Author Topic: Question of the day #5  (Read 6177 times)
« on: December 01, 2004, 07:48:43 AM »
What does the following function calculate?
(defun func (a b c)
  (defun sq (n) (* n n))
      (+ (sq b) (sq c))
      (sq a)
    (* 2 b c)
(func 85.0 100.0 80.0)
0.573438
whdjr
« Reply #1 on: December 01, 2004, 09:44:30 AM »
You know we need to set up rules or guidlines for these questions.
Something kinda like:
1.  Please don't post your answer until 3 hours after the initial post.
     (So that everyone's answer is completely bias.  Also if I see someone
      else has already answered it I might not even try.)
2.  During this time frame someone could ask questions or you could
     give out hints or clues.
3.  People could also chime in with "I got my answer.  How about you guys?".
These are just a few thoughts to make this fun and good learning at the same
time.  If the answer is posted within 2 minutes of the original post newbies might get discouraged.
Just my thoughts so please don't beat them up too bad.
« Reply #2 on: December 01, 2004, 09:47:39 AM »
good idea
whdjr
« Reply #3 on: December 01, 2004, 10:33:09 AM »
You edited your post Kerry :D
Man, I'm stumped!?!?!?!?
« Reply #4 on: December 01, 2004, 10:47:55 AM »
I agree, some guidelines would be a good. The problem is the time frame. If we make 3 hours then some one is going to get left out, and 24 hours may be to long. But I agree we to do something.
How does this sound?
Question of the day guidelines:
1. Please do not post your answer for 24 hours after the time of the post.
2. If you wish you may post something like "I've got it!"
3. Feel free to ask questions, or for hints.
4. Feel free to PM the person who asked the question.
5. Do not be embarrassed by your answer or code.
CADaver
Re: Question of the day #5
« Reply #5 on: December 01, 2004, 10:52:03 AM »
Quote from: Mark Thomas
(defun func (a b c)
      (+ (sq b) (sq c))
      (sq a)
    (* 2 b c)
0.573438
Lesee, you're adding the squares of b and c, then subtracting the square of a.  Then you're dividing the whole mess by 2 times b times c.
Dunno man, looks sorta familiar, but I ain't gotta clue.
whdjr
« Reply #6 on: December 01, 2004, 10:52:36 AM »
Mark,
Those sound very good.  3 hours was just a time I used for illustration.
« Reply #7 on: December 01, 2004, 12:14:48 PM »
Well, like CADaver, it looks soooo familiar, but I just can't place it ...
dubb
« Reply #8 on: December 01, 2004, 12:19:55 PM »
no multiple choice?
« Reply #9 on: December 01, 2004, 12:54:24 PM »
I think encrypted answers would be cool (that way the first person to have the correct answer "wins".). ...Once the time is up we just post our keys to decrypt the answers.
So that means no edited posts. (if they do edit the post we assume cheeting.)
whdjr
« Reply #10 on: December 01, 2004, 01:00:05 PM »
Sounds great Se7en.
So whose got the encryption tool?  I know I had mine around here somewhere....?
CarlB
« Reply #11 on: December 01, 2004, 01:00:16 PM »
OK I found it but to not spoil all the fun I'll just drop a hint.  Has to do with a triangle.
« Reply #12 on: December 01, 2004, 01:05:09 PM »
Quote from: CarlB
I was going to say dinner bell, but thought better of it. :D
« Reply #13 on: December 01, 2004, 01:07:53 PM »
Quote from: whdjr
Sounds great Se7en.
We can make our own.  (I cant do it now cause all my stuff i at home. But i can see how far i can get.) But im sure some ones got some code that can be modified real quick.
dubb
« Reply #14 on: December 01, 2004, 02:38:52 PM »
A WILD GUESS......pythagorean theorem? in code?
