Author Topic: Simple routine request  (Read 6647 times)
HasanCAD
« on: June 18, 2010, 08:12:15 AM »
Hi all
I want to select an object in all layouts then change entity for?
Example
select all viewports in all layouts
save old value of DXF code 90
add 147456 to old value
thanks for your help
Hasan
kpblc
Re: Simple routine request
« Reply #1 on: June 18, 2010, 08:32:14 AM »
You can use something like (setq selset (ssget "_X" '((0 . "VIEWPORT")))) and work with selection set.
Sorry for my English.
HasanCAD
« Reply #2 on: June 18, 2010, 03:35:43 PM »
thanks kpblc
this was my start
(defun c:vps ()
     (setq vprtslct (ssget "X" '((0 . "VIEWPORT"))))
     (foreach x vprtslct
but I lost in foreach and How to select viewport in all layouts.
PS: Whats deference between "X" and "_X"
Hasan
« Last Edit: June 18, 2010, 03:46:12 PM by HasanCAD »
kpblc
« Reply #3 on: June 18, 2010, 03:51:30 PM »
The difference is:
(ssget "X" <...>) -> will work only on english AutoCAD
(ssget "_X" <...>) -> will work on any localised version of AutoCAD (include English)
P.S. To convert selection set to list try to use code like this:
(defun conv-selset-to-list (selset / tab item)
  (repeat (setq tab  nil
                item (sslength selset)
                ) ;_ end setq
    (setq tab (cons (ssname selset (setq item (1- item))) tab))
    ) ;_ end of repeat
  ) ;_ end of defun
And then:
(setq vprtslct (ssget "_X" '((0 . "VIEWPORT"))))
(foreach (conv-selset-to-list vprtslct)
« Reply #4 on: June 18, 2010, 07:26:28 PM »
Can someone confirm that the (ssget "X" .. is affected by ' localisation ' issues
kenkrupa
« Reply #5 on: June 19, 2010, 12:03:46 PM »
Command: (ssget "X")
<Selection set: 3>
Command: globcheck
Enter new value for GLOBCHECK <0>: 1
The ssget option string must be preceded by an underscore.
Localization unfriendly ssget option "x" rejected!
kpblc
« Reply #6 on: June 19, 2010, 01:24:58 PM »
I can't find full description of system variable 'globcheck'. Could you help me please?
LE3
« Reply #7 on: June 19, 2010, 01:31:56 PM »
Here:
http://www.manusoft.com/resources/acadexposed/sysvars.html
kpblc
« Reply #8 on: June 19, 2010, 01:44:43 PM »
Thank you very much!
HasanCAD
« Reply #9 on: June 24, 2010, 03:50:17 AM »
(defun c:vps(/ dimsel)
(setq dimsel(ssget "x" '((0 . "VIEWPORT"))))
   (command "_PSELECT" "_p" "")
(PRINC)
selected all viewports in all layouts
but entmod not working with viewports
is there any solution?
« Last Edit: June 24, 2010, 03:56:35 AM by HasanCAD »
Hangman
« Reply #10 on: June 24, 2010, 02:40:52 PM »
AutoLISP Reference Guide > AutoLISP Functions > E Functions >
entmod
Modifies the definition data of an object (entity)
Restrictions on Using entmod
There are restrictions on the changes the entmod function can make:
*** You cannot use the entmod function to modify a viewport entity. ***
Sorry, no-can-do with Entmod.
Hangman  8)
Hangman
« Reply #11 on: June 24, 2010, 02:45:33 PM »
Here's an excerpt taken from CAB's 'VPLockAll',
(if (= (vla-get-objectname ent) "AcDbViewport")
            (vla-put-displaylocked ent lck)
            (vla-put-color ent clr)
            (if (setq obj (assoc 340  (entget (vlax-vla-object->ename ent))))
              (vla-put-color (vlax-ename->vla-object (cdr obj)) clr2)
          ); end progn
I know the viewport is accessed and it is locked or unlocked, and the color is changed depending on the scenario, but this is the only manner I have seen so far in modifying viewports.
Hangman  8)
HasanCAD
« Reply #12 on: July 02, 2010, 09:31:20 AM »
what about this
(defun c:vps(/ VPsel)
  (foreach x (setq VPsel(ssget "_X" '((0 . "VIEWPORT"))))
    (vla-put-displaylocked VPsel :vlax-false)
  (PRINC)
« Reply #13 on: July 02, 2010, 09:34:23 AM »
what about this
  (PRINC)
You'll have to turn your selection set into a list to perform foreach on it.
HasanCAD
« Reply #14 on: July 02, 2010, 09:40:31 AM »
Is this correct way
  (foreach x (setq VPsel (list (ssget "_X" '((0 . "VIEWPORT")))))
  (PRINC)
seems not
because not working for me
