ViewTableRecord's have a few properties that you would want to use along with a selection set. You can find all the points you would need, as the VTR has ' center point ', ' width ' and ' height ' which will get you a rectangle, that you can use with a selection set, and you don't have to have user interaction. Just watch out for different coordinate systems. Not sure if that will matter, but it might, and that will be the difference between getting what you want, and not.
