you might want to try NOT getting the additional profile properties from your roadway grid...and instead try the wizard and verify the settings here for profile styles...and your grid labels can be placed to the outside...you will need to widen your profile view frame in your template slightly....
IGNORE the the band set...that was a red herring...see above for the 'solution'
your profile vies for the sheets are being assign styles...examine the settings for Intermediate, and Last View that are being assigned to your Main Road profile view....
When you tell the app to use that profile for a source of settings...one needs to be sure that it has the settings one really wants assigned to it.
You may need or want to set up different Inetermediate, and Last View styles to push the text outside the profile view grid....
