Author Topic: -={ Challenge }=- Group List by Number  (Read 27184 times)
Re: -={ Challenge }=- Group List by Number
« Reply #15 on: March 11, 2010, 06:26:42 AM »
Thanks Alan  :-)  Nice code also  :-)
wizman
« Reply #16 on: March 12, 2010, 02:26:39 PM »
Here's another nth:
(defun wiz-grp (l n / a b c d)
    (while (Setq d l)
        (while (< (setq b (length a)) n)
            (setq a (cons (nth b d) a) l (cdr l)))
            (setq  c (cons (reverse a) c)  a nil))
            (reverse c))
« Reply #17 on: March 12, 2010, 02:30:25 PM »
Nice one Wiz  ^-^
Loving the new avatar btw  :-)
wizman
« Reply #18 on: March 12, 2010, 02:48:52 PM »
Thanks Lee, Good codes from all too... :-)
gile
  • Marseille, France
« Reply #19 on: March 13, 2010, 11:52:29 AM »
I am late (I had not much time for lisping these days) but here're my 2 cents
(defun split (l n / sub)
  (defun sub (a n)
    (if (< 0 n)
      (cons (car a) (sub (setq l (cdr a)) (1- n)))
  (if l
    (cons (sub l n) (split l n))
« Reply #20 on: March 13, 2010, 11:54:14 AM »
Nice one Gile  :-)  You do love the recursive solutions  8-)
« Reply #21 on: March 13, 2010, 12:21:16 PM »
Here is the result I get:
Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s):
    (GROUPBYNUM_MAC3 LST 2).....1357 / 1.40 <fastest>
    (WIZ-GRP LST 2).............1482 / 1.28
    (GBN_EV LST 2)..............1545 / 1.23
    (GROUPBYNUM_MAC2 LST 2).....1575 / 1.21
    (GROUPBYNUM_MAC1 LST 2).....1654 / 1.15
    (SPLIT_GILE LST 2)..........1700 / 1.12
    (GROUPBYNUM_VK LST 2).......1731 / 1.10
    (GBN_AJT LST 2).............1872 / 1.02
    (GBN_AJT2 LST 2)............1903 / 1.00 <slowest>
« Reply #22 on: March 13, 2010, 01:19:20 PM »
Judging the posted performances it's obvious to me you guys are testing using a list with pretty modest size, guessing < 100 items. Re-run your tests with a list of 10000 items and you will find a huge difference in performance between the algorithms. Also, you should vary the "group by" value. Subtitle: One test does paint an accurate picture of relative performances. Just sayin'. :)
« Reply #23 on: March 13, 2010, 01:50:54 PM »
You make a good point Michael, I shall try your recommendations  - thanks  :-)
« Reply #24 on: March 13, 2010, 02:03:32 PM »
Ok, retesting with Michael's suggestions:
List with 200 elements, Grouped by 2
  (setq a '(0 1 2 3 4 5 6 7 8 9))
  (repeat 20 (setq lst (append a lst)))
Benchmarking ...............Elapsed milliseconds / relative speed for 4096 iteration(s):
    (GROUPBYNUM_MAC3 LST 2).....1482 / 2.04 <fastest>
    (WIZ-GRP LST 2).............1872 / 1.62
    (GBN_EV LST 2)..............1950 / 1.55
    (GROUPBYNUM_MAC2 LST 2).....2028 / 1.49
    (SPLIT_GILE LST 2)..........2215 / 1.37
    (GROUPBYNUM_MAC1 LST 2).....2262 / 1.34
    (GROUPBYNUM_VK LST 2).......2496 / 1.21
    (GBN_AJT2 LST 2)............2902 / 1.04
    (GBN_AJT LST 2).............3027 / 1.00 <slowest>
List of 200 elements, Grouped by 5
    (GROUPBYNUM_MAC3 LST 5).....1201 / 2.09 <fastest>
    (GROUPBYNUM_MAC2 LST 5).....1388 / 1.81
    (GROUPBYNUM_MAC1 LST 5).....1482 / 1.70
    (GBN_EV LST 5)..............1498 / 1.68
    (WIZ-GRP LST 5).............1498 / 1.68
    (SPLIT_GILE LST 5)..........1591 / 1.58
    (GBN_AJT2 LST 5)............2106 / 1.19
    (GBN_AJT LST 5).............2122 / 1.18
    (GROUPBYNUM_VK LST 5).......2512 / 1.00 <slowest>
List of 200 elements, Grouped by 20
    (GROUPBYNUM_MAC3 LST 20).....1045 / 2.40 <fastest>
    (GROUPBYNUM_MAC2 LST 20).....1092 / 2.30
    (GROUPBYNUM_MAC1 LST 20).....1139 / 2.20
    (SPLIT_GILE LST 20)..........1263 / 1.99
    (GBN_EV LST 20)..............1295 / 1.94
    (WIZ-GRP LST 20).............1357 / 1.85
    (GBN_AJT LST 20).............1732 / 1.45
    (GBN_AJT2 LST 20)............1747 / 1.44
    (GROUPBYNUM_VK LST 20).......2511 / 1.00 <slowest>
Hopefully this is a more rounded test.
VovKa
  • Ukraine
« Reply #25 on: March 13, 2010, 02:18:22 PM »
if (length lst) is a multiple of n
(defun GroupByNum_Mac4 (l n / a b i)
  (setq l (reverse l))
  (while l
    (setq i n)
    (while (< 0 i)
      (setq a (cons (car l) a)
    l (cdr l)
    i (1- i)
    (setq b (cons a b)
  a nil
  b
« Reply #26 on: March 13, 2010, 02:43:53 PM »
Try it with:
(setq lst '(0 1 2 3 4 5 6 7 8 9 0))
(repeat 10 (setq lst (append lst lst)))
(length lst)
11264
with a group length of say 16
the relative difference between the slowest and fastest will be more in the order to 40 to 50 times
let the weeping begin
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #27 on: March 13, 2010, 02:54:10 PM »
You need the fastest function for the huge list?
for this case, you need to forget about recursion, and use a specialized algorithm ...
« Reply #28 on: March 13, 2010, 02:55:17 PM »
List Length = 210x10 = 10240,  Grouped by 16:
Benchmarking ..........Elapsed milliseconds / relative speed for 128 iteration(s):
    (GROUPBYNUM_MAC3 LST 16)......1607 / 22.80 <fastest>
    (GROUPBYNUM_MAC4 LST 16)......1623 / 22.58
    (GROUPBYNUM_MAC2 LST 16)......1700 / 21.56
    (GROUPBYNUM_MAC1 LST 16)......1841 / 19.90
    (SPLIT_GILE LST 16)...........1981 / 18.50
    (GBN_EV LST 16)...............2090 / 17.53
    (WIZ-GRP LST 16)..............2090 / 17.53
    (GROUPBYNUM_VK LST 16)........3978 / 9.21
    (GBN_AJT2 LST 16)............36598 / 1.00
    (GBN_AJT LST 16).............36645 / 1.00 <slowest>
« Reply #29 on: March 13, 2010, 03:14:03 PM »
Excellent. Now having done this one needs to consider context. What's the typical context this function would be used? Maybe you'll use the function to take the flat list of doubles returned by (vlax-get polyline 'coordinates) and convert instead to a list of points (because for whatever reason you were eschewing dxf data), grouping by 2 or 3 depending if it's a lightweight or heavyweight polyline. Is it reasonable to anticipate you could have a polyline with 3000 to 5000 vertices? Back to you Jim.
« Last Edit: March 13, 2010, 03:22:43 PM by MP »
