When you use the command to insert a block with attributes you must address the following system variables.
ATTDIA
Controls whether the -INSERT command uses a dialog box for attribute value entry. See "INSERT Command Line."
0 Issues prompts on the command line
1 Uses a dialog box
ATTMODE
Controls display of attributes.
0 Off: Makes all attributes invisible
1 Normal: Retains current visibility of each attribute: visible attributes are
displayed; invisible attributes are not
2 On: Makes all attributes visible
ATTREQ
Determines whether the INSERT command uses default attribute settings during insertion of blocks.
0 Assumes the defaults for the values of all attributes
1 Turns on prompts or dialog box for attribute values, as specified by ATTDIA
TEXTEVAL
Controls the method of evaluation of text strings.
0 All responses to prompts for text strings and attribute values are taken literally
1 Text starting with an opening parenthesis [ ( ] or an exclamation mark (!) is
evaluated as an AutoLISP expression, as for nontextual input
(setq sysattdia (getvar "ATTDIA"))
(setq sysattreq (getvar "ATTREQ"))
(setq systxteva (getvar "TEXTEVAL"))
(setvar "ATTDIA" 0)
(setvar "ATTREQ" 0)
(setvar "TEXTEVAL" 0)
<do your lisp>
(setvar "ATTDIA" sysattdia)
(setvar "ATTREQ" sysattreq)
(setvar "TEXTEVAL" systxteva)
Alternately you can use the sys var EXPERT
EXPERT
Type: Integer
Not saved
Initial value: 0
Controls whether certain prompts are issued.
0 Issues all prompts normally.
1 Suppresses "About to regen, proceed?" and "Really want to turn the current layer off?"
2 Suppresses the preceding prompts and "Block already defined. Redefine it?" (BLOCK) and "A drawing with this name already exists. Overwrite it?" (SAVE or WBLOCK).
3 Suppresses the preceding prompts and those issued by the LINETYPE command if you try to load a linetype that's already loaded or create a new linetype in a file that already defines that linetype.
4 Suppresses the preceding prompts and those issued by UCS Save and VPORTS Save if the name you supply already exists.
5 Suppresses the prompt, "That name is already in Use, redefine it?" issued by the -DIMSTYLE Save option when you supply the name of an existing dimension style.
When a prompt is suppressed by EXPERT, the operation in question is performed as
though you entered y at the prompt. Setting EXPERT can affect scripts, menu
macros, AutoLISP, and the command functions.
