Author Topic: Strange Printing Related Crash  (Read 16553 times)
Matt__W
  • I like my water diluted.
Re: Strange Printing Related Crash
« Reply #15 on: November 02, 2010, 03:29:50 PM »
PEBKAC??
Autodesk Expert Elite
Rob...
« Reply #16 on: November 02, 2010, 03:30:30 PM »
How about blank entities?
CAD Tech
M-dub
« Reply #17 on: November 02, 2010, 03:31:43 PM »
PEBKAC??
Daaaaaaaahhhhh I reckon not
M-dub
« Reply #18 on: November 02, 2010, 03:34:44 PM »
Not that I know of.
The attached drawing is one that was giving me problems.  I've erased everything from it, purged all and simply added a rectangle so there'd be SOMETHING there.
I still get the problem with this dwg file.
Anyone see anything?  Co-workers do not have the same issue as I'm having.
Rob...
« Reply #19 on: November 02, 2010, 03:38:15 PM »
Could not recreate problem.
CAD Tech
Matt__W
« Reply #20 on: November 02, 2010, 03:39:06 PM »
M-dub
« Reply #21 on: November 02, 2010, 03:40:20 PM »
I didn't really think you (or anyone else for that matter) would be able to.
« Reply #22 on: November 02, 2010, 06:24:15 PM »
I had a problem I am trying to remember and it seems it was similiar, but it boiled down to a setting in Adobe Acrobat 9 Pro extended. Do you have that installed?
« Reply #23 on: November 02, 2010, 08:33:43 PM »
I have opened the file.
I have created and set a named page setup
I set it current
I plot
At prompt for file name I create Attached file
There is NO error
In discussion with other coffee been chewing string theorists; it is agreed
your drawing is infected with a number of fractional dimensional objects
that are shifting between UCS on you during the plot command
and if not for the low power output of your CPU
you would now be sitting right in the middle of a black hole
due to the number of interdimensional collisions that are taking place
this could explain the disappearance of the other users reporting
this same error, it's possible they were running 600 watts or better
for their power supply
it is suggested that you INSERT one of the afflicted drawings as a block
into a drawing from a template that you know was made entirely in this dimension
then explode that block; this should rid you of the interdimensional objects you are unable to print
« Last Edit: November 04, 2010, 10:17:31 AM by Anti Quark »
« Reply #24 on: November 02, 2010, 09:42:15 PM »
Have you tried unistalling it. I had a problem a couple of weeks ago where it would freeze almost everytime I tried opening, saving, etc...... anything where a file dialog box poped up  and had to shut down computer.
I could repair and reinstall and that would not fix it. I tried to unistall it and failed.
So I ran Windows Install Clean-Up on it deleted the main folder and it has worked great.
Of course I re-installed it.
drizzt
« Reply #25 on: November 04, 2010, 10:10:49 AM »
If this is happening on all printers/plotters and not just pdf, and only on print preview.... seems like a video card problem, but I don't really know.
M-dub
« Reply #26 on: November 04, 2010, 10:23:06 AM »
No, it's not just PDF... it's happening regardless of which printer I have selected... and yes, it's only on certain drawings and only when I do a preview.  If I print one of those drawings without doing a preview (or trying to publish them), they work fine.  Definitely a strange issue.
