Author Topic: VBa  (Read 6193 times)
krampaul82
VBa
« on: June 07, 2010, 02:17:20 PM »
How do I open a .pdf file from a Visual Basic Program?
any help appreciated...
Re: VBa
« Reply #1 on: June 07, 2010, 03:18:34 PM »
Open it as open adobe to view it or open it as open it in VBA to do something with it?
Prior is something like this:
Option Explicit
Private Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hwnd As Long, ByVal lpszOp As String, ByVal lpszFile As String, ByVal lpszParams As String, ByVal lpszDir As String, ByVal FsShowCmd As Long) As Long
Public Function OpenFile(ByVal FileName As String) As Long
   OpenFile = ShellExecute(0, "Open", FileName, "", "C:\", 1)
End Function
latter isn't gonna happen without some knowledge of the PDF structure and/or a type library and/or a class for handling PDF files.
krampaul82
Re: VBa
« Reply #2 on: June 07, 2010, 03:56:05 PM »
I would like to press a command button and have it open an adobe pdf file for printing
Re: VBa
« Reply #3 on: June 07, 2010, 04:01:13 PM »
well, that will do it, just pass the file name to the function and it will open the PDF in adobe
krampaul82
Re: VBa
« Reply #4 on: June 07, 2010, 04:42:07 PM »
using your example above how would i pass the filename to this function?
(at your convienence.....)
Re: VBa
« Reply #5 on: June 07, 2010, 04:48:33 PM »
OpenFile "filenamegoeshere"
That simple
krampaul82
Re: VBa
« Reply #6 on: June 07, 2010, 04:57:56 PM »
Option Explicit
   OpenFile = ShellExecute(0, "Open", FileName, "", "C:\ALL_pdf_Cut_Sheets\Actuators\", 1)
End Function
like this?
sub file_get
OpenFile "ms8105a1008"
Re: VBa
« Reply #7 on: June 07, 2010, 05:41:56 PM »
that should do it, but you might need to include the path to the file as well. All I can suggest it to try it
krampaul82
Re: VBa
« Reply #8 on: June 08, 2010, 10:14:26 AM »
No Dice... :|
Option Explicit
End Function
like this?
sub file_get
OpenFile "C:\ALL_pdf_Cut_Sheets\Actuators\ms8105a1008"
Re: VBa
« Reply #9 on: June 08, 2010, 11:22:03 AM »
you need to include the file extension ..
Try this:
Option Explicit
End Function
Sub file_get()
   OpenFile "C:\ALL_pdf_Cut_Sheets\Actuators\ms8105a1008.pdf"
In your form, make the action of the click event for your button call file_get
krampaul82
Re: VBa
« Reply #10 on: June 09, 2010, 09:54:46 AM »
Suh-Wheet that was it. Thanks for sticking with me Keith.
Re: VBa
« Reply #11 on: June 09, 2010, 09:56:12 AM »
no problem
jgr
Re: VBa
« Reply #12 on: June 18, 2010, 08:02:52 PM »
For print Try with verb "print" (parameter lpOperation)
ShellExecute(0, "print",....
