Author Topic: Removing Lines from Text File  (Read 8374 times)
ElpanovEvgeniy
  • Moscow (Russia)
Re: Removing Lines from Text File
« Reply #15 on: January 13, 2010, 03:37:11 PM »
other version...
(defun f (a b c) (and a b (write-line b c)))
(defun c:test (/  c d)
 ;; '(nil nil nil t) - Pattern of lines of the text for record
 (setq d (getfiled "Select File" "" "txt" 16)
       c (open (strcat d "-New.txt") "w")
       d (open d "r")
 ) ;_  setq
 (while (foreach a '(nil nil nil t) (f a (read-line d) c)))
 (close d)
 (close c)
) ;_  defun
« Reply #16 on: January 13, 2010, 03:44:32 PM »
Very nice solution Evgeniy, although I think he/she wanted to keep the first line, and discard the rest (other three), so that while loop may need some re-jigging...  :wink:
But I do wish that you would give you variables some meaningful names... makes it so much easier to follow...  :wink:
« Last Edit: January 13, 2010, 03:52:49 PM by Lee Mac »
« Reply #17 on: January 13, 2010, 04:01:30 PM »
Yes '(t nil nil nil)
« Reply #18 on: January 13, 2010, 04:34:34 PM »
Not quite.
The While loop relies on the 't' being last...  :wink:
VovKa
  • Ukraine
« Reply #19 on: January 13, 2010, 04:41:51 PM »
i believe Evgeniy has a Kelvinator for "forum-posting" purposes :)
« Reply #20 on: January 13, 2010, 04:41:56 PM »
I better have a close look. 8-)
« Reply #21 on: January 13, 2010, 04:58:44 PM »
I see, very clever.
But this works.
(defun f (flag str fn) (and flag str (write-line str fn)))
(defun c:test (/ fname fnr fnw s)
 (setq fname (getfiled "Select File" "" "txt" 16)
       fnw (open (strcat fname "-New.txt") "w")
       fnr (open fname "r")
 ) ;_  setq
 (while (foreach a '(t nil nil nil) (f a (setq s (read-line fnr)) fnw) s))
 (close fnw)
 (close fnr)
) ;_  defun
« Reply #22 on: January 13, 2010, 05:06:42 PM »
I see, very clever.
But this works.
It does indeed  8-)
« Reply #23 on: January 13, 2010, 05:27:48 PM »
<snip>
heh, Dave Stein used to use vowels. *lmao*
(defun blah ( / a e i o u ) ...
« Reply #24 on: January 13, 2010, 05:53:31 PM »
<snip>
Haha, reminds me of an article I remember someone posting on here describing 'good programming practices', like having two variables like:
(defun blah (/ lI Il ...
And using comments that describe the code as doing something completely different...
trying to find the thread now...
« Reply #25 on: January 13, 2010, 05:53:46 PM »
« Reply #26 on: January 13, 2010, 05:56:13 PM »
<snip>
Ahh yes
« Reply #27 on: January 13, 2010, 06:18:23 PM »
<snip>
Ahh yes
*click-click* Oh my goodness. yeah dont do that. just put the keyboard down and step away.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #28 on: January 14, 2010, 01:03:45 AM »
I also am Kelvinator...  8-)
It is convenient me, when local variables short, they do not prevent to see music of the program and its rhythm.
Long names of variables, can borrow more places, than sense the code.
« Reply #29 on: January 14, 2010, 07:54:14 AM »
Thanks CAB ... writing to a new text file helps. I just wish I knew  which part of the code to modify if I needed to keep, say every 5th line, 6th line or some other number instead of the 4th.
Is there some kind of pattern you are looking for?
