Author Topic: April One  (Read 2938 times)
April One
« on: April 01, 2010, 11:11:26 AM »
How'd you torment your users?  :-D
(defun aprilfools (/ d)
  (setq d (rtos (fix (getvar 'cdate)) 2 0))
  (if (eq "0401" (strcat (substr d 5 2) (substr d 7 2)))
      (defun teehee (reactor params / disp)
(setq disp (vla-get-display (vla-get-preferences (vlax-get-acad-object))))
(cond ((eq (car params) "EXPLODE") (vlax-put disp 'modelcrosshaircolor 0))
      ((eq (car params) "COPY") (vlax-put disp 'modelcrosshaircolor 255))
      ((eq (car params) "CIRCLE") (vlax-put disp 'modelcrosshaircolor 85))
      ((eq (car params) "ERASE")
       (vlax-put disp
'displaylayouttabs
(boole 8 0 (vlax-get disp 'displaylayouttabs))
      ((eq (car params) "MOVE") (vlax-put disp 'cursorsize 25))
      ((eq (car params) "PLOT")
       (vlax-put disp
'displayscrollbars
(boole 8 0 (vlax-get disp 'displayscrollbars))
      ((eq (car params) "MLEADER")
       (vlax-put disp
'displayscreenmenu
(boole 8 0 (vlax-get disp 'displayscreenmenu))
      (if (not *aprilfoolsreactor*)
(setq *aprilfoolsreactor*
       (vlr-editor-reactor
"TeeHeeHee"
'((:vlr-commandended . teehee))
;;; Cleanup
;;; (vlr-remove-all :vlr-editor-reactor)
(aprilfools)
alanjt
  • Standby for witty remark...
Re: April One
« Reply #1 on: April 01, 2010, 12:49:27 PM »
LoL
As soon as I started reading this Coasters - Yakety Yak Lyrics popped in my head.
Dropbox
KewlToyZ
alanjt
Re: April One
« Reply #3 on: April 01, 2010, 01:06:03 PM »
Stupid song is still stuck in my head!!!
Dropbox
Re: April One
« Reply #4 on: April 01, 2010, 01:16:43 PM »
So not other pranksters out there? I'm setting up the bluescreen screensaver as we speak  8-)
alanjt
Re: April One
« Reply #5 on: April 01, 2010, 01:25:52 PM »
You're much more imaginative that I am. I just put this in the acaddoc.lsp file.
(or (eq "athompson" (getvar 'loginname)))
    (alert "Press OK to format C: drive"))
Dropbox
KewlToyZ
Re: April One
« Reply #6 on: April 01, 2010, 02:09:20 PM »
 :lmao:
Brutal and brilliant!
dgorsman
Re: April One
« Reply #7 on: April 01, 2010, 02:10:35 PM »
Provided your users actually *read* the command line.   :-(
I *was* considering adding a speech module to the global error handler, with the computer saying "Please don't touch me like that." on every error.  But seeing that I can't even get 5 minutes without being interupted this morning...  :x
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
M-dub
Re: April One
« Reply #8 on: April 01, 2010, 02:13:15 PM »
For April Fools this year, I cut the wife's brake line.
(points and laughs) "Ha Ha, April Fools!  How's that neck brace treatin' ya?!"
I'm kidding, of course.
KewlToyZ
Re: April One
« Reply #9 on: April 01, 2010, 02:17:50 PM »
Re: April One
« Reply #10 on: April 01, 2010, 02:50:42 PM »
Nice one Ron   8-)
FYI
(boole 8 0 x)  =  (~ x)  :wink:
Greg B
  • Tell me a Joke!
Re: April One
« Reply #11 on: April 01, 2010, 03:19:03 PM »
Of course.
Re: April One
« Reply #12 on: April 01, 2010, 03:21:52 PM »
Nice one Ron   8-)
FYI
GDF
Re: April One
« Reply #13 on: April 01, 2010, 04:08:39 PM »
;;;R.K. McSwain 98
(defun c:aprilfool  ()
  (setvar "cmdecho" 0)
  (command ".delay" 4000)
  (setvar "expert" 5)
  (command ".layer" "_off" "*" "")
  (setvar "expert" 0)
  (alert (strcat
           "              FATAL ERROR" "             \n"
           "             \n Heap error in module FF00:1235"
           "             \n CIS debug FF12:4510  FF12:1895"
           "             \n FF18:1346 in acad.exe."))
  (alert (strcat " Audit will now execute...."))
  (prompt "\rcommand: audit")
  (prompt "\nFix any errors detected? <N> y")
  (command ".delay" 100)
  (prompt "\n 112 Blocks audited")
  (command ".delay" 1500)
  (prompt "\nPass 1 1320     objects audited")
  (prompt "\nPass 2 1320     objects audited")
  (prompt "\nPass 3 9617     objects audited")
  (command ".delay" 150)
  (prompt "\nTotal errors found 1842 fixed 0")
  (princ))
GDF
Re: April One
« Reply #14 on: April 01, 2010, 04:11:22 PM »
(defun ANNOY  ()
  (command ".limits" "-0.1,-0.1" "0,0" "" "on")
  (command ".undefine" "limits" "undefine" "redefine")
  (progn (setq num 10000)
         (while (> num 50) (dos_speaker num 1) (setq num (- num 250))))
  (progn (setq X 1000)
         (setq Y 500)
         (repeat 10 (dos_speaker Y 250) (dos_speaker X 200)))
  (progn (setq X 50)
         (setq Y 200)
  (progn (setq num 50)
         (while (< num 10000) (dos_speaker num 1) (setq num (+ num 250))))
  (princ))
