Author Topic: lisp code scrambling  (Read 1820 times)
VovKa
  • Ukraine
« on: January 14, 2010, 12:45:41 PM »
inspired by EvgeniyElpanov
originally Kelvinator was introduced by someone called Kelvin R. Throop.
trying to avoid copyright problems i named mine VovKaFicator :)
scrambles localized variables and functions
strings and quoted lists remain intact
(defun VovKaFicator (Func UsedVars)
  (or GenVarName
      (defun GenVarName (VarName UsedVars /)
(if (assoc VarName UsedVars)
 UsedVars
 (cons (cons VarName (read (substr (vl-filename-mktemp "_" "\\") 2))) UsedVars)
  (cond ((null Func) nil)
((= (car Func) 'QUOTE) Func)
((listp (car Func))
(cons (VovKaFicator (car Func) UsedVars) (VovKaFicator (cdr Func) UsedVars))
((= (car Func) 'DEFUN)
(cons (car Func)
      (cons (cond ((cdr (assoc (cadr Func) UsedVars)))
  ((cadr Func))
    (VovKaFicator (cddr Func)
  (progn (foreach v (vl-remove '/ (caddr Func))
   (setq UsedVars (GenVarName v UsedVars))
 UsedVars
((= (car Func) 'LAMBDA)
(foreach v (vl-remove '/ (cadr Func)) (setq UsedVars (GenVarName v UsedVars)))
(cons (car Func) (VovKaFicator (cdr Func) UsedVars))
((assoc (car Func) UsedVars)
(cons (cdr (assoc (car Func) UsedVars)) (VovKaFicator (cdr Func) UsedVars))
(t (cons (car Func) (VovKaFicator (cdr Func) UsedVars)))
(setq
  testfunc (quote (defun test (arg1 DoNotRename / var1 var2 var3 test *error*)
   (defun *error* (msg) (princ msg))
   (defun test (arg3) arg3)
   (setq var1 (strcat arg1 (setq var2 (strcat DoNotRename "_" arg1))))
   (setq
     var3 (strcat (vl-princ-to-string
    (mapcar (function (lambda (e) (test e))) '(1 var1 3))
  var1
  ((lambda (str1 / str2 var1)
     (setq str2 (strcat arg1 (setq var1 DoNotRename)))
     (strcat str1 str2 var2)
    var1
  var2
(prin1
  (VovKaFicator testfunc
'((*ERROR* . *ERROR*) (var3 . guesswhat) (DoNotRename . DoNotRename))
GenVarName is a subject to change to strengthen the ambiguities  :roll:
ElpanovEvgeniy
  • Moscow (Russia)
Re: lisp code scrambling
« Reply #1 on: January 14, 2010, 01:20:18 PM »
How to use your function?
I have not understood, how it to use...
>> add:
Apologize, has understood, an example in the end...
« Last Edit: January 14, 2010, 01:30:38 PM by ElpanovEvgeniy »
« Reply #2 on: January 14, 2010, 02:54:24 PM »
Recursive... much...  :evil:
VovKa
  • Ukraine
« Reply #3 on: January 15, 2010, 04:08:46 AM »
sorry, this was the only way i could do it  :wink:
