sure... you're talking about assoc. dims that, when already placed, will magically have one or more node points shoot off into space, right?  Sometimes after something as simple as a regen, or moving unrelated objects, even.
Otherwise, I got another thread to start....  :-D
« Reply #6 on: November 29, 2010, 05:20:35 PM »
add'l info
is the object or part of the object being dimensioned part of a BLOCK?
IF Yes, is that block scaled NON uniformly?
PHX cadie
« Reply #7 on: November 29, 2010, 05:36:40 PM »
Yep
add'l info
Nope. No blocks. In this case both are from a tank (circle) to a site wall. Both in xrefs
Acad 2013 and XM
