Author Topic: Auto dimension??  (Read 1878 times)
josano
Auto dimension??
« on: November 09, 2010, 06:55:18 AM »
Friends,
Researched a number automatically scale and found nothing talking about.
I've attached a picture listed.
Is to get the points for quoting?
Has anyone read or seen anything regarding this matter.
Thank you in advance any help.
Hugs,
Josano
« Last Edit: November 09, 2010, 02:06:02 PM by josano »
kaefer
Re: Auto dimension??
« Reply #1 on: November 09, 2010, 04:23:06 PM »
http://www.theswamp.org/index.php?topic=31861.msg386487#msg386487? (thx to fixo)
josano
« Reply #2 on: November 10, 2010, 08:53:05 AM »
Kaefer,
Thanks for the help.
I have a question about this subject.
For dimension lines as i proceed?
I would pick the insertion points of lines.
P1________________P2_____________P3___
                                                    |P4_|_
Save the clicked points and generate quota.
Hugs,
Josano
« Reply #3 on: November 10, 2010, 09:38:54 PM »
You will also need to determine if the dimension is Horizontal or Vertical or Aligned and the line location ..
... this can't be done simply from a predetermined set of points.
Dimensioning is simple once these parameters are determined :)
unfortunately for programming, they are usually best determined by a rational mind.
HOWEVER ;
If you're dimensioning parametric shapes where the configuration can be predetermined you may be joyfull.
