Author Topic: How to use the same file at Multiple Projects?  (Read 2782 times)
ruruhehe
« on: April 06, 2010, 06:14:11 AM »
I have two VB.net Projects A & B
I want A & B  share one file (FrmMain.vb)
But if I add this file from Project A to Project B
It will save a copy to B's directory,instead of share this file at A's directory.
What should I do?
Re: How to use the same file at Multiple Projects?
« Reply #1 on: April 06, 2010, 06:56:09 AM »
Sorry, I don't understand the question.
Having 2 Projects in one file is not possible.
You can have a solution with multiple Projects,
and you can share Files between different Projects.
You may need to refine your question.
ruruhehe
« Reply #2 on: April 06, 2010, 07:43:36 AM »
Do you mean to say:
Only the projects in one solution, can share a file?
I want share a file between different solution.
David Hall
  • Automatic Duh Generator
« Reply #3 on: April 06, 2010, 09:13:35 AM »
I think he wants to reference the file, and needs to set local copy to false
ruruhehe
« Reply #4 on: April 06, 2010, 09:24:02 AM »
reference dll file and don't copy to local ? no no.
I want to share a frm.vb file between different solutions.
Draftek
« Reply #5 on: April 06, 2010, 09:57:25 AM »
Just make the form into a project and add it to the solution.
Glenn R
« Reply #6 on: April 06, 2010, 05:47:59 PM »
Ditto.
ruruhehe
« Reply #7 on: April 06, 2010, 09:33:33 PM »
 :lol:
Add existing file as link. OK!
