Author Topic: Lisp to read selection set and write to xls  (Read 7904 times)
artisteroi
« on: June 07, 2010, 02:29:29 PM »
Hi everybody!
I need a lisp (or other routine) to read a group of line work get the vertex and arc data and write the info to a spreadsheet. It needs to keep a running spreadsheet so that it can be run multiple times. This is WAAAYYYY beyond my level of programming. I might get lisp to draw some stuff, but reading data and writing it to excel, not in a million years.
Attached is set of line work made of arcs and 3d polylines. I need to write the 3d poly vertexes points in space (vertex 1 = 12,32,15 ; vertex 2 = 14,38,15) and the info for the arc (center point x,y,z = 12,32,15 ; radius = 22 ; start angle 22.6875 ; end angle = 132.4375). And it needs to append this data into an excel spreadsheet in a running table.
Sound like fun? Sounds like a headache to me, but that's me. I would get my staff to do this but they all got laid off last year. Anyone wishing to rise to the challenge will have my undying graditude.
Re: Lisp to read selection set and write to xls
« Reply #1 on: June 07, 2010, 02:40:55 PM »
Getting the information:
Converting a SelectionSet to a list of VLA-Objects:
(defun ss->vla ( ss )
  (if ss
      (lambda ( i / e l )
        (while (setq e (ssname ss (setq i (1+ i))))
          (setq l (cons (vlax-ename->vla-object e) l))
        l
      -1
(ss->vla <SelectionSet>)
==>  '(<VLA-object> <VLA-object> <VLA-object> ... <VLA-object>)
Arcs:
(vlax-get <Arc Object> 'StartAngle)
(vlax-get <Arc Object> 'EndAngle)
(vlax-get <Arc Object> 'Radius)
Use rtos / angtos to convert Arc data to strings.
Polylines:
(vlax-get <Polyline Object> 'Coordinates)
==>  '(x y z x y z x y z ... x y z)
Converting Polyline Coordinates into a Points list:
(defun GroupByNum ( l n / a b )
  (while l
      (lambda ( i )
        (while (< 0 i)
          (setq a (cons (car l) a) l (cdr l) i (1- i))
        (setq b (cons (reverse a) b) a nil)
      n
  (reverse b)
(GroupByNum (vlax-get <Polyline Object> 'Coordinates) 3)
==>  '((x y z) (x y z) (x y z) ... (x y z))
Constructing Coordinate Strings from the Point data:
(defun lst->str ( lst del )
  (if (cdr lst)
    (strcat (car lst) del (lst->str (cdr lst) del))
    (car lst)
(lst->str '(x y z) ",")
==>  "x,y,z"
Writing data to Excel.
This should get you going  :-)
artisteroi
« Reply #2 on: June 07, 2010, 03:16:02 PM »
thanks Lee
I will see what I can do with this. But I am way out of my depth. Most of what you wrote, I don't even recognize. But I will take a swing at it.
« Reply #3 on: June 07, 2010, 03:30:17 PM »
Not a problem, if you get stuck at all, just ask  :-)
artisteroi
« Reply #4 on: June 08, 2010, 10:53:20 AM »
I appreciate the help you are offering but I am totally lost.
This is visual lisp code right? All the "vlax" stuff. I can't get any of that to work. I converted the first couple of lines to vanilla autolisp and manged to get the selection set but I cant get it to go any farther. I may have to use the vlax stuff but it won't run on my cad. Do I need to load some sort of enabler or something?
Here is what I got working. Thats all.
(defun c:dr (/) ;;;(defun  ss->vla ( ss )
(setq ss (ssget)) ;;;  (if ss
« Reply #5 on: June 08, 2010, 11:13:01 AM »
You will need:
at the top of the code to enable the Visual LISP functions.
« Reply #6 on: June 08, 2010, 11:17:09 AM »
GREAT post Lee, great post.
« Reply #7 on: June 08, 2010, 11:17:52 AM »
Of course, this could be done in Vanilla LISP... (well, all except the Excel part)...
Arc Data:
Radius =  DXF group 40
StartAngle = DXF group 50
EndAngle = DXF group 51
Again, you would have to use rtos / angtos to convert this data to a string
Polylines:
You can get the vertices using this recursive code:
(defun foo ( ent / p )
  (if (and (setq ent (entnext ent)) (setq p (cdr (assoc 10 (entget ent)))))
    (cons p (foo ent))
(foo <Polyline entity>)
Then again, constructing Coordinate Strings from the Point data:
  (if (cdr lst)
    (car lst)
==>  "x,y,z"
« Last Edit: June 08, 2010, 11:22:23 AM by Lee Mac »
« Reply #8 on: June 08, 2010, 11:22:56 AM »
Thanks Mark  8-)
artisteroi
« Reply #9 on: June 08, 2010, 11:24:32 AM »
can't do the excel part with vanilla huh?
So I added the vla com load part and the script is running. Will get back to you soon with a progress check.
« Reply #10 on: June 08, 2010, 11:28:52 AM »
Ok, I suppose you can do it with Vanilla, but you don't get much control. You can write to an Excel file using write-line, and tab delimited text strings.
artisteroi
« Reply #11 on: June 08, 2010, 11:50:56 AM »
This is beyond me I'm afraid. My knowledge of lisp is limited to doing animations and stuff like that. I dont think I can pull data (nothing to look at) from objects in model space.
Would you (Lee) be willing to write the code for me. I maybe able to get you re-imbursed for your time. Let me know how much you would charge and I will see what I can do.
« Reply #12 on: June 08, 2010, 12:01:33 PM »
PM'ed  :wink:
artisteroi
« Reply #13 on: June 08, 2010, 12:14:59 PM »
e-mailed
fixo
« Reply #14 on: June 09, 2010, 06:06:25 AM »
Hi everybody!
Try this code
;;local defuns
(defun group-by-num (lst num / ls ret)
  (if (= (rem (length lst) num) 0)
      (setq ls nil)
      (repeat (/ (length lst) num)
 (repeat num
   (setq ls
      (cons (car lst) ls)
  lst (cdr lst)
 (setq ret (append ret (list (reverse ls)))
       ls  nil
  ret
(defun pline_cordinates (pline_obj / verts)
  (setq verts (vlax-get pline_obj 'Coordinates)
 verts
  ((wcmatch (vlax-get pline_obj 'Objectname)
     "AcDb2dPolyline,AcDb3dPolyline"
   (group-by-num verts 3)
  ((eq (vlax-get pline_obj 'Objectname)
       "AcDbPolyline"
   (group-by-num verts 2)
  (T nil)
;;main program
(defun C:IEX (/     *error*  eang    ep      etang   fdesk   fname   obj_list
       pt      rad     sp      sset    stang   strcoords
       tmp
(defun *error* (msg)
    (if (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
        (princ (strcat "\n** Error: " msg " **")
    (if fdesk  (close fdesk)
  (if (setq sset (ssget (list (cons 0 "LINE,POLYLINE,ARC"))))
      (setq obj_list
      (mapcar 'vlax-ename->vla-object
       (vl-remove-if
         'listp
         (mapcar 'cadr (ssnamex sset))
      (setq fname (strcat (getvar "dwgprefix")
     (vl-filename-base (getvar "dwgname"))
     ".CSV"
      (setq fdesk (open fname "w"))
      (foreach obj obj_list
(setq tmp
 (cond ((and (equal "AcDbLine" (vla-get-objectname obj))
        (setq sp (vlax-get obj 'StartPoint)
       ep (vlax-get obj 'EndPoint)
        (strcat "LINE" (chr 9)
     (strcat (rtos (car sp) 2 3)
     (rtos (cadr sp) 2 3)
     (rtos (caddr sp) 2 3))
     (chr 9)
         (strcat
     (rtos (car ep) 2 3)
     (rtos (cadr ep) 2 3)
     (rtos (caddr ep) 2 3)
       ((and(equal "AcDbArc" (vla-get-objectname obj))
        (setq pt    (vlax-get obj 'Center)
       rad   (vlax-get obj 'Radius)
       stang (vlax-get obj 'StartAngle)
       eang  (vlax-get obj 'EndAngle)
        (strcat "ARC" (chr 9)
     (rtos (car pt) 2 3)
     (rtos (cadr pt) 2 3)
     (rtos (caddr pt) 2 3)
     (chr 9)
     (rtos rad 2 3)
     (chr 9)
     (rtos stang 2 3)
      (chr 9)
     (rtos eang 2 3)
       ((equal "AcDb3dPolyline" (vla-get-objectname obj))
        (setq strcoords
          (apply
     'strcat
     (mapcar
       (function (lambda (x) (strcat x (chr 9))))
       (mapcar
         (function
           (lambda (a)
      (apply
        'strcat
        (cons
          (rtos (car a) 2 3)
          (mapcar
            (function
       (lambda (i) (strcat "," (rtos i 2 3)))
            (cdr a)
         (pline_cordinates obj)
       strcoords (substr strcoords 1 (1- (strlen strcoords)))
        (strcat "3DPOLY" (chr 9) strcoords)
 ;;debug only
 (princ "\n   =>>   ")
 (princ tmp)
 (write-line tmp fdesk)
      (close fdesk)
  (*error* nil)
(prompt "\n   >>   Start command with IEX   <<")
(prin1)
~'J'~
