Author Topic: Viewport Mirrored drawing in modelspace ...  (Read 6990 times)
Hangman
« on: July 07, 2010, 12:28:07 PM »
Has anyone ever run into a situation where your drawing in model space is reversed or mirrored when looking at it through a viewport in paper space ??
We have a rather large, complex drawing and in paper space, we have four viewports.  These viewports are mirroring the drawing.
I don't even know where to start looking for a solution to this problem other than asking you guru's here.
ANY thoughts on a possible solution are welcome and well appreciated.
Thanks.
Hangman  8)
Re: Viewport Mirrored drawing in modelspace ...
« Reply #1 on: July 07, 2010, 12:30:42 PM »
Perhaps a twist angle is set using DVIEW?
Hangman
« Reply #2 on: July 07, 2010, 12:33:39 PM »
We were thinking the same thing, so we created a new viewport and it still appeared mirrored.  Using twist will only rotate the drawing in the viewport correct ??  Or is there a selection to mirror as well ??  I've gotta go look, brb.
Hangman  8)
Rob...
« Reply #3 on: July 07, 2010, 12:35:30 PM »
How about 3d view set to bottom?
CAD Tech
« Reply #4 on: July 07, 2010, 12:37:20 PM »
We were thinking the same thing, so we created a new viewport and it still appeared mirrored....
I believe that any new viewports created on the same tab will replicate the properties of the initial viewport. Try making the viewport on a completely new tab.
I don't think DVIEW is the answer ... just throwing something out there  :-D
Hangman
« Reply #5 on: July 07, 2010, 12:44:22 PM »
That was it !!
Thank you guys for your suggestions and thoughts.
Quote from: ronjonp
I believe that any new viewports created on the same tab will replicate the properties of the initial view port. Try making the view port on a completely new tab.
Ron, that is most interesting.  I hadn't thought of, nor looked into that before, but it could be a solution to another minor issued we've had in the office.  Thanks.
Hangman  8)
« Reply #6 on: July 07, 2010, 12:46:39 PM »
That was it !!
Quote from: ronjonp
Anytime  8-)
