Author Topic: E_NOINTERFACE  (Read 10091 times)
sinc
E_NOINTERFACE
« on: March 12, 2010, 07:36:06 PM »
Anyone know anything about this?
I have an application that gets this error when attempting to access the AcadApplication via the Interops.
Jeff found this link, but I don't know if it has anything to do with it or not.  If this is the problem, why would I only see this error on only one computer?
Bryco
Re: E_NOINTERFACE
« Reply #1 on: March 15, 2010, 06:04:06 PM »
Does vba have to be installed on a machine for interop to work?
sinc
Re: E_NOINTERFACE
« Reply #2 on: March 15, 2010, 07:30:41 PM »
It's the other way around.  VBA requires the Interops, and can't use the .NET interface.  Or maybe I should say VBA and the Interops both use the COM interface, instead of the .NET interface.
Re: E_NOINTERFACE
« Reply #3 on: March 15, 2010, 07:34:57 PM »
can you post the code or the entire error to help in searching for possible other causes?  (there do seem to be a lot of reasons one could be gettin this error)
Re: E_NOINTERFACE
« Reply #4 on: March 16, 2010, 02:22:09 AM »
This is the error:
Unable to cast COM object of type ‘System.__ComObject' to interface type ‘Autodesk.AutoCAD.Interop.AcadApplication’. This operation failed because the QueryInterface call on the COM component for the interface with IID ‘{XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX}’ failed due to the following error: No such interface supported (Exception from HRESULT: 0×80004002 (E_NOINTERFACE)).
Bryco
Re: E_NOINTERFACE
« Reply #5 on: March 16, 2010, 09:45:00 AM »
Since 2010 cad requires a separate download of vb I thought perhaps that machine didnt have it but it doesn't make much sense
sinc
Re: E_NOINTERFACE
« Reply #7 on: March 16, 2010, 10:55:49 AM »
I don't see anything in either of those links that seems to apply.
My current working theory (which may be completely bogus) is that it is caused by another Autodesk product being installed side-by-side with Civil 3D.  Unfortunately, the target machine has about 15 Autodesk products installed on it...   :laugh:
Re: E_NOINTERFACE
« Reply #8 on: March 16, 2010, 11:07:45 AM »
perhaps if all those XXXXXXX's were actual numbers; a search might yield more usefull information?
•Microsoft SQL Server Management Studio: An error with a message like “Unable to cast COM object of type ‘System.__ComObject’ to interface type ‘Microsoft.VisualStudio.OLE.Interop.IServiceProvider’. This operation failed because the QueryInterface call on the COM component for the interface with IID ‘{6D5140C1-7436-11CE-8034-00AA006009FA}’ failed due to the following error: No such interface supported (Exception from HRESULT: 0×80004002 (E_NOINTERFACE)). (Microsoft.VisualStudio.OLE.Interop)
I’m not sure of the exact details, but this is what I think I’ve found. Perhaps someone at Microsoft would correct or elaborate on this.
Previously, actxprxy.dll (ActiveX Interface Marshaling Library) was used as the proxy for a multitude of system interfaces, such as IShellFolder and IServiceProvider.
In Windows 7 (and probably Vista also), the GUID of this library has changed from {B8DA6310-E19B-11D0-933C-00A0C90DCAA9} to {C90250F3-4D7D-4991-9B69-A5C5BC1C2AE6}
Secondly, there is also a new Proxy/Stub provider found in ieproxy.dll of Internet Explorer (IE ActiveX Interface Marshaling Library). Some interfaces that previously used actxprxy.dll are now registered to use ieproxy.dll.
Now various problematic software (such as Vault 3.x) will try to register against actxproxy using the old GUID, and for interfaces now proxied by ieproxy.dll.
« Last Edit: March 16, 2010, 11:13:00 AM by mjfarrell »
LE3
Re: E_NOINTERFACE
« Reply #9 on: March 16, 2010, 11:29:26 AM »
This is the error:
Is this happen after a windows update?... but still that error means that the com dll is not correctly registered on your system - try to re-register manually via regsvr32
sinc
Re: E_NOINTERFACE
« Reply #10 on: March 16, 2010, 11:41:23 AM »
That was the very first thing I tried.  No hits.
sinc
Re: E_NOINTERFACE
« Reply #11 on: March 16, 2010, 11:42:38 AM »
Do you mean try repairing/reinstalling Civil 3D?  I would have no idea how to re-register the DLLs, except to do a "repair installation"...
Re: E_NOINTERFACE
« Reply #12 on: March 16, 2010, 11:48:07 AM »
the article I quoted from last had an example of how to manually register the particular DLL's their article found to be a solution to the issue (they were experiencing)   Perhaps that Batch file could be modified to suit
http://www.davidmoore.info/tag/c90250f3-4d7d-4991-9b69-a5c5bc1c2ae6/
LE3
Re: E_NOINTERFACE
« Reply #13 on: March 16, 2010, 11:58:32 AM »
I am not familiar with C3D.
I mean the dll in particular... you can copy regsvr32.exe (that it is under windows\system32 well at least on my winxp system) on the same location as the dll and use: regsvr32 theName.dll <enter>
or attached here is a tool for that (been using it for years). HTH
sinc
Re: E_NOINTERFACE
« Reply #14 on: March 16, 2010, 11:59:50 AM »
The problem is that I have no idea IF that's the problem, or if it is, what the correct GUID should be for what key.
My current working theory is that it's something that happens when 64-bit and 32-bit Autocad products are installed side-by-side, but I have no idea how to fix it.
