Author Topic: Publish Using DWG to PDF.pc3 AND Suppress Filename Prompt  (Read 13786 times)
M-dub
« on: November 04, 2010, 10:48:04 AM »
I didn't think this was as difficult as it's proving to be.  Maybe I was using a different pdf printer.
How do I do it with DWG to PDF?  Anyone know?
M-dub
Re: Publish Using DWG to PDF.pc3 AND Suppress Filename Prompt
« Reply #1 on: November 04, 2010, 11:14:37 AM »
Found it.   :loco:
In the Publish window, hit Publish Options... button and the first option (Default output location (DWG and plot-to-file)) is the one.
mary
« Reply #2 on: April 21, 2011, 09:26:14 PM »
Just saw your post and would like to share with you, that I am running AutoDWG which converts my drawings into PDF file format with easy steps, no more struggle with AutoCAD, I downloaded it from here: http://www.autodwg.com/PDF/
« Reply #3 on: April 21, 2011, 10:24:21 PM »
Does it perform hidden line removal / hidden line substitution, and if so, with the same degree of fidelity?
huiz
  • Certified Prof C3D
« Reply #4 on: April 22, 2011, 03:00:42 AM »
I thought there is also an option in AutoCAD to automatically save a pdf and/or dwf everytime you save the dwg.
« Reply #5 on: April 22, 2011, 03:47:01 AM »
Not that I know of
... and I'd have it disabled if there was :)
« Reply #6 on: April 22, 2011, 04:05:02 AM »
Mike,
attached is what I do :
This is intended to run from a toolbar button per drawing, not through publisher :)
Note that I haven't modified the code, so you may want to.
I extract the revision number from the border and append it to the base file name.
The PlotConfigurations are deleted and replaced from a template drawing ...  not critical
A folder is made under the Drawing Folder
The PDF is created there.
;;; CodeHimBelonga kdub@theSwamp
;;; (c:DWGToPDF_A1)
(defun C:DWGToPDF_A1 (/ old-expert rev_value PDFPath dwgname PDFName)
  (DeleteAllPlotConfigurations)
  (setq old-expert (getvar "EXPERT"))
  (setvar "EXPERT" 5)
;; (or (kdub:stringprintable-p (setq rev_value (_getBorderRevision)))
;;      (setq rev_value "--")
;; Workaround for forum posting
  (setq PDFPath (strcat (getvar "DWGPREFIX") "PDF\\")
        dwgname (vl-filename-base (getvar "DWGNAME"))
        PDFName (strcat PDFPath dwgname "[REV " rev_value "].PDF")
  (vl-mkdir PDFPath)
  (if (and (vl-cmdf "-psetupin"
                    "C:/kdub_SteelTools/BLOCKS/_PLOT_Template_2011.DWG"
           (vl-cmdf "-plot"       "no"          "Model"       "DWGToPDF_A1"
                    "DWG To PDF.pc3"            PDFName       "No"
                    "yes"
    (princ (strcat "PDF File Created: " PDFName))
    (princ "Failed to create PDF File ")
  (setvar "EXPERT" old-expert)
(defun DeleteAllPlotConfigurations ()
  (vlax-for ps (vla-get-plotconfigurations
    (vla-delete ps)
« Last Edit: April 22, 2011, 04:10:45 AM by Kerry »
« Reply #7 on: April 22, 2011, 05:22:17 AM »
Would Automatic Publish and set for Save work?
« Last Edit: April 22, 2011, 06:46:19 AM by Jeff H »
huiz
« Reply #8 on: April 22, 2011, 07:13:43 AM »
Not that I know of
That 's what I was talking about. Automatic publish will save a PDF each time you save the drawing.
I have disabled it but I can imagine other people like the option.
Krushert
  • FREE BEER Tomorrow!!
« Reply #9 on: April 22, 2011, 08:34:02 AM »
Not that I know of
Thanks for letting me know about that one.  And Yes I have disabled it for my users.   :evil:
rkmcswain
« Reply #10 on: April 22, 2011, 08:59:08 AM »
...and if you use Sheet Set Manager, you can print to any output format including PDF without any prompts.
Johnvictor
« Reply #11 on: December 19, 2013, 08:40:49 AM »
I would like to suggest you goggling DWG to PDF online converter so you'll get lot of sites and check the ratings of the sites. According to ratings use one good quality sites, where you'll get the format of DWG to PDF.
