Hi Rhino,
I have just tidied up your routine a bit, I hope you don't mind:
not at all - i'll just add the fac variable to it - thanks! I have much to learn
![cool 8-)](https://www.theswamp.org/Smileys/black/cool.gif)
Lee I think he wants is a companion routine to reverse the process.
Or at lease some undo marks.
I could be mistaken. ![cool 8-)](https://www.theswamp.org/Smileys/black/cool.gif)
PS I like the vl version when dealing with COLOR. ![smiley :-)](https://www.theswamp.org/Smileys/black/smiley.gif)
I like the vlisp version too.
@CAB
I don't want a separate func to reverse the process - the vl-undo works well but after you exit the loop/function
i'd like it to work within the loop itself - as a user might click some text string like those under the grid line column...
lee's routine is fine otherwise - and has thought me quite a bit.
