Author Topic: Question of the day #1  (Read 2223 times)
« on: November 22, 2004, 07:22:57 AM »
If your program requires the user to input a distance, either on the command line or by picking points, what AutoLISP function would you use?
Provide an example:
David Bethel
« Reply #1 on: November 22, 2004, 08:00:46 AM »
(initget 1)
(setq wid (getdist "\nS-S Width:   "))
I see a lot of people using getreal.  (getdist) allows for input based on LUNITS settings.  -David
R12 Dos - A2K
CADaver
« Reply #2 on: November 22, 2004, 10:04:11 AM »
Quote from: David D Bethel
(initget 1)
(GETDIST also allows the user to "show" AutoCAD the distance by selecting points on the screen.
