Author Topic: Dynamic variable name in action_tile  (Read 3627 times)
pBe
« on: October 24, 2010, 09:10:17 AM »
Why cant i create a dynamic variable inside an action_tile line?
(defun Get_Folder ()
   (setq sObj (vla-getInterfaceObject
                 (vlax-get-acad-object)"Shell.Application")
         cFold(vlax-invoke-method sObj 'BrowseForFolder 0 "Select Folder for Layer Files" 0))
(vlax-release-object sObj)
(setq fObj(vlax-get-property cFold 'Self)
             oVal (vlax-get-property fObj 'Path))
  (setq ftl (vl-directory-files oval "*.dwg"))
(foreach sto ftl
  (setq fto (strcat oval "\\" sto) ftl_ ftl)
;(takbo fto)
(vlax-release-object cFold)
       (vlax-release-object fObj)
(defun c:GD2 ()
            [color=blue](setq Dsc_l '("CVL_" "ARCHL_" "STCL_" "ELCTL_" "MECH_" "PLMBG_" "GENR_"))[/color] ;result from another routine
   (setq cs_dcl (load_dialog "Cover_tbed.DCL"))
(if (not (new_dialog "Drw_index" cs_dcl))
 (exit)
        (start_list "DW_LST")
   (mapcar 'add_list ftl_)
     (end_list)
   (foreach md_ Dsc_l
(mode_tile (strcat md_ "C") 1))
;(action_tile "Remove_" "(setq Nt_rl (get_tile \"DW_LST\") itm 0)")
(foreach ad_str Dsc_l
[color=red];   (setq &# (vl-position ad_str Dsc_l))[/color]
(action_tile [color=blue]ad_str[/color]  (vl-prin1-to-string
(quote
   (setq Ds_rl (get_tile "DW_LST") Ad_ls nil tmp_l nil)
   (while (/= Ds_rl "")
   (setq Ad_ls (cons (atoi Ds_rl) Ad_ls)
   Ds_rl (vl-string-left-trim (strcat " "(itoa (atoi Ds_rl))) Ds_rl))
;(ds_tm Ad_ls)
(foreach & Ad_ls
(setq tmp_l (cons (nth & ftl_) tmp_l))
  (setq ftl_ (vl-remove (nth & ftl_) ftl_)))
(start_list "DW_LST")(mapcar 'add_list ftl_)(end_list)
(set (setq cc (read (strcat [color=blue]$key[/color] "ls"))) tmp_l)[color=blue](mode_tile $key 1)[/color]
(mode_tile "Remove_C" 1)
   (action_tile "Remove_" (vl-prin1-to-string
(quote
   (setq Nt_rl (get_tile "DW_LST") rm_ls nil)
   (while (/= Nt_rl "")
   (setq rm_ls (cons (atoi Nt_rl) rm_ls)
   Nt_rl (vl-string-left-trim (strcat " "(itoa (atoi Nt_rl))) Nt_rl))
(foreach & rm_ls
     (setq ftl_ (vl-remove (nth & ftl_) ftl_)))(set_tile "Remove_C" (itoa (length rm_ls)))
   (action_tile "accept" "(done_dialog 1)")
   (action_tile "cancel" "(done_dialog 0)")
(start_dialog)
   (unload_dialog cs_dcl)
running the routine only give me the last variable name on my list.. and the  rest is nil
what do you guys think is wrong?
Edit: silly me .forgot to paste the whole routine  :-P
Update DCL: Lee Mac Edition
Update Code to include $key
Thanks guys
« Last Edit: October 25, 2010, 03:05:27 AM by pBe »
Re: Dynamic variable name in action_tile
« Reply #1 on: October 24, 2010, 10:02:59 AM »
Welcome to theSwamp pBe  :-)
Slightly outside the scope of your question, but you could perhaps simplify your DCL slightly to something like this:
ed2 : edit_box { edit_limit = 2; edit_width = 2; }
bta : button   { label = "Add to -->"; }
btr : button   { label = "Remove -->"; }
Drw_index : dialog { label = "Drawing index"; spacer;
  : row {
    : boxed_column { label = "Drawing List";
      : list_box { key = "DW_LST"; multiple_select = true; width = 40; height = 20; } spacer ;
    : boxed_column {
      : bta { key = "CVL_"  ; }
      : bta { key = "ARCHL_"; }
      : bta { key = "STCL_" ; }
      : bta { key = "ELCTL_"; }
      : bta { key = "MECH_" ; }
      : bta { key = "PLMBG_"; }
      : bta { key = "GENR_" ; }
      : btr { key = "Remove_"; }
      spacer;
    : boxed_column { label = "Discipline";
      : ed2 { label = "Civil";          key = "CVL_C";   }
      : ed2 { label = "Architectural";  key = "ARCHL_C"; }
      : ed2 { label = "Structural";     key = "STCL_C";  }
      : ed2 { label = "Electrical";     key = "ELCTL_C"; }
      : ed2 { label = "Mechanical";     key = "MECH_C";  }
      : ed2 { label = "Plumbing";       key = "PLMBG_C"; }
      : ed2 { label = "General";        key = "GENR_C";  }
      : ed2 { label = "Remove" ;        key = "Remove_C";}
      spacer;
  spacer; ok_cancel;
pBe
« Reply #2 on: October 24, 2010, 10:24:22 AM »
Like I said... a mile long.. cheese and rice Lee i never knew you can do that with DCL.... for every call to any of that lines will definitely shorten it...
MILE LOOOOOOOONG               little by little i'm learning.....  :-D ........is there anything in Lisp that you dont know?  :lol:
Thanks Lee
« Reply #3 on: October 24, 2010, 10:28:24 AM »
Don't worry, there's plenty I don't know..
roy_043
  • BricsCAD 18
« Reply #4 on: October 24, 2010, 10:50:53 AM »
@ pBe: Dsc_l is not defined. I don't know if that is the problem but I can't test that without Dsc_l.
roy_043
  • BricsCAD 18
« Reply #5 on: October 24, 2010, 11:25:06 AM »
Perhaps change this:
(set (setq cc (read (strcat (nth &# Dsc_l) "ls"))) tmp_l)To:
(set (setq cc (read (strcat $key "ls"))) tmp_l)
If this solves it, the problem is related to the use of (quote).
Tip:
Change this:
    (action_tile (nth &# Dsc_l) (vl-prin1-to-string
To:
    (action_tile ad_str (vl-prin1-to-string
:wink:
pBe
« Reply #6 on: October 24, 2010, 11:25:22 PM »
(set (setq cc (read (strcat [color=red]$key[/color] "ls"))) tmp_l)
Thats the one...
I did it this  way because i thought the problem lies with the quote
it was originally like what you wrote there...
but quote reads the variable ad_str differently so i throw in a call to a list...
but then.... still the same result.. so what i did is separate the routine into two... which makes the codes longer..
(action_tile "CVL_" "(setq ds_pst 0)(ds_tm ds_pst)(mode_tile \"CVL_\" 1)").....
(defun ds_tm (ds_pst / Ds_rl Ad_ls tmp_l)
(foreach & Ad_ls
  (set (setq cc (read (strcat (nth ds_pst Dsc_l) "ls"))) tmp_l)
Not good.... the codes are just too long
so now you came up with the $key ....  that did the trick
thanks buddy
btw here's the missing variable Dsc_l
Thanks Lee for the DCL pattern...
good catch roy_043
first post updated
« Last Edit: October 25, 2010, 03:10:39 AM by pBe »
