Workset : Working set
for example : some objects in the Locked layer ,when we using any edit_command ,such as "move" ,"copy"... , AutoCAD will noticed user those objects can't modified because them layers were Locked.
In programming , we can check the objects in selectionset and filtered them out if the object's layer were locked ,then program avoid a bug .
but when Inplace RefEdit , my program can't check which selected objects are in Workingset or not ,it will cause the program can't work correctly.
i want to know what difference between the object in the working set and the object out the working set ?
