Poll
Which of these is easier for [you] to read
fun_1
fun_2
Author Topic: Reading Code  (Read 4992 times)
Reading Code
« on: March 12, 2010, 03:48:26 PM »
Which of these is easier for [you] to read.
I don't mean to ask if you can understand either set of code, I mean which formatting lets can you grasp the code intent easier.
(defun fun_1 (l n / a b c d)
    (while (Setq d l)
        (while (< (setq b (length a)) n)
            (setq a (cons (nth b d) a) l (cdr l)))
            (setq  c (cons (reverse a) c)  a nil))
            (reverse c))
(defun fun_2 (l n / a b c d)
  (while (setq d l)
            l (cdr l)
          a nil
  (reverse c)
Re: Reading Code
« Reply #1 on: March 12, 2010, 03:50:09 PM »
Is this another dig at my coding style...  :evil:
fun_1  But with the indentation set to how it should be.
Re: Reading Code
« Reply #2 on: March 12, 2010, 03:53:21 PM »
No Lee, this is NOT a dig at you.
I've seen several people attempt to use the closing at end of line format style, and wanted to know what our users think.
The first code block is reproduced exactly as it was posted.
The second as formatted by VLIDE.
Re: Reading Code
« Reply #3 on: March 12, 2010, 03:55:41 PM »
Just messing with you Kerry  :wink:
I realise that was how it was posted - but it isn't the correct way that the end-of-line style is formatted by the VLIDE and makes it difficult to decipher even when you are used to the end-of-line style... bit of unfair survey IMO..
GDF
Re: Reading Code
« Reply #4 on: March 12, 2010, 04:09:34 PM »
I think the same way about dcl code formatting...
for example:
//To load master widgets used by Arch Program© for AutoCAD®
@include "..\\ARCH.dcl"
dcl_settings :default_dcl_settings {audit_level=0;}
arch_program_multi_layerreactor_toggle
  :row {children_fixed_height=true; children_fixed_width=true;
    :arch_multi {}
    :arch_curlaysetreactor {arch_curlaysetreactor;}
    :text_part {label="Leader";}
    :toggle {label = "Poly"; key="poly";}
    :toggle {label = "Bloc"; key="bloc";}
ARCH_ANNO :dialog {key = "set-title"; initial_focus="set-title"; width=93.3; height=21.875;
  :row {
    :boxed_row {label="Control Settings"; width=33.875;
      :column {height=4.025; children_alignment=top;
        :row {
          :toggle {label = "Dtx"; key="dtext"; width=3;}
          :edit_box {key="txdsv"; edit_width=4;}
        :row {
          :toggle {label = "Mtx"; key="mtext"; width=3;}
          :edit_box {key="txmsv"; edit_width=4;}
      :column {
        :row {
          :toggle {label = "CSI"; key="csi"; width=3;}
          :toggle {label = "GEN"; key="gen"; width=3;}
        :row {
          :button {label="Style"; key="txsty"; fixed_width=true;}
          :arch_35x35_image_15 {key="chx";}
    :boxed_column {label="Annotation Commands";
      :arch_cmdname {arch_cmdname;}
      :popup_list {key="commands-list"; width=51.5; tabs="11"; multiple_select=false;}
      :spacer {}
  :arch_program_multi_layerreactor_toggle {arch_program_multi_layerreactor_toggle;}
  :row {height=11.875;
    :column {
      :text_part {key = "clistag"; width=18;}
      :list_box {key = "clist"; width=18; height=9;}
      :popup_list {key="issue"; width=18; multiple_select=false;}
    :row {
      :column {
        :list_box {key = "nte"; width=56.5; height=12; allow_accept=true;} //71 12
      :row {
        :column {
          :arch_35x35_image_15 {key="seq";}
          :arch_35x35_image_15 {key="atx";}
          :arch_35x35_image_15 {key="btx";}
          :arch_35x35_image_15 {key="case";}
          :arch_35x35_image_15 {key="sbox";}
        :column {
          :arch_35x35_image_15 {key="fat";}
          :arch_35x35_image_15 {key="ddt";}
          :arch_35x35_image_15 {key="mrgtx";}
          :arch_35x35_image_15 {key="rtx";}
          :arch_35x35_image_15 {key="it";}
        :column {
          :arch_35x35_image_15 {key="nn";}
          :arch_35x35_image_15 {key="txn";}
          :arch_35x35_image_15 {key="txtmatch";}
          :arch_35x35_image_15 {key="txw";}
          :arch_35x35_image_f15 {}
  :arch_program_textstyle {arch_program_textstyle;}
  styletable :dialog {label=" Set-Chg Textstyle:"; alignment=centered; initial_focus="cancel";
   :text {key ="T_num";}
   :list_box {key="TextPop"; width=27; is_default=true; allow_accept=true;}
   :row {
     :spacer {}
     :button {label="eXit"; key="cancel"; fixed_width=true; mnemonic="X";}
     :spacer {}
gile
  • Marseille, France
Re: Reading Code
« Reply #5 on: March 12, 2010, 04:37:31 PM »
fun_2
Re: Reading Code
« Reply #6 on: March 12, 2010, 05:46:24 PM »
I read my own style best. (fun_2)
I find that I need to reformat the ultra condensed (fun_1) and the expanded style to do any serious investigation of the code.
alanjt
  • Standby for witty remark...
Re: Reading Code
« Reply #7 on: March 12, 2010, 05:52:05 PM »
fun_2
Dropbox
Re: Reading Code
« Reply #8 on: March 12, 2010, 05:58:47 PM »
That's funny, I have to do the opposite for other people's code  8-)
alanjt
Re: Reading Code
« Reply #9 on: March 12, 2010, 06:02:14 PM »
(setq i 1 a "blah") <- Just not easy to look at.
Dropbox
mkweaver
Re: Reading Code
« Reply #10 on: March 12, 2010, 07:25:38 PM »
fun_2
pkohut
Re: Reading Code
« Reply #11 on: March 12, 2010, 07:38:16 PM »
fun_2
ElpanovEvgeniy
  • Moscow (Russia)
Re: Reading Code
« Reply #12 on: March 13, 2010, 02:25:36 AM »
fun_2
wizman
Re: Reading Code
« Reply #13 on: March 13, 2010, 04:57:33 AM »
that looks famiiar Kerry.. :-), fun_2 is easier to grasp, i agree, i usually do the visual lisp formatting but this time just tried the other way which i think looks also pleasant.
Re: Reading Code
« Reply #14 on: March 13, 2010, 06:12:53 AM »
wiz,
I changed the name to protect the innocent :)
Pleasant looking is great, but if I (and others) have to copy code to an editor and format it to make the intent understandable (to me) it's not doing what it's supposed to ... communicate the instructions to solve a problem. If I have to reformat code to be sure of the design I won't bother 9 times out of 10 ; and if someone has a problem to be solved they need the code to be as clear and unambiguous as possible.
This of course is my personal opinion and may bear no kinship to reality.
