Author Topic: XML to InRoads ALG? Anyone??  (Read 11769 times)
kevinh
« on: November 01, 2010, 12:00:01 PM »
I have posted this in the past but now the job is drawing to a close and we need to get the required output to give to the client.
I have a centerline alignment created within Civil3D and have exported the data to a LandXML v1.2 file.
Can this alignment file be imported into Bently/InRoads and then have InRoads export the alignment data file into an .ALG format?
Any help someone could give would be greatly appreciated.
Thanks,
Kevin
Matt__W
  • I like my water diluted.
Re: XML to InRoads ALG? Anyone??
« Reply #1 on: November 01, 2010, 12:07:00 PM »
I believe InRoads can read LandXML data and the ALG file comes from InRoads so there shouldn't be any issues.  I don't have InRoads so I can't verify this will in fact work correctly.
Autodesk Expert Elite
kevinh
« Reply #2 on: November 01, 2010, 12:09:44 PM »
That is the same thing I have gathered but we had a company we frequently work with give it a try and they were unsuccessful.  I don't know anything about Bently/InRoads to know if it is a program error, user error, file error?
« Reply #3 on: November 01, 2010, 12:31:51 PM »
trying to find the right resource...my understanding is that one will be requird to edit the header of the LandXML file to import it into Bentley...fingers pointing in both directions about whom violated what part of the 'standard'
looks like you need to use the lowest vesrion number....during export
and some other settings during import....give this a peep, and have your peeps pee it too     ;-)
http://www.youtube.com/watch?v=uLPW6y0Wmes&feature=player_embedded
« Last Edit: November 01, 2010, 12:37:48 PM by Anti Quark »
kevinh
« Reply #4 on: November 01, 2010, 12:39:00 PM »
Any idea on what part of the header?
I don't understand why this is so difficult!!  I guess XML is just not as universal as it may seem.
« Reply #5 on: November 01, 2010, 12:41:14 PM »
ok..perhaps it was the other way   and I know this isn't your vesrion....so it should be OK...
however there is history....http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240778&id=6453995&siteID=123112
still researching
« Reply #6 on: November 01, 2010, 12:44:53 PM »
ok..there also seems to be file size limitations...
so you may NEED to export out the design information into logical chunks and not the entire design file as one....
At this time, there are still limitations when transferring large amounts of data.  Only export essential data.
http://www.nh.gov/dot/cadd/mx/landxml2mx.htm
kevinh
« Reply #7 on: November 01, 2010, 02:21:34 PM »
The only thing contained within the XML file is just the Horizontal Alignment Data.  File size is only 5kb.
« Reply #8 on: November 01, 2010, 02:31:36 PM »
has the other party sent you images of the ERROR message(s) and or the results of the transfer if any?
did they watch the video? yet?   ;-)
kevinh
« Reply #9 on: November 01, 2010, 02:33:59 PM »
I found out that they are using Geopak V8 and not InRoads.  Apparently there is a difference.
« Reply #10 on: November 01, 2010, 02:40:10 PM »
OK,
I think we have the ROOT cause of this issue identified here:
When you create an InRoads horizontal alignment, the application automatically assigns it a Global Unique Identifier, or GUID. This internal tag helps to distinguish alignments as they are used in profiles, cross sections and the Roadway Designer.
When geometry data is developed in CAiCE and imported into an existing InRoads geometry project using the LandXML translator, the XML file does not include any identification for a specific horizontal alignment. Consequently, the alignment that includes updated CAiCE data is displayed in red in the Roadway Designer, resulting in an error in the InRoads Roadway Designer.
 found here http://www.wsdot.wa.gov/publications/fulltext/design/cae/TechNotesIR/InRoads-GUIDforCAiCEtoInRoadsGeometry.pdf
it is possible that the same issue is at play here as C3D IS the Spawn of CAiCE...
now to figure out where or how to add a valid GUID to that alignment XML file, hmmmm
or where we could get that app  C:\cae_rsc\common\AddingGUID\ AddingGUID.exe
kevinh
« Reply #11 on: November 01, 2010, 05:50:34 PM »
Wonder if InRoads has a 30 day free trial?  I suppose I would have to have a Microstation free trial as well. :(
Dinosaur
« Reply #12 on: November 01, 2010, 06:04:54 PM »
I don't think there is an evaluation copy available for any of the Bentley offerings.
ChristopherF
« Reply #13 on: November 02, 2010, 06:24:45 PM »
Bentley is offering the out of work this: http://www.bentley.com/en-US/Community/Academic/Be+Employable/
I've had a trial version of a Bentley software product before, I think they actually want you to talk to someone before giving it out though.
« Reply #14 on: November 02, 2010, 07:53:33 PM »
I've gotten a couple trial versions, the first took 7 months to deliver for some reason...
