Author Topic: Tell me why I did it like this. :)  (Read 19333 times)
Re: Tell me why I did it like this. :)
« Reply #30 on: September 24, 2010, 05:26:03 PM »
Smarty-pants  :lol:
« Reply #31 on: September 24, 2010, 06:58:52 PM »
`Smarty-pants'? If you a referring to my IQ, yes. If you are referring to my code, *meh* more like experience and a few books (In AutoLISP: it is better to operate on a list. In programming: it is always better to K.I.S.S.).
But you had to see something like that coming didn't you (I thought I taught you how to build a substitution model)? ...You were putting a heck of a lot of information on the Stack; you would have done better to use a recursive procedure with an iterative process instead. I would be willing to bet that my procedure would still have been faster but at least yours would have been able to handle a longer string then it currently does.
Anyways, I'm going to a friends house for food and a movie. Take care.
« Reply #32 on: September 24, 2010, 08:31:39 PM »
Lee,
This would be a far faster method (NOTE: I reformatted this function in the VLIDE for Kerry :D ).
I thank you, my therapist thanks you.  :-)
« Reply #33 on: September 24, 2010, 08:43:42 PM »
Don't know how this performs comparably but it's how I would do it:
(defun SplitByCaps ( text / lst )
    (vl-list->string
        (cons
            (car (setq lst (vl-string->list text)))
            (apply 'append
                (mapcar
                    (function (lambda (x) (if (zerop (logand 32 x)) (list 32 x) (list x))))
                    (cdr lst)
alanjt
  • Standby for witty remark...
« Reply #34 on: September 25, 2010, 12:06:05 AM »
my contribution...
(defun AT:SplitByCaps (s)
  (apply
    (function strcat)
    (cons (substr s 1 1)
          (mapcar (function (lambda (i)
                              (if (<= 65 i 90)
                                (strcat " " (chr i))
                                (chr i)
                  (cdr (vl-string->list s))
(defun AT:SplitByCaps-2 (s / l)
  (apply
    (function strcat)
    (cons (chr (car (setq l (vl-string->list s))))
                              (if (<= 65 i 90)
                                (chr i)
                  (cdr l)
slight change on MP's
(defun SplitByCaps (text / lst)
  (vl-list->string
    (cons
      (apply (function append)
             (mapcar
                           (if (<= 65 i 90)
                             (list 32 x)
                             (list x)
               (cdr lst)
« Last Edit: September 25, 2010, 12:10:03 AM by alanjt »
Dropbox
« Reply #35 on: September 25, 2010, 12:26:47 AM »
I don't think i saved the string i used to test but i just constructed it with a minor bit of code. I can see if i can get some time to do it again on Monday but i will place my bet now that MP will take first place and alanjt (third version) will be second place.
« Reply #36 on: September 25, 2010, 09:41:48 AM »
Nice coding guys (as always lol)
« Reply #37 on: September 25, 2010, 09:52:17 AM »
MP,
Nice idea, but a few other chars don't have the 32-bit set...
(SplitByCaps "This[is]a^Te_st")
>> "This [is ]a ^ Te _st"
I like your thinking however.
« Reply #38 on: September 25, 2010, 11:29:53 AM »
I hear what you're sayin' I've never seen those characters in camel cased enum names.
« Reply #39 on: September 25, 2010, 12:58:22 PM »
Fair point - I was in the 'generic function' mindset...
« Reply #40 on: September 25, 2010, 03:23:58 PM »
Good point Lee / Concede, genericized:
    (vl-list->string
        (cons
                (mapcar
                    (function (lambda (x) (if (< 64 x 91) (list 32 x) (list x))))
                    (cdr lst)
« Reply #41 on: September 25, 2010, 04:15:07 PM »
« Reply #42 on: September 27, 2010, 09:31:09 AM »
*GACK* MP, your second function was the exact same route i was planning at first too but i couldn't think of how to append it (I tried appending after the uppermost cons) and i gave up and went the easy route. Ah, its so obvious now that i seen how you applied the append I should make myself sit on the floor the rest of the day. *lol*
Anyways, i am assembling a speed test right now. I will report back when i get it done.
alanjt
« Reply #43 on: September 27, 2010, 09:37:54 AM »
  (vl-list->string
    (cons
             (mapcar
                           (if (<= 65 i 90)
                             (list 32 x)
                             (list x)
               (cdr lst)
Dropbox
« Reply #44 on: September 27, 2010, 09:45:14 AM »
alanjt, *ACK!*
