Author Topic: How to display context ribbon  (Read 2505 times)
kenkrupa
« on: June 16, 2010, 11:17:35 AM »
When you do the MTEXT command (R2010), after picking the second corner a Text Editor ribbon is displayed.
With lisp, if you do
(initdia)(initcommandversion 2)(command "_mtext")(princ)
it works the same way.  BUT if that is part of a larger routine where it is followed by
(while (= (getvar "cmdactive") 1)(command pause))
and then other stuff, then the ribbon is not displayed.
So, what I'm looking for is a way to display that ribbon (and dismiss it afterward). Possible with lisp?
Re: How to display context ribbon
« Reply #1 on: June 16, 2010, 11:48:45 AM »
kenkrupa
« Reply #2 on: June 16, 2010, 02:17:06 PM »
Check this out.
http://www.theswamp.org/index.php?topic=30407.msg360299#msg360299
Thanks for the reply CAB, but it does not seem to be on target. That topic is about the Mtext editor. I'm talking about a Text Editor ribbon (see attached image), which is displayed whenever the Mtext command is used (except in this program situation).
dgorsman
« Reply #3 on: June 16, 2010, 02:29:21 PM »
Context depends on the selected object, so maybe its considering nothing to be selected.  Maybe a call involving (sssetfirst) or other means of keeping the mtext object selected would help?
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
kenkrupa
« Reply #4 on: June 16, 2010, 03:16:52 PM »
What? There is no mtext object yet, just the input box, when this ribbon displays.
Crank
« Reply #5 on: June 16, 2010, 03:20:38 PM »
I wonder what you're trying to do?
First: initcommandversion should only be used if you want to use a special (old) version of a command. As far as I know command versioning is only available for the commands CHAMFER, FILLET, LAYOUT, LENGTHEN, TRIM, COLOR and EXPLODE. (I know there are more versions of the MTEXT command, but you can only change it to "OLDEDITOR" and I can't imagine you want to do that)
Second:
(while (= (getvar "cmdactive") 1)(command pause))can only be usefull before or after the MTEXT command, right?
This is how I would do it:
(defun c:test (/ th DM p1 rot)
 (setq th 3.5); textsize
 (command "._undo" "_be")
 (setq DM (getvar "DYNMODE"))
 ; save layer and color here (omitted)
 ; set layer and color you want here (omitted)
 (initget 1)(setq p1 (getpoint "\nSpecify start point of text: "))
 (setq rot (getangle p1 "\nSpecify rotation angle <0>: "))
 (if (null rot) (setq rot 0.0) (setq rot (* 180.0 (/ rot pi))))
 (setvar "DYNMODE" (- 0 (abs DM))) ; Avoid problems with some graphics cards
 (setvar "MTJIGSTRING" "Example")
 (initdia) ; Dialog/ContextualTab !
 (command "._mtext" p1 "j" "TL" "r" rot "h" th "L" "E" (strcat (rtos (getvar "TSPACEFAC")) "x") pause)
 ; restore saved layer and color here (omitted)
 (setvar "DYNMODE" DM)
 (command "._undo" "_end")
huiz
  • Certified Prof C3D
« Reply #6 on: June 16, 2010, 03:46:08 PM »
Contextual ribbons are controlled by the CUI. See the CUI editor, section Ribbon, then Contextual Tab States. There are a lot of actions below it, like "arc selected" but also "Text editor in progress". You can drag and drop a tab (existing or newly created) to this and from that point the contextual tab will be shown with that action.
I think it is not possible to show a tab just when a lisp or command is active, but only when you select an object, because that is controlled by the CUI.
kenkrupa
« Reply #7 on: June 16, 2010, 08:47:09 PM »
Nope. With your code that ribbon is not displayed. What ribbon? - see image in previous post.
You may be right that it's not needed here. However, it has been found to be needed elsewhere - for mleader in particular - on some systems but not others. This is a confirmed fact, although undocumented. That's what lead me to believe it might be the case here also. But, alas, not so.
Crank
« Reply #8 on: June 17, 2010, 02:23:08 AM »
This is working for the contextual ribbon in Acad2011
So you're talking about a contextual ribbon, but you want the toolbar? In that case you should set MTEXTTOOLBAR to 1. (see help)
kenkrupa
« Reply #9 on: June 17, 2010, 11:07:25 AM »
Yes, I see that the ribbon is displayed with your code, and mine also, in 2011. But not in 2010 - they must have fixed this.
As for the toolbar, it is not necessarily wanted and would probably not be wanted IF the ribbon were displayed. I was not aware of the MTEXTTOOLBAR sysvar, so thank you for that. But it does not help. If I set it to 2 (does not display when the ribbon is on), the toolbar does not display in my routine even though the ribbon is not displayed. Apparently AutoCAD thinks the ribbon is displayed even though it is not. That's why I'm looking for a some code to force that ribbon to display, as a workaround for this release.
Thanks.
