If you need to review your present settings, here are two routines that do this.
;; Original by John Uhden
;(defun ale_checkvars (/ varlist bads getvars getenvs envsvars val)
(defun c:varcheck (/ varlist bads getvars getenvs envsvars val)
(setq varlist
'("PlotSpoolerNode" "PlotSpoolerDirectory"
"AutoSaveFile" "TempDirectory"
"DefaultPlotToFile" "ModeBits"
"AlarmOnError" "ActiveAssistance"
"PROXYWEBSEARCHNUMBER" "Use TODAY as Startup dialog"
"ShowFullPathInTitle" "LayoutRegenControl"
"SnapType" "ShowHyperlinkCursor"
"ShowHyperlinkToolTip" "ShowPaperSize"
"ObjectARXSupportPath" "ObjectDBXSupportPath"
"ExplorerInsertUnits" "LineWeightDisplayScale"
"MRUFilesToList" "HideWarningDialogs"
"DatabaseTablesOpenMode" "SQLIndexInDwg"
"InsertUnitsDefTarget" "InsertUnitsDefSource"
"Measureinit" "AssignInsertUnits"
"LoadPaletteBySession" "ShowOleScaleDialog"
"ImageHighlight" "AutoSnapPolarAddAng"
"LogFilePath" "SaveFilePath"
"OffsetCurveGapType" "UcsIconNonActiveColor"
"UcsIconActiveColor" "UcsIconLineWidth"
"UcsIconCone" "UcsIconSize"
"UcsIcon3d" "UCSAxisAng"
"UCSView" "UCSOrtho"
"XFadeCtl" "DisableTrueColor"
"Trimmode" "CheckDrawingSignature"
"PrinterDescDir" "PrinterStyleSheetDir"
"PrinterConfigDir" "ShowPrintBorder"
"ShowPaperMargins" "ShowPaperBackground"
"CreateViewports" "ShowPlotSetup"
"ShowRuler" "ShowTabs"
"DefaultFormatForSave" "LineWeightUnits"
"WHIPTHREAD" "WhipThreadEnable"
"WhipArcEnable" "DefaultLayerZeroPlotStyle"
"DefaultPlotStyle" "HatchAlertDisabled"
"DatabaseWorkSpacePath" "TemplatePath"
"MaxArray" "EdgeMode"
"MaxHatch" "HatchType"
"PlineType" "AVEMAP"
"ImportPathInfo" "CursorSize"
"ShowProxyGraphics" "ShowProxyDialog"
"ARXDemandLoad" "TextWindow.FontPitchAndFamily"
"TextWindow.FontItalic" "TextWindow.FontWeight"
"TextWindow.FontHeight" "TextWindow.FontFace"
"CmdLine.FontPitchAndFamily"
"CmdLine.FontItalic" "CmdLine.FontWeight"
"CmdLine.FontHeight" "CmdLine.FontFace"
"FontPitchAndFamily" "FontItalic"
"FontWeight" "FontHeight"
"FontFace" "MonoVectors"
"Plot preview background" "Autotracking vector"
"LayoutXhairPickboxEtc" "XhairPickboxEtc"
"TextWindow.BackColor" "TextWindow.ForeColor"
"CmdLine.BackColor" "CmdLine.ForeColor"
"Layout background" "Background"
"MaxDwg" "CustomColors"
"CmdHistLines" "CmdVisLines"
"MaxApp" "ToolTips"
"Scrollbars" "UseMenuHeader"
"AcadClassic" "SDIMode"
"NoStartUpDialog" "DemandLoadingModeler"
"ScreenMenu" "DigitizerArbitration"
"BmpOutCompression" "LogFileOpen"
"ACADLOGFILE" "LOGFILE"
"UserName" "ACADALTMENU"
"ACADLspAsDoc" "AutoSnapTrackPath"
"AutoSnapPolarDistance" "AutoSnapPolarAng"
"AutoSnapPolarMode" "AutoSnapShowAperture"
"AutoSnapSize" "AutoSnapColor"
"OleHide" "XrefLoadPath"
"Trim&ExtendProjectMode" "MaxOctTreeNodesToAllocate"
"PostscriptQuality" "PickFirst"
"PickDrag" "PickBox"
"PickAuto" "PickAdd"
"GripSize" "GripHot"
"GripColor" "GripBlock"
"Grips" "EntityExtentVariant"
"AuditControlFlags" "MenuOptionFlags"
"XrefControlFlags" "DisableGraphicsTextArea"
"SDF_AttributeExtractTemplateFile"
"ObjectSnapCursorSize" "StatusLine&CoordinateDisplay"
"RasterPreview" "PlotRotationMode"
"QAFlags" "CommandDialogs"
"FileDialog" "RtDisplay"
"ZoomFactor" "UseContextMenus"
"ContextMenus" "MiddleButtonPan"
"OsnapCoord" "XrefLazyLoadMode"
"TextFill" "MTextEditor"
"CustomDictionary" "MainDictionary"
"PSOUT_PrologFileName" "AutomaticSaveMinutes"
"DisableScreenMenuArea" "MaxSortEntries"
"FontMappingFile" "EmergencyFont"
"NetLocation" "IsaveBackupDwg"
"IsavePercent" "MenuFile"
(foreach item varlist
((and (setq val (getenv item)) (getvar item))
(setq envsvars (cons (strcat item " " val) envsvars))
(val
(setq getenvs (cons (strcat item " " val) getenvs))
((setq val (getvar item))
(setq getvars
(cons
(strcat
item
((= (type val) 'int) (itoa val))
((= (type val) 'real) (rtos val 2))
(t val)
getvars
(t (setq bads (cons item bads)))
(princ
(strcat
"\nACADVER="
(getvar "acadver")
" _VERNUM="
(getvar "_vernum")
(princ "\n\nItems found via (getenv and getvar):\n")
(if envsvars
(mapcar 'write-line (acad_strlsort envsvars))
(write-line "None")
(princ "\n\nItems found via (getenv):\n")
(if getenvs
(mapcar 'write-line (acad_strlsort getenvs))
(write-line "None")
(princ "\nItems found via (getvar):\n")
(if getvars
(mapcar 'write-line (acad_strlsort getvars))
(write-line "None")
(princ "\nItems NOT found:\n")
(if bads
(mapcar 'write-line (acad_strlsort bads))
(write-line "None")
;; By Unknown author
(defun c:prac ()
(textpage)
(foreach n
'("ACADLSPASDOC" "ACISOUTVER" "AFLAGS" "ANGBASE"
"ANGDIR" "APBOX" "APERTURE" "ATTDIA"
"ATTMODE" "ATTREQ" "AUDITCTL" "AUNITS"
"AUPREC" "AUTOSNAP" "BINDTYPE" "BLIPMODE"
"CECOLOR" "CELTSCALE" "CELTYPE" "CELWEIGHT"
"CHAMFERA" "CHAMFERB" "CHAMFERC" "CHAMFERD"
"CHAMMODE" "CIRCLERAD" "CLAYER" "CMDECHO"
"CMLJUST" "CMLSCALE" "CMLSTYLE" "COMPASS"
"COORDS" "CPLOTSTYLE" "CTAB" "CURSORSIZE"
"CVPORT" "DCTCUST" "DCTMAIN" "DEFLPLSTYL"
"DELOBJ " "DEMANDLOAD" "DIMADEC" "DIMALT"
"DIMALTD" "DIMALTF" "DIMALTR ND" "DIMALTTD"
"DIMALTTZ" "DIMALTU" "DIMALTZ" "DIMAPOST"
"DIMASO" "DIMASSOC" "DIMASZ" "DIMATFIT"
"DIMAUNIT" "DIMAZIN" "DIMBLK" "DIMBLK1"
"DIMBLK2" "DIMCEN" "DIMCLRD" "DIMCLRE"
"DIMCLRT" "DIMDEC" "DIMDLE" "DIMDLI"
"DIMDSEP" "DIMEXE" "DIMEXO" "DIM FIT"
"DIMFRAC" "DIMGAP" "DIMJUST" "DIMLDRBLK"
"DIMLFAC" "DIMLI M" "DIMLUNIT" "DIMLWD"
"DIMLWE" "DIMPOST" "DIMRND" "DIMSAH"
"DIMSCALE" "DIMSD1" "DIMSD2" "DIMSE1"
"DIMSE2" "DIMSHO" "DIMSOXD" "DIMSTYLE"
"DIMTAD" "DIMTDEC" "DIMTFAC" "DIMTIH"
"DIMTIX" "DIMTM" "DIMTMOVE" "DIMTOFL"
"DIMTOH" "DIMTOL" "DIMTOLJ" "DIMTP"
"DIMTSZ" "DIMTVP" "DIMTXSTY" "DIMTXT"
"DIMTZIN" "DIMUNI T" "DIMUPT" "DIMZIN"
"DISPSILH" "DONUTID" "DONUTOD" "DRAGMODE"
"DRAGP1" "DRAGP2" "DWGCHECK" "EDGEMODE"
"ELEVATION" "EXPERT" "EXPLMODE" "EXTNAMES"
"FACETRATIO" "FACETRES" "FILEDIA" "FILLE TRAD"
"FILLMODE" "FONTALT" "GRIDMODE" "GRIDUNIT"
"GRIPBLOCK" "GRIPCOLOR" "GRIPHOT" "GRIPS"
"GRIPSIZE" "HALOGAP" "HIDEPRECIS" "HIDETEXT"
"HIGHLIGHT" "HPANG" "HPBOUND" "HPDOUBLE"
"HPNAME" "HPSCALE" "HPSPACE" "HYPERLINKB"
"IMAGEHLT" "INDEXCTL" "INETLOCATI" "INSBASE"
"INSNAME" "INSUNITS" "INSUNITSDE" "INSUNITSDE"
"ISAVEBAK" "ISAVEPERCE" "ISOLINES" "LASTPOINT"
"LAYOUTREGE" "LIMCHE CK" "LIMMAX" "LIMMIN"
"LISPINIT" "LOGFILEMOD" "LOGFILEPAT" "LTSCALE"
"LUNITS" "LUPREC" "LWDEFAULT" "LWDISPLAY"
"LWUNITS" "MAXACTVP" "MAXSORT" "MBUTTONPAN"
"MEASUREINI" "MEASUREMEN" "MENUCTL " "MENUECHO"
"MIRRTEXT" "MODEMACRO" "MTEXTED" "NOMUTT"
"OBSCUR EDCO" "OBSCUREDLT" "OFFSETDIST" "OFFSETGAPT"
"OLEHIDE" "OLEQUALIT Y" "OLESTARTUP" "ORTHOMODE"
"OSMODE" "OSNAPCOORD" "PAPERUPDAT" "PDMODE"
"PDSIZE" "PELLIPSE" "PICKADD" "PICKAUTO"
"PICKBOX" "PICKDRAG" "PICKFIRST" "PICKSTYLE"
"PLINEGEN" "PLINETYPE" "PLINEWID" "PLOTROTMOD"
"PLQUIET" "POLARADDAN" "POLARANG" "POLARDIST"
"POLARMODE" "POLYSIDES" "PROJECTNAM" "PROJMODE"
"PROXYGRAPH" "PRO XYNOTIC" "PROXYSHOW" "PROXYWEBSE"
"PSLTSCALE" "PSPROLOG" "PSQUALITY" "PSTYLEPOLI"
"PSVPSCALE" "PUCSBASE" "QTEXTMODE" "RASTERPREV"
"REGENMODE" "REMEMBERFO" "RTDISPLAY" "SAVEFILEPA"
"SAVETIME" "SDI" "SHADEDGE" "SHADEDIF"
"SHORTCUTME" "SHPNAME" "SKETCHINC" "SKPOLY"
"SNAPANG" "SNAPBASE" "SNAPISOPAI" "SNAPMODE"
"SNAPSTYL" "SNAPTYPE" "SNAPUNIT" "SOLIDCHECK"
"SORTENTS" "SPLFRAME" "SPLINESEGS" "SPLINETYPE"
"STARTUPTOD" "SURFTAB1" "SURFTAB2" "SURFTYPE "
"SURFU" "SURFV" "TABMODE" "TEXTEVAL"
"TEXTFILL" "TEXTQLTY" "TEXTSIZE" "TEXTSTYLE"
"THICKNESS" "TILEMODE" "TOOLTIPS" "TRACEWID"
"TRACKPATH" "TREEDEPTH" "TREEMAX" "TRIMMODE"
"TSPACEFAC" "TSPACETYPE" "TSTACKALIG" "TSTACKSIZE"
"UCSAXISANG" "UCSBASE" "UCSFOLLOW" "UCSICON"
"UCSORTHO" "UCSVIEW" "UCSVP" "UNITMODE"
"VISRETAIN" "WHIPARC" "WMFBKGND" "WMFFOREGND"
"WORLDVIEW" "XCLIPFRAM E" "XEDIT" "XFADECTL"
"XLOADCTL" "XLOADPATH" "XREFCTL" "ZOOMFACTOR"
(progn (print n) (princ (getvar n)))
