Author Topic: how do I add a variable to the windows clipboard?  (Read 15036 times)
Re: how do I add a variable to the windows clipboard?
« Reply #15 on: December 07, 2015, 04:02:06 PM »
Why use any library? To leverage the expertise and efforts of others to increase productivity and efficiency. I've no reservations nor shame recommending Dale's work to others; none. If a "casual programmer" can't learn how to fix code thru discussion forums and their own dogged determination and ingenuity then they shouldn't be writing code projects or companies rely upon.
ymg
« Reply #16 on: December 07, 2015, 04:42:59 PM »
Another option is Gille Chanteau's "LispExtension" which can be downloaded from: gileCAD
Adds the following command to Autolisp:
  • gc-Brep
  • gc-CopyToClipboard
  • gc-TextFromClipboard
  • gc-GetFileDlg
  • gc-GetFolderDlg
  • gc-InputBox
  • gc-MessageBox
  • gc-GetStrippedMtextString
  • gc-VpFreeze
  • gc-VpLayerOverride
  • gc-VpLayerRemoveAll
  • gc-VpThaw
  • gc-VpThawAll
  • gc-XlRead
  • gc-XlWrite
ymg
guitarguy1685
  • Mosquito
« Reply #17 on: May 24, 2017, 11:49:52 AM »
Just download DOSLIb from www.mcneel.com and use the dos_clipboard function.
I downloaded this library.  So to be sure, I would need to install this on everyone's computer.  I read the install notes and I guess I can set it up in the startup file.
guitarguy1685
  • Mosquito
« Reply #18 on: May 24, 2017, 12:06:52 PM »
[/code]
;;  MP
(defun _GetClipBoardText( / htmlfile result )
    (setq result
        (vlax-invoke
            (vlax-get
                (vlax-get (setq htmlfile (vlax-create-object "htmlfile")) 'ParentWindow)
               'ClipBoardData
           'GetData "Text")
    (vlax-release-object htmlfile)
    result
Be sure not to get a pie in your face :wink:
LM you're everywhere! Bless your soul.  Anyways what's the purpose the 2nd code? It just returns the text from clipboard.  Would this be to us internally in another lisp?
« Reply #19 on: May 24, 2017, 01:11:20 PM »
For example, if a program is perhaps expecting the user to copy data to the clipboard from another application, the function can then obtain such data for use in the program.
