Author Topic: Need help understanding the help  (Read 12393 times)
« on: October 12, 2010, 06:03:42 PM »
So here is the section I'm referring to
Quote from: Online Dxf help
420-427
32-bit integer value. When used with True Color; a 32-bit integer representing a 24-bit color
value. The high-order byte (8 bits) is 0, the low-order byte an unsigned char holding the Blue
value (0-255), then the Green value, and the next-to-high order byte is the Red Value. Convering
this integer value to hexadecimal yields the following bit mask: 0x00RRGGBB. For example, a
true color with Red==200, Green==100 and Blue==50 is 0x00C86432, and in DXF, in decimal,
13132850
Found here [ http://images.autodesk.com/adsk/files/acad_dxf0.pdf ]
What I'm trying to see is what is the viewport override color for a layer.  I can find what I'm looking for ( at least I think it's what I'm looking for ) within the extension dictionary of a layer.  This code is just for layer 0, but you can see what I'm getting at.
(defun c:Test ( / Data )
    (setq Data (entget (tblobjname "layer" "0")))
    ;(setq Data (entget (cdr (assoc 360 Data))))
    (setq Data (dictsearch (cdr (assoc 360 Data)) "ADSK_XREC_LAYER_COLOR_OVR"))
    (while (setq Data (member '(102 . "{ADSK_LYR_COLOR_OVERRIDE") Data))
        (prompt (strcat "\n Viewport handle: " (cdr (assoc 5 (entget (cdr (assoc 335 Data))))) "  Color code: " (rtos (cdr (assoc 420 Data)) 2 0)))
        (if (equal (car (cadddr Data)) 430)
            (princ (strcat "  Color book: " (cdr (cadddr Data))))
        (setq Data (cdr Data))
This is what prints out when I have it set to the true color value that is listed in the help, r = 200 g =100 b = 50
 Viewport handle: 112  Color code: -1027054542
As you can see it doesn't match what the help file says.  So I'm wondering how to get from one to the other?  It seems like all Acad colors start with ' -10234 ', with color 1 ending with ' 10175 ' and color 255 ending with ' 09921 '.
Re: Need help understanding the help
« Reply #1 on: October 12, 2010, 06:31:01 PM »
That's pretty weird, now I'm curious too...
FYI, same result using VL:
(defun c:TestVL ( / xRec Typ Val )
    (not
      (vl-catch-all-error-p
        (setq xRec
          (vl-catch-all-apply 'vla-item
            (list
              (vla-getExtensionDictionary
                (vla-item
                  (vla-get-layers
                    (vla-get-ActiveDocument
                      (vlax-get-acad-object)
                  "0"
      (vla-getXrecordData xRec 'typ 'val)
      (print
        (apply 'mapcar
          (cons 'cons
            (mapcar 'VariantValue (list typ val))
(defun VariantValue ( value )
    ( (eq 'variant (type value))
      (VariantValue (vlax-variant-value value))
    ( (eq 'safearray (type value))
      (mapcar 'VariantValue (vlax-safearray->list value))
    ( value )
« Reply #2 on: October 12, 2010, 09:26:22 PM »
* Se7en racks brain...
I think i remember reading something about this a few years back when the true color thing started showing up. I remember the author was stumped about the formula or something but found something that worked. I'll do some searching and get back to ya.
« Reply #3 on: October 12, 2010, 09:37:55 PM »
Found this right away, which looks promising, but i haven't looked further then to see it had SOME conversion functions.
http://www.jtbworld.com/lisp/DisplayColorProperties.htm
« Reply #4 on: October 12, 2010, 10:00:59 PM »
No knowledge of true color but did find this in my collection of stuff.
Adding the ability to select True Colors to your LISP programs
If you take a look at the help files for both AutoCAD 2004 and 2005 you find the
old function ACAD_COLORDLG listed for AutoLISP. However, the ACAD_COLORDLG
function doesn't support True Colors in AutoCAD though. So was it over looked,
is it missing... really it is just undocumented. The function you need in your
code if you want to all the user to select True Colors is ACAD_TRUECOLORDLG.
Since the function is undocumented it took a little while to exactly figure out
the syntax for this function a year ago. Below is what I know of the function
itself and its companion command to select True Colors at the command line.
Dialog Box
Syntax: (acad_truecolordlg color [allowbylayer])
Example:
(acad_truecolordlg 137 nil)
((62 . 137))
Alternative to use True color:
(acad_truecolordlg (cons 420 2594))
Alternative to use Color Book color:
(acad_truecolordlg (cons 430 "PANTONE(R) a & i-cotton$PANTONE 11-4800TC"))
Command Line
Syntax: (acad_truecolorcli color [allowbylayer] [alternatePrompt])
Example:
(acad_truecolorcli 137)
New Color [Truecolor/COlorbook] <137>:
((62 . 137))
Other return values:
Returns ACI as: ((62 . 144))
Returns True Color as: ((62 . 137) (420 . 2594437))
Returns Color Book Color as:
((62 . 254) (420 . 15789027) (430 . "PANTONE(R) a & i-cotton$PANTONE 11-4800 TC"))
Sincerely,
  Lee Ambrosius
« Reply #5 on: October 13, 2010, 12:02:06 PM »
Thanks for trying guys, but both are a no go.  They both get the correct RGB color value, as the help states, but doesn't get the number that is associated with the vp overrides.  There must be another calculation that is missing.  I'll see what I can find out.
« Reply #6 on: October 13, 2010, 12:25:03 PM »
Query sent to ADN.  Lets see if they can help this time.
LE3
« Reply #7 on: October 14, 2010, 02:12:58 PM »
420-427
13132850
Did a quick test on the decimal number above and it returns (if I try to pass a negative value it simple crashes AutoCAD) do not know if helps:
unsigned long rgb = 13132850;
acutPrintf ( _T("\nR=%d G=%d B=%d"), GetRValue(rgb), GetGValue(rgb), GetBValue(rgb) );
Command: test
R=50 G=100 B=200
« Reply #8 on: October 14, 2010, 03:44:34 PM »
Here is another tid bit.
Wish I had kept better notes on where it came from.
(defun ContrastingColor(TrueColorNumber /  colorpoint cubecorners distances
maxdistance cpt)
  ;; TrueColor-split - takes a TrueColor number and returns a list of integers the form '(red green blue)
  (defun TrueColor-split ( c / )
    (list (lsh (fix c) -16)
   (lsh (lsh (fix c) 16) -24)
   (lsh (lsh (fix c) 24) -24)
  ;; TrueColor-make - takes TrueColor components (red green blue) and
creates a single TrueColor integer
  (defun TrueColor-make ( r g b /  )
    (+ (lsh (fix r) 16)
       (lsh (fix g) 8)
       (fix b)
  ;;Get rgb for supplied truecolor
  (setq
    ColorPoint (TrueColor-Split trueColorNumber)
  ;;Get distance to each of the 6 corners of the colorcube
    CubeCorners '(
    (0 0 0)
    (0 0 255)
    (0 255 0)
    (0 255 255)
    (255 0 0)
    (255 0 255)
    (255 255 255)
  ;;Get the greatest distance
    distances (mapcar '(lambda (cpt)
    (distance colorpoint cpt)
        cubecorners
    MaxDistance (apply 'max distances)
    cpt (nth (- 7 (length (member MaxDistance distances))) CubeCorners)
    )     ;end setq
  ;;Convert this corner back to a truecolor and return it
  (apply 'TrueColor-make cpt)
  )     ;end contrastingcolor
« Last Edit: October 14, 2010, 05:49:28 PM by CAB »
« Reply #9 on: October 14, 2010, 03:57:34 PM »
Thanks guys.  I'll see what I can do with the information provided.
Jeff H
« Reply #10 on: October 15, 2010, 12:51:39 AM »
************************************Edited ********************************
 The Next Post I Think Has The Answer I Produced The Help File Value By Using The True Color Tab And Entering A Rgb Value The Other Value Is From Entering A Index Number
I might have found a pattern
Sorry about the mess
The only layer in the drawing was layer "0"
There were 16 viewports in drawing
The color override was color 1 to 10 and 120 to 125
It did not go in order but the values after Command: GETLAYERVPOVERRIDE
Were generated using the GetViewportOverrides method
The values after Command: GETLAYERVPOVERRIDEEXTDIC
Were from getting the layer ExtensionDictionary and printing the DxfCode and value from the Xrecord "ADSK_XREC_LAYER_COLOR_OVR"
So as you can see
1 = -1023410175
2 = -1023410174
3 = -1023410173
125 = -1023410051
red
yellow
green
cyan
blue
10
9
8
white
magenta
124
123
122
121
120
125
(102,{ADSK_LYR_COLOR_OVERRIDE)
(335,(2129680016))
(420,-1023410175)
(102,})
(335,(2129680040))
(420,-1023410174)
(102,})
(335,(2129680072))
(420,-1023410173)
(102,})
(335,(2129680104))
(420,-1023410172)
(102,})
(335,(2129680136))
(420,-1023410171)
(102,})
(335,(2129680168))
(420,-1023410166)
(102,})
(335,(2129680200))
(420,-1023410167)
(102,})
(335,(2129680232))
(420,-1023410168)
(102,})
(335,(2129680264))
(420,-1023410169)
(102,})
(335,(2129680296))
(420,-1023410170)
(102,})
(335,(2129680392))
(420,-1023410052)
(102,})
(335,(2129680424))
(420,-1023410053)
(102,})
(335,(2129680456))
(420,-1023410054)
(102,})
(335,(2129680488))
(420,-1023410055)
(102,})
(335,(2129680520))
(420,-1023410056)
(102,})
(335,(2129680616))
(420,-1023410051)
(102,})
Here is the C# code if anyone wants to see if they get the same values
[CommandMethod("GetLayerVpOverRide")]
        public void GetLayerVpOverRide()
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction trx = db.TransactionManager.StartTransaction())
                LayerTable lyrTbl = (LayerTable)db.LayerTableId.GetObject(OpenMode.ForRead);
                LayerTableRecord lyrTblRec = (LayerTableRecord)lyrTbl["0"].GetObject(OpenMode.ForRead);
                ObjectIdCollection vpObjIds = new ObjectIdCollection();
                vpObjIds = db.GetViewports(false);
                foreach (ObjectId vpId in vpObjIds)
                    LayerViewportProperties lyrVp = lyrTblRec.GetViewportOverrides(vpId);
                    ed.WriteMessage("\n" + lyrVp.Color);
                trx.Commit();
        [CommandMethod("GetLayerVpOverRideExtDic")]
        public void GetLayerVpOverRideExtDic()
                DBDictionary extDic = (DBDictionary)trx.GetObject(lyrTblRec.ExtensionDictionary, OpenMode.ForRead, false);
                Xrecord xRec = (Xrecord)trx.GetObject(extDic.GetAt("ADSK_XREC_LAYER_COLOR_OVR"), OpenMode.ForRead, false);
                ResultBuffer reBuff = xRec.Data;
                TypedValue[] typVal = reBuff.AsArray();
                for (int i = 0; i < typVal.Length; i++ )
                    ed.WriteMessage("\n" + typVal[i].ToString());
                trx.Commit();
« Last Edit: October 15, 2010, 01:37:18 AM by Jeff H »
Jeff H
« Reply #11 on: October 15, 2010, 01:23:23 AM »
Now I think I got it
If you look at the first one the Number is what you expect from the help file.
The color can be saved by RGB or index
So when I selected the color from the Index tab I got the unexpected value
If I went to the true color tab and entered the RGB value then the RGB value was used and got the number the help file said you would.
200,100,50
255,255,0
green
cyan
blue
10
9
8
white
magenta
124
123
122
121
120
125
(335,(2129680016))
(420,-1027054542)
(102,})
(335,(2129680040))
(420,-1023410432)
(102,})
« Reply #12 on: October 15, 2010, 11:41:00 AM »
I think the case is that you can't get the true value of the color through Lisp.  There is some type of formatting, so that the numbers do not match.  It seems the help I quoted refers to the color of an entity, which it does, and the numbers come out just like the help says, but when dealing with an override, then an extra formatting takes place, and Lisp doesn't see the real value.  One could get the real values knowing how it works, but one can't set the value with lisp.  If you set the value with lisp, then it will act like no override is there, at least in my test that is what happened.
I looked at the layer with dbview, and it doesn't even show the color in the dxf code of the xrecord of the override.  I was thinking that maybe something else got added to the drawing when one assigns an override, but I didn't see anything in the dbview that shows something new is added.  I thought I saw somewhere a program that would watch the database as you work, and you can see what gets added in real time, but I wasn't able to find a program like that, so if someone knows what I'm talking about, I would like to try that next, and see if something else is getting added when assigning an override to a layer.
Jeff,
  ADN even said that the only way to get the real value is with .Net of Arx, so I guess if one wanted to get the value, then that is the way to go.  I just wanted to see if it could be done though lisp.  Thanks for providing a solution so that others who might need/want something like this, have it.
TimSpangler
  • CAD Naked!!
« Reply #13 on: October 15, 2010, 12:57:11 PM »
I'm not sure this is going to help, but,  here it is anyway.  It may shed some light
ACA 2015 - Windows 7 Pro
Jeff H
« Reply #14 on: October 15, 2010, 02:04:51 PM »
In .Net using the LayerViewportProperties.Color Property which is the override you can not get the truecolor you can get the ACI or RGB
You only get that value if the override is enterd as a RGB
The ones circled in red give you the true color you looking for in Lisp, .NET
The ones circled in blue give you the other value for Lisp, .NET
If the override is red or number 1 you get the same value,  so for R = 255, G = 0, B = 0 you would get the same answer
(420,-1023475712)    ACI# 1
(420,-1023410432)    ACI# 2
(420,-1040122112)    ACI# 3
(420,-1040121857)    ACI# 4
(420,-1040187137)    ACI# 5
(420,-1023475457)    ACI# 6
(420,-1023410177)    ACI# 7
(420,-1031765888)    ACI# 8
(420,-1027555136)    ACI# 9
(420,-1023410175)    ACI# 1
(420,-1023410174)    ACI# 2
(420,-1023410173)    ACI# 3
(420,-1023410172)    ACI# 4
(420,-1023410171)    ACI# 5
(420,-1023410170)    ACI# 6
(420,-1023410169)    ACI# 7
(420,-1023410168)    ACI# 8
(420,-1023410167)    ACI# 9
                    ed.WriteMessage("\n" + lyrVp.Color + "        " + "ACI# " + lyrVp.Color.ColorIndex);
                trx.Commit();
        public void GetLayerVpOverRideExt()
                int j = 1;
                for (int i = 2; i < typVal.Length; i = i + 4 )
                    ed.WriteMessage("\n" + typVal[i].ToString() + "    ACI# " + j);
                    if (j == 9)
                        j = 1;
                    else
                        j++;
                trx.Commit();
