So .. I am just finishing up the C# Microsoft E-Learning module ($349 if you have to buy it) and it was listed as an aide for folks with an intermediate knowledge of C#
After the several hours going through the material, I must say that if I had actually purchased this class, I would have been quite upset at the learning level it provided, especially considering the cost to take it.
I am also a bit unnerved by the reference material and the associated documentation, not to mention the obvious disconnect between what the documentation says and what it actually requires you to do ...
For example ...
The material specifies that you should import the various namespaces to keep from having to type copious amounts of code ... i.e.
using System; etc ... and then the built in checker forces you to type it and identifies it as wrong if you don't.
The material says
In the OrderItemControl, create a public property named OrderProductControlName that returns a String and gets and sets the Text property of the ProductNameComboBox.
Now, knowing I am working in C# I start out with
public string OrderProductControlName
get
return ProductNameComboBox.Text;
set
ProductNameComboBox.Text = value;
Of course it looks right to me, the compiler compiles it correctly and it works ... BUT ... it is marked as wrong. WHY? you might ask ..
well, I am glad you asked .. it is because answer key says it should be coded like so:
Public Property OrderProductName() As String
Get
Return ProductNameComboBox.Text
End Get
Set(ByVal Value As String)
ProductNameComboBox.Text = Value
End Set
End Property
I am like WTF ... how in the heck did they key a VB solution to a C# course ...
And finally, the course says in the instructions:
When using a typed dataset, you can access the associated table as a property of that dataset, so instead of using
StoreSalesDataSet1.Tables["sales"]
you can use
StoreSalesDataSet1.sales
Ok, great .. except the documentation requires that you do it one way in function A and the other way in function B ... seriously, make up my mind already ... either shorthand or longhand ... pick one, I don't care which.
and the labs ... they should seriously consider improving the resolution ... 800x600 doesn't cut it when the application you are building defaults to 1024x768 and you can't even access half the controls on it ... its no wonder people can't make heads or tails out of the education they get from these things ... it is only marginally useful ... after doing a couple labs, I finally just gave up on them and figured I would finalize the course without having completed them ... there doesn't seem to be any issue for not doing them ... at least it doesn't count against you like it would in a regular classroom.
but alas, the paperwork will do wonders for those who fumble through the incoherencies ... I'm glad I'll finish it up later today ...
