Now I have to take issue with one thing posted earlier, because it is true only to a point .. this is merely to clarify the issue ... If your drawing units are inches (most common architectural work) and you draw a 400 mile square, that isn't 400 units ... that is 400*5280*12 or 25344000 units .... this is why some people (namely architypes and surveyors) have issue with using one anothers drawings ... scale up the drawing by 12 .. scale down the drawing by 12 .. adnauseum
Quote from: Keith™ on May 28, 2010, 10:54:04 AMNow I have to take issue with one thing posted earlier, because it is true only to a point .. this is merely to clarify the issue ... If your drawing units are inches (most common architectural work) and you draw a 400 mile square, that isn't 400 units ... that is 400*5280*12 or 25344000 units .... this is why some people (namely architypes and surveyors) have issue with using one anothers drawings ... scale up the drawing by 12 .. scale down the drawing by 12 .. adnauseumInternational feet or US Survey feet?
