Author Topic: Visual DCL to achieve in AutoLisp  (Read 5999 times)
nonsmall
« on: April 08, 2010, 10:15:07 PM »
 8-) Hello everyone !
nonsmall works: Visual DCL dialog box automatically connect program.
The program written entirely by AutoLisp. TKS
« Last Edit: April 20, 2010, 02:51:53 AM by nonsmall »
nonsmall
Re: Visual DCL to achieve in AutoLisp
« Reply #1 on: April 08, 2010, 10:18:13 PM »
show
nonsmall
« Reply #2 on: April 08, 2010, 10:24:21 PM »
This code can be all generated automatically by the Visual DCL procedures
nonsmall
« Reply #3 on: April 08, 2010, 10:26:36 PM »
DCL in Lisp
LE3
« Reply #4 on: April 08, 2010, 10:27:42 PM »
don't do any dcl anymore.... looks good.
are you including the application that generates the dcl code?
nonsmall
« Reply #5 on: April 09, 2010, 08:15:30 AM »
NO, the application is excluded.
not only the whole dcl code,but also the initialized dcl lisp source code is generated by program, automatically.
The above lisp code & dcl code you can download, are all written by the program, no letter by me.
« Last Edit: April 09, 2010, 08:33:38 AM by nonsmall »
LE3
« Reply #6 on: April 09, 2010, 10:07:28 AM »
I see, you are showing a demo then.
Aerdvark
« Reply #7 on: April 10, 2010, 01:44:32 AM »
Maybe I am not looking good enough but it seems to me that the code is not to be shared?
Or am I missing a link?
Tnx.
TimSpangler
  • CAD Naked!!
« Reply #8 on: April 12, 2010, 07:37:11 AM »
This was out a little while back on Cadalyst (I think).  It's a paid program,  It never really took off. (Imo)
Here is a link to it on freecadapps
Here it is on Caddepot
It seems there website is MIA
ACA 2015 - Windows 7 Pro
aicr317
« Reply #9 on: April 13, 2010, 04:58:55 AM »
不死猫,看来是“孤高和寡”了.......哈哈
nonsmall
« Reply #10 on: April 16, 2010, 03:05:37 AM »
The above'Visual DCL'is not really visual,it has nothing to do with me,I just transform the VB FORM into DCL,all the visualization can come true in the VB  .
nonsmall
« Reply #11 on: August 16, 2010, 11:55:43 PM »
This is part of my codes
(defun VB-DCL(export_mode view_code view_form frm_path dcl_path lsp_path /
; *h_scale *w_scale add_num all_list be control dcl_id del dialog_all dialog_h
; dialog_info dialog_key dialog_label dialog_w dialog_x dialog_y end end_string
; err_value f file frame_h frame_key frame_label frame_typ frame_w frame_x frame_y
; get get_be get_end go h i info is_cancel key key_word label layout lst lst_left
; lst_new_column lst_new_row max_range maxh maxw minx minx_info miny miny_info n
; old_range other path re return s sort_lst space str tmp typ w x y
(setq path "D:\\Lisp_开发研究\\visual DCL\\")
(setq f (open frm_path "r"))
(setq key_All nil ok_cancel nil Sort_Times 0)
(setq *w_scale 100.0 *h_scale 200.0)
(read-line f)
(setq dialog_key (last (non_string_to_list (vl-string-trim " " (read-line f)) " ")))
(setq dialog_label (GetLast (read-line f)))
(setq dialog_H (/ (read (GetLast (read-line f))) *h_scale))
(setq dialog_X (/ (read (GetLast (read-line f))) *w_scale))
(setq dialog_Y (/ (read (GetLast (read-line f))) *h_scale))
(setq dialog_W (/ (read (GetLast (read-line f))) *w_scale))
(setq dialog_info (list dialog_X dialog_Y dialog_W dialog_H dialog_key dialog_label))
(while (not (vl-string-search "Begin" (setq str (read-line f)))))
(setq go 1 All_list nil dialog_all nil label "" other nil)
(while (/= go 0)
((= "End" (vl-string-trim " " str))
(setq go (1- go))
(if (= 1 go)
(setq dialog_all (append dialog_all (list (list x y w h key label typ other))) label "" other nil)
((vl-string-search "Begin VB.Frame" str)
(setq dialog_all (append dialog_all (list (OpenFrame str))) label "" other nil)
((vl-string-search "Begin VB." str)
(setq go (1+ go))
(setq key (last (setq tmp (non_string_to_list (vl-string-trim " " str) " "))))
(setq typ (last (non_string_to_list (cadr tmp) ".")))
((or (= "Tag" (GetFirst str)) (= "Caption" (GetFirst str)) (= "Text" (GetFirst str)))
(setq label (GetLast str))
((= "Height" (GetFirst str))
(setq h (/ (read (GetLast str)) *h_scale))
((= "Width" (GetFirst str))
(setq w (/ (read (GetLast str)) *w_scale))
((= "Left" (GetFirst str))
(setq x (/ (read (GetLast str)) *w_scale))
((= "Top" (GetFirst str))
(setq y (/ (read (GetLast str)) *h_scale))
((= "MultiSelect" (GetFirst str))
(setq other (GetLast str))
(close f)
(setq sort_lst (sort_with_column "COLUMN" dialog_all));排出来Row+控件表+控件表 +....
(setq Space 4 Add_Num 0);增加空格Space 增加次数Add_Num
(setq get (Broken sort_lst));得到前后两段源码
(setq End_String (append (car get) (cadr get)))
(if (not ok_cancel) (setq key_All (append key_All (list (list "accept" "button" "确认") (list "cancel" "button" "取消")))))
((= export_mode "unite")
(write_Dcl_in_Lsp lsp_path frm_path)
(if (= view_code "1")(startapp "notepad" lsp_path))
((= export_mode "alone")
(write_dcl_only dcl_path frm_path)
(write_lsp_only lsp_path dcl_path)
(if (= view_code "1")(startapp "notepad" dcl_path))
((= export_mode 3)
(write_dcl_only dcl_path)
(write_lsp_Net lsp_path)
(if (= view_form "1")
(load lsp_path)
(c:tt)
« Last Edit: August 17, 2010, 08:22:47 AM by CAB »
nonsmall
« Reply #12 on: August 16, 2010, 11:56:46 PM »
initget
(defun c:q( / dcl_id Dialog_Return key keys Dcl_File)
(setq reg_path "HKEY_LOCAL_MACHINE\\SOFTWARE\\Autodesk\\VB-Dcl")
(setq dcl_id (load_dialog (setq Dcl_File (Write_VB_Dcl))));对话框加载
(vl-file-delete Dcl_File)
(setq keys '("frm_path" "frm_sel" "dcl_path" "dcl_sel" "lsp_path" "lsp_sel" "unite" "alone" "view" "code" "accept" "cancel" "info"));列表全部控件名称
(foreach key keys
(set (read (strcat key "_bak")) (vl-registry-read reg_path (strcat key "_bak")))
(setq Dialog_Return 2)
(while (> Dialog_Return 0) ;循环控制对话框是否结束
(new_dialog "Form1" dcl_id);建立窗体
;-->-->-对话框初始化->-->--
(foreach key keys;全部控件的初始化
(if (eval (read (strcat key "_bak"))) (set_tile key (eval (read (strcat key "_bak")))));控件内容
(action_tile key "(Action_Form_Keys $key $value)");点击动作
;--<--<-对话框初始化完成-<--<--
(setq Dialog_Return (start_dialog));开启对话框(用户可见)
(unload_dialog dcl_id);退出时卸载对话框
(princ);防止函数回显
(defun Action_Form_Keys (key value) ;全部控件的点击动作触发
((= key "accept") ;{确认按钮}
(foreach key '("frm_path" "dcl_path" "lsp_path")
(set (read key) (get_tile key))
(foreach key '("unite" "alone" "dcl" "all")
(if (= (get_tile key) "1")
(setq export_mode key)
(setq view_code (get_tile "code"))
(setq view_form (get_tile "view"))
(Get_Form_Date)
(VB-DCL export_mode view_code view_form frm_path dcl_path lsp_path)
((= key "cancel") ;{取消按钮}
(done_dialog 0);对话框退出返回主函数 传递给Dialog_Return独立0
((= key "frm_sel") ; {"选择"} (按钮)
(if (vl-file-directory-p (vl-filename-directory (get_tile "frm_path")))
(setq old_path (strcat (vl-filename-directory (get_tile "frm_path")) "\\"))
(setq old_path "")
(if (setq path (getfiled "请选择需要转换的Frm文件" old_path "frm" 0))
(set_tile "frm_path" path)
((= key "dcl_sel") ; {"选择"} (按钮)
(if (vl-file-directory-p (vl-filename-directory (get_tile "dcl_path")))
(setq old_path (strcat (vl-filename-directory (get_tile "dcl_path")) "\\"))
(setq old_path "")
(if (setq path (getfiled "请确认转换后保存的Dcl文件名" old_path "dcl" 1))
(set_tile "dcl_path" path)
((= key "lsp_sel") ; {"选择"} (按钮)
(if (vl-file-directory-p (vl-filename-directory (get_tile "lsp_path")))
(setq old_path (strcat (vl-filename-directory (get_tile "lsp_path")) "\\"))
(setq old_path "")
(if (setq path (getfiled "请确认转换后保存的Lsp文件名" old_path "lsp" 1))
(set_tile "lsp_path" path)
((= key "info") ; {"说明"} (按钮)
(alert
(strcat
"程序作者: nonsmall \n"
"联系方式: QQ43797405 \n"
"Email : nonsmall@163.com"
(defun Get_Form_Date( / key)
(foreach key keys
(vl-registry-write reg_path (strcat key "_bak") (get_tile key))
(defun Write_VB_Dcl( / Dcl_File file str)
(setq Dcl_File (vl-filename-mktemp nil nil ".Dcl"))
(setq file (open Dcl_File "w"))
(foreach str '(
"/*nonsmall 作品: Visual DCL*/"
"//本代码全部由Visual DCL程序自动生成"
"Form1:dialog"
" label = \"Visual Dcl 全自动制作程序 V1.0\";"
"    :column"
"        :boxed_column"
"         key = \"Frame1\" ;"
"         label = \"路径选择\" ;"
"            :row"
"                :edit_box"
"                    key = \"frm_path\" ;"
"                    label = \"Frm窗体路径:\" ;"
"                    width = 76.95 ;"
"                    height = 0.9375 ;"
"                    fixed_height = true ;"
"                    fixed_width = true ;"
"                :button"
"                    key = \"frm_sel\" ;"
"                    label = \"选择\" ;"
"                    width = 9.75 ;"
"                    height = 1.875 ;"
"            :row"
"                :edit_box"
"                    key = \"dcl_path\" ;"
"                    label = \"输出DcL路径:\" ;"
"                    width = 76.95 ;"
"                :button"
"                    key = \"dcl_sel\" ;"
"                    label = \"选择\" ;"
"                    width = 9.75 ;"
"                    height = 1.875 ;"
"            :row"
"                :edit_box"
"                    key = \"lsp_path\" ;"
"                    label = \"输出Lsp路径:\" ;"
"                    width = 76.95 ;"
"                :button"
"                    key = \"lsp_sel\" ;"
"                    label = \"选择\" ;"
"                    width = 9.75 ;"
"                    height = 1.875 ;"
"        :boxed_column"
"         key = \"Frame2\" ;"
"         label = \"输出文件类型选择\" ;"
"            :row"
"                :radio_button"
"                    key = \"unite\" ;"
"                    label = \"Dcl+Lsp整合\" ;"
"                    width = 13.35 ;"
"                    height = 1.275 ;"
"                :radio_button"
"                    key = \"alone\" ;"
"                    label = \"Dcl+Lsp独立文件\" ;"
"                    width = 16.95 ;"
"                    height = 1.275 ;"
"                :toggle"
"                    key = \"view\" ;"
"                    label = \"完成后预览窗体\" ;"
"                    width = 15.75 ;"
"                    height = 1.275 ;"
"                :toggle"
"                    key = \"code\" ;"
"                    label = \"完成后查看源码\" ;"
"                    width = 15.75 ;"
"                    height = 1.275 ;"
"        :row"
"            :text"
"                key = \"Label1\" ;"
"                width = 13.35 ;"
"                height = 1.875 ;"
"            :button"
"                key = \"accept\" ;"
"                label = \"Just Do It !\" ;"
"                width = 19.35 ;"
"                height = 1.875 ;"
"                is_default = true ;"
"            :button"
"                key = \"cancel\" ;"
"                label = \"退出\" ;"
"                width = 16.95 ;"
"                height = 1.875 ;"
"                is_cancel = true ;"
"            :button"
"                key = \"info\" ;"
"                label = \"说明\" ;"
"                width = 16.95 ;"
"                height = 1.875 ;"
"            :text"
"                key = \"Label2\" ;"
"                width = 15.75 ;"
"                height = 1.875 ;"
(write-line str file))
(close file)
Dcl_File
« Last Edit: August 17, 2010, 08:23:24 AM by CAB »
highflyingbird
  • Later equals never.
« Reply #13 on: August 17, 2010, 04:24:27 AM »
error: no function definition: NON_STRING_TO_LIST
OK,it's a good idea. Linking the VB form and DCL together,you did a good job.
Nonsmall,looks you have put them togther in real time--WYSWYG? wonderful!
I am a bilingualist,Chinese and Chinglish.
