Author Topic: Change Double Click Action on the fly - Opinions ideas wanted  (Read 1221 times)
Rod
This Lisp allows users to change the double click action for an object type
by selecting from actions in the popmenu for that object type.
Select an object right-click Select Edit Double Click Action from the shortcut menu
The doubleclick.cui file must be in a support path folder
Dos_lib must be installed
This works by a workaround only, maybe someone could point me in the right direction for improving this to change the cuix. Or ideas. Or rewrite.
There is no error checking in this yet it is mostly a concept at this stage.
The routine assumes that you have a cmdedit submenu by default this is present
Some object popmenu names may have to be changed slightly eg. LWPline Object Menu to LWPolyline Object Menu
« Last Edit: June 24, 2010, 02:09:36 AM by Rod »
"All models are wrong, some models are useful" - George Box
