What 'problems' are created using page setup overrides?
From my experience, there should be none. What are they if they can be described explicitly? Those 'problems' might be caused by how one has ones layouts set up...
If PAGE Setup A uses plot by layout
and page setup B uses plot by Layout
what gets plotted wrong?
If one can not or does not use BY LAYOUT, there are some fundamental flaws in the process of creating the Page Setups.
Please send me an example of a file where LAYOUT doesn't work for all page setups, and I can discover WHY, and WHAT should be done to enable same to work without issues. Unless of course, this is a fundamental flaw in the version of ACAD you are using.
(Perhaps this should spawn a second topic in PLOTTING? Interestingly enough I am finding no discussion about 'problems' using BY LAYOUT and plotting in the usual places.)
