Author Topic: Rotate Text in SelectionSet  (Read 6659 times)
HasanCAD
« on: September 23, 2010, 05:58:40 AM »
I am trying to write a lisp to rotate selected objects but keep the text in the same angle
I did rotation step
But how to filter the previous selectionset to select text and mtext
Then rotate from its basepoint at opposite direction
(defun c:PlanRotate ( / AcObj ActDoc
    SelectoinPoint1 SelectoinPoint2 SelectionSet BasePoint RotationAngle RotationAngleDtr
  ;Undo
  (setq AcObj (vlax-get-Acad-Object))
  (setq ActDoc (vla-get-ActiveDocument AcObj))
  (vla-EndUndoMark ActDoc)
  (vla-StartUndoMark ActDoc)
    (and
      (setq SelectoinPoint1 (getpoint "\nSpecify first corner point: "))
      (setq SelectoinPoint2 (getcorner SelectoinPoint1 "\nSpecify second corner point: "))
      (setq SelectionSet (ssget "c" SelectoinPoint1 SelectoinPoint2))
      (setq BasePoint (getpoint "\nSpecify Base Point for Rotation: "))
      (setq RotationAngle (getangle BasePoint "\nSpecify Rotation angle: "))
      (setq RotationAngleDtr (* (/ RotationAngle pi) 180.0))
      (command "_.ROTATE" SelectionSet "" BasePoint RotationAngleDtr)
    (princ "\n No objects selected")
  ;(foreach n '(a b c) (print n))
[edit:kdub]Title was 'Help with this lisp'
« Last Edit: September 23, 2010, 06:25:14 AM by Kerry »
David Bethel
Re: Help with this lisp
« Reply #1 on: September 23, 2010, 06:17:56 AM »
I'd try something like this:
(defun c:PlanRot (/ p1 p2 ss bp ra i en ed)
  (initget 1)
  (setq p1 (getpoint "\nFirst Corner:   "))
  (initget 1)
  (setq p2 (getcorner p1 "\nOpposite Corner:  "))
  (if (not (setq ss (ssget "_C" p1 p2 '((0 . "*TEXT")))))
      (progn (alert "No Text Entities Found")
             (exit)))
  (initget 1)
  (setq bp (getpoint "\nRotation Base Point:   "))
  (initget 3)
  (setq ra (getangle "\nRotation Angle:   "))
  (command "_.ROTATE" ss "" bp (/ (* ra 180.0) pi))
  (setq i -1)
  (while (setq en (ssname ss (setq i (1+ i))))
         (setq ed (entget en))
         (entmod (subst (cons 50 (- (cdr (assoc 50 ed)) ra)) (assoc 50 ed) ed)))
  (prin1))
-David
R12 Dos - A2K
Tharwat
  • Hypersensitive
« Reply #2 on: September 23, 2010, 06:22:45 AM »
  ;Undo
  [color=red](vla-EndUndoMark ActDoc)[/color]
 [color=blue] (vla-StartUndoMark ActDoc)
[/color]
End the undomark before it's going to start.  :lmao:
otherwise it must be included with error trap functions.  :ugly:
Good luck with your long routine, although your idea should not include more than four or five lines of codes.
Tharwat
David Bethel
Re: Rotate Text in SelectionSet
« Reply #3 on: September 23, 2010, 08:11:14 AM »
After rereading your OP, I'd revise it to this:
(defun c:PlanRot (/ p1 p2 ss sst bp ra i en ed)
  (while (not ss)
         (initget 1)
         (initget 1)
         (setq ss (ssget "_C" p1 p2)))
  (initget 1)
  (initget 3)
  (and (setq i -1 sst (ssget "_C" p1 p2 '((0 . "*TEXT"))))
      (while (setq en (ssname sst (setq i (1+ i))))
             (entmod (subst (cons 50 (- (cdr (assoc 50 ed)) ra)) (assoc 50 ed) ed))))
  (prin1))
-David
R12 Dos - A2K
« Reply #4 on: September 23, 2010, 08:24:15 AM »
Following David's lead I would code it this way.
(defun c:PlanRot (/ ss bp ra i en ed)
  (prompt "\nSelect text to rotate.")
  (if (setq ss (ssget '((0 . "TEXT,MTEXT"))))
      (initget 1)
      (initget 3)
      (setq ra (getangle bp "\nRotation Angle:   "))
      (setq i -1)
  (prin1)
HasanCAD
« Reply #5 on: September 23, 2010, 09:11:27 AM »
DAVID
What I want is rotate selection set of objects then filter the text and rotate in opposite direction
This is revised
;;----------------=={ Rotate plan }==-------------------------;;
;;  rotate all selected objected with apilaty of excuding     ;;
;;  even Text Or Blocks                                       ;;
;;  Author: Hasan Mohamed Asos, 2010                          ;;
;;  Copyright © 2010 by Hasan, All Rights Reserved.           ;;
;;  Contact: HasanCAD @ TheSwamp.org,                         ;;
;;           Asos2000 @ CADTutor.net                          ;;
;;  Arguments:                                                ;;
;;  Returns:                                                  ;;
(defun c:PlanRotate (/ Slctd
     Slcnpt1 Slcnpt2 SlcnSetAll SlcnSetSlctd bspt RtnAngle Cntr
     SlcnSetSlctd SlcnSetSlctd2 SlcnSetSlctd3
  ;; © Hasan Asos 2010
      (initget 0 "Text Blocks")
(if (> 5 (strlen (getkword "\nObjects to be executed [Text/Blocks]")))
  (setq Slctd "*TEXT")
  (setq Slctd "INSERT")
    (and
      (setq Slcnpt1 (trans (getpoint "\nSpecify first corner point: ") 1 0))
      (setq Slcnpt2 (trans (getcorner Slcnpt1 "\nSpecify second corner point: ") 1 0))
      (setq SlcnSetAll (ssget "c" Slcnpt1 Slcnpt2))
      (setq SlcnSetSlctd (ssget "c" Slcnpt1 Slcnpt2 (List (cons 0 Slctd))))
      (setq bspt (trans (getpoint "\nSpecify Base Point for Rotation: ") 1 0))
      (setq RtnAngle (getangle bspt "\nSpecify Rotation angle: "))
      (setq Cntr -1)
      (command "_.ROTATE" SlcnSetAll "" bspt (* (/ RtnAngle pi) 180.0))
  (while (setq SlcnSetSlctd2 (ssname SlcnSetSlctd (setq Cntr (1+ Cntr))))
         (setq SlcnSetSlctd3 (entget SlcnSetSlctd2))
         (entmod (subst (cons 50 (- (cdr (assoc 50 SlcnSetSlctd3)) RtnAngle)) (assoc 50 SlcnSetSlctd3) SlcnSetSlctd3))
« Reply #6 on: September 23, 2010, 02:58:31 PM »
Nice code header lol  :-D Now where have I seen that before..
« Last Edit: September 23, 2010, 03:02:32 PM by Lee Mac »
« Reply #7 on: September 23, 2010, 03:13:02 PM »
  ;Undo
[/color]
Tharwat
I do this type of thing all the time.  It is in case someone left an undo mark open.
Tharwat
  • Hypersensitive
« Reply #8 on: September 23, 2010, 03:39:27 PM »
Yaaa Undoubtedly copied and pasted as he used to do with a little changes to become different somehow from the following link.
Although that new user with lisp would like to become a legendary with header but without being able to write their won
codes without a help for each line.  :-D
http://www.cadtutor.net/forum/showthread.php?48790-Upgraded-BCount
« Last Edit: September 23, 2010, 03:49:42 PM by Tharwat »
Tharwat
  • Hypersensitive
« Reply #9 on: September 23, 2010, 03:48:13 PM »
I do agree but things like this with defun error.
(defun *error* (msg)
  (vla-endundomark Mycad)
  (princ msg)
....... doing of routine ....
(vla-startundomark
(setq Mycad (vla-get-activedocument (vlax-get-acad-object)))
Tharwat
« Reply #10 on: September 23, 2010, 03:49:58 PM »
I think we discussed this recently...
My entry:
(if (= 8 (logand 8 (getvar 'UNDOCTL))) (vla-EndUndomark doc))
(vla-StartUndoMark doc)
« Reply #11 on: September 23, 2010, 04:05:55 PM »
DAVID
OH :roll:
No error checking.
  (prompt "\nSelect objects to rotate.")
  (if (setq ss (ssget))
      (initget 1)
      (initget 3)
      (setq i -1)
        (if (vl-position (cdr (assoc 0 (setq ed (entget en)))) '("TEXT" "MTEXT"))
  (prin1)
« Reply #12 on: September 23, 2010, 04:09:35 PM »
  (princ msg)
(vla-startundomark
Tharwat
That only closes your undo marking.  What about other people's code?  I use code written by others in my company, an others that they farm work out to, so I just assume one is open and close it at the beginning of my code, just to make sure.
My entry:
You're correct sir.  Good alternative to just closing the mark.
HasanCAD
« Reply #13 on: September 23, 2010, 04:20:02 PM »
eeemmmm
same is here I am wondering
Where have I seen that before ;)
alanjt
  • Standby for witty remark...
« Reply #14 on: September 23, 2010, 04:21:10 PM »
My entry:
Good stuff.
Dropbox
