Author Topic: Would you like my Vim lisp syntax file  (Read 10560 times)
« on: May 11, 2010, 12:32:05 PM »
Would anyone be interested in my Lisp Syntax file? Ive tweaked the default Lisp syntax file to include all the VL and AL functions i could find, ive also done some fixing to the ATOMS, COMMENTS, and LISTS sections of the file.
I know there are not that many Vim users amongst us (Mark and I are most likely the only ones) but i would imagine that those of you using other text editors besides Vim could use the 1800 or so function names i gathered up and added to the file.
If there is interest I'll post it.
P.S. Please don't just say "yeah post it". Please check your syntax file, if you don't have ~1800 functions or so then i will post it otherwise i wont waste our time (by not spending the time removing my custom stuff and or re-formatting or etc.).
Krushert
  • FREE BEER Tomorrow!!
Re: Would you like my Vim lisp syntax file
« Reply #1 on: May 11, 2010, 12:42:24 PM »
Ahhhh I don't want your stinkin Vim lisp syntax file.  So I really wish you WOULD NOT post it.  :lol: :evil:
I don't know why I felt like saying that but I felt like I had to say it, so I said it. But seriously I do not want that file.  Really I do not want it.
gskelly
« Reply #2 on: May 11, 2010, 01:14:06 PM »
Sure, if it is not an effort... I use vim occasionally but not enough to be worth much effort on your part cleaning up.
Bricscad v12
« Reply #3 on: May 11, 2010, 01:16:29 PM »
There wouldnt be much effort at all if you are using Vim (All i would have to do is remove one section that i added for a project or two - 30seconds?).
« Reply #4 on: May 11, 2010, 04:25:50 PM »
Here is the lisp.vim file
t-bear
« Reply #5 on: May 11, 2010, 04:48:00 PM »
Dag-nab-it Se7en, you were asked not to post that stuff!  Now folks are gonna haffta USE it!  Trouble-maker!  S**t-stirrer!  Sheeeesh! :pissed: :realmad:
« Reply #6 on: May 11, 2010, 10:52:27 PM »
*gack*  ...bear, Ive known you for a LONG time (before thesamp.org. wow, even before bigswamp.org.)  ...Is it bad that now i kinda cant wait for you to start fishing more?
:D
Gonna miss ya.
HasanCAD
« Reply #7 on: May 12, 2010, 11:16:33 AM »
Hi Se7en
Could I ask, what is this file?
« Reply #8 on: May 12, 2010, 12:45:49 PM »
Hi Se7en
Do you know how in the VLIDE a built in command function name turns yellow? Basiclly, this file is for that (and other things) in my text editor Vim.
Just so that you can have something to see for yourself, here is a "screenshot" of my editor. This is how I see a lisp file (the blue line is a folded up region of code--a whole sub function folded up so its out of my way-).
I program (in Lisp and C++) in my editor. When I work on a lisp project and I have to debug or test code I can open the VLIDE to a completed ready to test lisp file.
HasanCAD
« Reply #9 on: May 12, 2010, 07:28:48 PM »
Sound is good
let me give a try
GDF
« Reply #10 on: May 14, 2010, 10:17:48 AM »
Thank you for the list of vla- functions. I have already made use of it.
There is no function vla-get-font and vla-put-font that I read from another forum.
(defun c:test ();does not work
  (vlax-for objTextStyle (vla-get-textstyles
                          (vla-get-activedocument
                           (vlax-get-acad-object)))
   (if (= (vla-get-font objTextStyle) "ARIAL.TTF")
    (vla-put-font objTextStyle "MULTPLNL.shx")
(defun c:test ()
   (if (= (vla-get-fontfile objTextStyle) "ARIAL.TTF")
    (vla-put-fontfile objTextStyle "MULTPLNL.shx")
[edit.kdub:codeTagsAdded]
« Last Edit: May 14, 2010, 10:39:12 AM by Kerry Brown »
« Reply #11 on: May 14, 2010, 10:57:47 AM »
I dont understand.
error: no function definition: VLA-GET-FONT
« Reply #12 on: May 14, 2010, 11:16:06 AM »
looks good! Thanks for sharing John.
« Reply #13 on: May 14, 2010, 11:26:04 AM »
There are
vla-getfont
vla-setfont
Perhaps thats the confusion.  :wink:
« Reply #14 on: May 14, 2010, 11:32:46 AM »
There are
vla-getfont
vla-setfont
Those are in the syntax file.  ?
